Results 1 to 19 of 19
Thread: 2.0t coilpack conversion question
  1. Member kay207's Avatar
    Nov 19th, 2009
    Sanford, ME
    2001 VW Jetta Wolfie
    09-07-2012 06:12 PM #1
    I have been doing a little bit of research on the 1.8t to 2.0t coilpack conversion settup... The only thing that I am having a hardvtime figuring out is the type of coil to use, fsi or tsi. I have a 2001 jetta with the AWW engine code... What coil would I be leaning more towards?
    Thanks,
    Kay
  2. Member Twopnt016v's Avatar
    Jul 5th, 2009
    1983 2.0 16v turbo bunny, 1991 2.0 16v Gti, 1986 Jetta Coupe 2.0 16v, 2002 337 Gti, Giannini R1
    09-07-2012 06:19 PM #2
    FSI...but you can use the TSI.
  3. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    09-07-2012 06:40 PM #3
    Most answers can be found here...
    http://forums.vwvortex.com/showthrea...-Contents-1.8t
    FSI/ TSI Coil Packs
    RED MKV FSI Coil Packs - 06E 905 115
    BLACK MKV FSI Coil Packs - 07K 905 715 F
    * This is the recommended coil
    BLACK MKV TSI Coil Packs - 06F 905 115 F
    BLACK MKVI TSI Coil Packs - 06H 905 115
    My Build
    FS: New in box, primer'd 20AE body kit (front+rear valences and side skirts) -- PM me for details
    FS: Fiberglass 20AE replica spoiler. No scratches. Reflex Silver.
  4. Member kay207's Avatar
    Nov 19th, 2009
    Sanford, ME
    09-07-2012 06:49 PM #4
    So it really doesn't matter which one? I'm planning on chipping the car up to stage 2 next summer... Do the same specs apply? Obviously the spark plugs would change...
  5. Member kay207's Avatar
    Nov 19th, 2009
    Sanford, ME
    09-07-2012 06:52 PM #5
    Quote Originally Posted by groggory View Post
    I looked at that chart a few times, I just wasn't sure if anything would've been different because of the car being an earlier 1.8t.
  6. Member
    Jul 8th, 2006
    Toronto
    03 Golf
    09-07-2012 07:04 PM #6
    Engine type doesn't matter, only relevant factor is boost pressure to determine plug gap
  7. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    09-07-2012 07:13 PM #7
    In other words.
    Buy appropriate adapter for your specific valve cover style.
    buy coil pack # 07K 905 715 F
    My Build
  8. Member kay207's Avatar
    Nov 19th, 2009
    Sanford, ME
    09-08-2012 04:18 PM #8
    I really like the red packs... from my understanding they are about the same as the black packs... Can anybody say otherwise?
  9. Member DMVDUB's Avatar
    Jan 10th, 2010
    NOVA
    German, American, Jap'erican
    09-08-2012 04:56 PM #9
    Bremi STI coils are red and don't require any extra hardware. You don't need a bigger coil / gap for a stage 2 car.
    PROTECTED BY SMITH & WESSON
    MAESTRO - 3"MAF - IE Rifle Drilled Rods - 550cc Bosch EV14 Injectors - Gonzo Tuning GTT K04 Hybrid Turbo - Devils Own Water Meth - Walbro 255 inline - Eurosport FMIC - Peloquin LSD - Madmax wastegate mod - Werk in Progress INTEGRATED ENGINEERING
  10. Member kay207's Avatar
    Nov 19th, 2009
    Sanford, ME
    09-19-2012 11:21 AM #10
    Okay kiddos, so I did my conversion yesterday:
    MkV red 2.0t fsi coil packs
    Red Integrated Engineering Adapters
    Red coil pack harness protecter
    NGK BKR6EIX Iridium spark plugs tapped at .035
    So far so good! My only question is about the gap... It's definitely a trial and error sorta thing, as all cars are different. My car is not yet reflashed or chipped... But it does have:
    2.5" catback exhaust
    3" downpipe with a highflow cat
    Air intake
    Forge DV
    Race N75
    and will be installing a new smic and MAP sensor
    Do you think that it is an appropriate gap and spark plug combo?
  11. Member DMVDUB's Avatar
    Jan 10th, 2010
    NOVA
    09-19-2012 11:50 AM #11
    Yeah, stock.
  12. Member kay207's Avatar
    Nov 19th, 2009
    Sanford, ME
    09-19-2012 01:38 PM #12
    Keep a stock gap?
  13. Member
    Mar 8th, 2012
    NW Louisiana
    2004 Jetta 1.8T
    09-19-2012 01:55 PM #13
    I don't think the coils are much stronger. Maybe you can gap them a little more. I think the main hope is the longevity of a more developed coil. LS2 coils are where you wanna go for big spark gaps.
    Quote Originally Posted by Dwight Shrute
    "I know how to build a business. You gotta get the black people to do it, to get the white people to do it. Then you gotta get the black people to stop doing it. One step at a time."
    Gonzo Stage 2+ w/2-step
  14. Member kay207's Avatar
    Nov 19th, 2009
    Sanford, ME
    09-19-2012 02:46 PM #14
    I gapped them at .035... Should I just put them back to .028-.032?
  15. Member
    Mar 8th, 2012
    NW Louisiana
    2004 Jetta 1.8T
    09-19-2012 04:24 PM #15
    I would drive around a week or two and check the plugs every once in a while. If they look okay then you're probly fine
  16. Member DMVDUB's Avatar
    Jan 10th, 2010
    NOVA
    09-19-2012 04:38 PM #16
    You have no reason to widen the gap or whatever. "IF" they are more reliable put them at .028 or .032 and let them be. You won't gain a thing by changing the gap on a stock turbo.
  17. Member kay207's Avatar
    Nov 19th, 2009
    Sanford, ME
    10-06-2012 05:00 PM #17
    So today I got a uni stage 2 flash... I am currently running NGK bkr6eix Iridium spark plugs at a gap of .33... So now I should go with NGK bkr7... Iridium or coppers?
  18. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    10-06-2012 05:23 PM #18
    Ngk 4644
    My Build
  19. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    audi tt gt3076r 01 aston martin db7 04 land rover disco 99rolls royce seraph
    10-06-2012 10:47 PM #19
    Quote Originally Posted by thefrese View Post
    X2
    http://forums.vwvortex.com/showthrea...t-done-I-guess
    ^^^Big Turbo build lots of pics^^^
    Best shop for repair and custom workin ma
    http://www.wentworthmotorsports.com/
