Results 1 to 2 of 2
Thread: Can you help me with my problems
  1. Member KeiCar's Avatar
    Jul 22nd, 2002
    Philly (past & present) -- Bangkok, HK, Singapore (future).
    2000 Honda CRV SE / 2012 Samsung Galaxy S3
    09-07-2012 08:11 PM #1
    I usually (never) post here because I usually dont have engin problems like this. Car in question is a 1997 Acura TL 3.2 (V6), ran great until one day it didn't
    Quick backstory: Got it from a friend, mechanic checked it out ok, did all my "usual" maintenance stuff (fluids (inc oil filter), belts, bulbs, filters, plugs & wires, PCV...ect. 155,xxx miles.
    Car will start fine but idle low, I had it turn off completely twice while sitting at a light. Started right up again and it had been on a while so everything was up to temp. In neutral it will rev freely till redline, no issues. While driving it is very sluggish in 1st up to about 2800RPM then a hard shift into second and all is fine, up to and including 5th gear, rides perfect at highway speeds (70ish). I would really like to get this running right, I just put new plugs in it yesterday, but that did nothing.
    The following is what the code scanner revealed:
    Code:
    P0155- O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
    P0135- O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 1)
    P0141- O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 2)
    P1204- Cylinder 4 Misfire
    P1205- Cylinder 5 Misfire
    P1206- Cylinder 6 Misfire
    P1316- Spark Plug Voltage Detection Circuit Malfunction, Front Bank
    P1317- Spark Plug Voltage Detection Circuit Malfunction, Rear Bank
    P1318- Spark Plug Voltage Detection Module Reset Circuit Malfunction, Front Bank
    P1319- Spark Plug Voltage Detection Module Reset Circuit Malfunction, Rear Bank
    P1768- Automatic Transmission System Malfunction
    P1300- Random Misfire
    P1399- Manufactures control Ignition system OR Misfire
    Few people understand the psychology of dealing with a highway traffic cop. A normal speeder will panic and immediately pull over to the side. This is wrong. It arouses contempt in the cop heart. Make the bastard chase you. He will follow.
  2. 09-19-2012 09:35 AM #2
    WHO CARES IT"S A HONDA!!!
