#36
#37
#38
#39
#40
you guys can add me to the list.
Was driving my car last Friday night. Took a right turn and suddenly the car lost throttle response. Car came to a stop and died. Engine wouldn't turn over. Had it towed to dealership and they determined the water pump pulley had started to work its way away from the engine. The pulley ground into the belt and caused the timing belt to go.
~6k miles on the odometer
didn't think to check build date before finding this thread but car was shipped first week of April so it is likely a march build
mods: apr stg 1, evoms intake
Dealership has had the car since Friday night and I am still awaiting the final decision from VWoA on warranty coverage. Hopefully they will decide tomorrow and the dealership can start fixing the R as well as give me a loaner so I'm not bumming rides from friends.
#41
"Don't believe everything on the internet" ??!!
I would have snapped had someone tried smokescreening me with such an ignorant platitude. No shiite, Sherlock.
OTOH, when forums full of enthusiasts are consistently reporting on a subject, once can only conclude that it's either A) a vast conspiracy with unknown aims and origins or B) worth looking into.
#42
I think a shed a tear when I went out to my R and saw the build date was March.![]()
#43
Thanks
R32TRELLA -> Feb Build - 4000 miles
http://forums.vwvortex.com/showthrea...1#post78047481
nate4486 -> March Build - 2415 miles
http://forums.vwvortex.com/showthrea...1#post78893676
usurbrain -> ?? Build - 6500 miles
http://forums.vwvortex.com/showthrea...1#post78505842
FDP -> March Build - 2400 miles
http://forums.vwvortex.com/showthrea...ll=1#post78963
arcticgenes -> March Build?? - 6000 miles
http://forums.vwvortex.com/showthrea...1#post79110919
#44
How many .:R's now? 7 and counting?![]()
2013 R RB - HPA Comp Controller - HPA Red 75A Motor Mount - HPA Short Shifter - 42DD Shifter Bushings - TyrolSport Solid Shifter Bracket Bushings - Carbotech Bobcat 1521 (Daily) - Carbotech XP12/XP8 (Track) - Unibrace UB - Euro Springs
#45
My build date is March as well, I'm at 8700 miles and no issue so far. I'm hoping it stays that way. I have had a few rattles in the cabin that I've had to track down, but other than that the car has been fantastic! I think I will check the water pump just for my own sanity, soon though. Having the clutch go bad is one thing, because that is easily replaced, yes it costs money if they won't cover it under warranty (I'm at stage 2+) but at least it doesn't require a complete engine swap. I'm not worried about clutch issues, it will give me an excuse to upgrade the clutch, but I am worried about the water pump failures.
#46
Is there any way we can visually check this issue ourselves? Would there be any obvious sign something's wrong before it goes?
Lurking Vortex Since '99
Former: '00 VR6 GTI/'04 MKIV R32/'07 Audi RS4
Current: Only owner of 1980 CJ7, 07 Range Rover Supercharged
Now Showing: Golf R - White (now w/ "accessories")
#48
Agreed it's a big task, and I don't know how to physically check it, I have a buddy with a lot more experience with VW than me (he's a mechanic) so I plan on asking him if it's worth just changing out the water pump altogether for piece of mind. To me a day or weekend in the garage is far better than weeks without my car and a total engine swap.
#49
#50
#51
#52
2012 VW Golf R Rising Blue 2-DR | APR Carbonio Intake | APR Stage 1 ECU | Clear Sidemarkers | R Mats | Blind Spot Mirrors | H&R Sport Springs | 19x8 TSW Nurburgring Wheels | 235/35/19 Michelin Pilot Super Sports |
2012 Volvo S60 T-6 Electric Silver/Anthracite. Stock.
#53
Most definitively the water pump. It happened to me at 2400 miles. The pulley head of the water pumps are defective. They are coming loose and then shredding the belt. Depending on the damage, it is not necessarily a full engine replacement. My engine did not need replacement. Now that it is fixed, it runs great. It actually ran great before the pump fell apart, but it runs the same now as it did before. I'm not sure how you would be able to check the pulley head on the pump, but I'm not a mechanic, so hopefully someone with knowledge can chime in...
I had no mods at the time.
#54
#55
All we need is a part number from someone's failed pump.
Then we just see if it's the current pump being offered or an older one.
#56
http://forums.vwvortex.com/showthrea...ght=water+pump
Post#32 has a DIY visual check...
"Of course, but I can also downill ski and figure skate..."
#57
That was the same question I asked the dealer. They told me VW uses this pump on many different cars. The dealer assumes it was a bad batch of pumps. Based on these answers it's the same pump. VW pretended they had never heard of this problem before, which we all know is not true since others had this exact same problem before me...and had their cars fixed under warranty. I would guess VW keeps on eye on major warranty work!
#58
Thanks for posting, I've seen that but I'm assuming just doing a visual check on the timing belt isn't going to help much. Maybe I'm wrong, but I don't think this is just a gradual process, I think this might be bang bang thing, (pulley lets go, timing belt toast, you are out 10k unless warranty covers it!).
Edit: I have no idea why my text is bold, just ignore it.
#59
That's the way I was lead to believe from the dealer. The head pops off, shreds the belt and good bye jack! But it certainly should be covered.
#60
If I were VW, I would bloody get all of our pumps replaced on our .:R's, if its a $70 part, its better to just do a bloody mass recall then risk these $7,000 engines which VW seems to not only be replacing, but air shipping them in a few days from Germany and then covering the labour for install. Good lord...
#61
Don't forget, those are the ones we KNOW about. How many Rs have failed with owners not part of this forum.
If we guess only 10% of Golf R owners are here, are there then 10 times the number of failed automobiles? I find that hard to fathom because if that was the case, you'd think VW would be more active regarding the situation. But scary, nonetheless.
#62
#63
#64
#65
#66
#67
Is there a way to double check the pump and see if there are signs of the pully beginning to let go? Did anyone that had this problem hear any bearing noises or other indication that the engine didn't sound right?
[QUOTE=deathisgain;79119205]Thanks for posting, I've seen that but I'm assuming just doing a visual check on the timing belt isn't going to help much. Maybe I'm wrong, but I don't think this is just a gradual process, I think this might be bang bang thing, (pulley lets go, timing belt toast, you are out 10k unless warranty covers it!).
I looked at this DIY too and it is just a check to make sure the timing belt is not fraying.
#68
Anyone make an aftermarket water pump for these cars? A 70 buck part seems like a easy fix if you ask me...i rather replace it now than deal with a catastrophic failure.
Nevermind i found what i need. Booyah! http://www.ecstuning.com/Volkswagen-...gine/ES251179/
#69
I'm pretty sure that's the same pump that's in our cars right now. I don't think putting in the same pump will solve the problem. I was really hoping VWOA would do a recall, but it looks like it's wait and see. I'm going to contact VWOA and at the very least go on record saying I'm concerned.
#70
