VWVortex.com - idle increased 200 rpm
    Results 1 to 3 of 3
    Thread: idle increased 200 rpm
    1. 09-09-2012 04:16 AM #1
      the car is a 1984 gti rabbit
      I just removed the throttle body rubber boot and sprayed the throttle blades with carb cleaner, I tok a toothbruch to them and got them clean
      I also removed the boot from the air sensor plate (above the air filter) and claned the plate and hte surrounding surface. I took a magent to the center bolt on the plate and lifted it up and cleaned the edges and mating surfaces.
      now my idle is about 200 rpm higher.
      is my car now running richer or leaner?
      Mar 31st, 2008
      PNW - Oregon
      09-10-2012 10:21 PM #2
      its not running richer or leaner, just 200rpm higher..
      as long as you did not mess with the setting on the fuel distributor, then its exactly the same mixture as it was before you cleaned the throttle body..
      you can turn the idle back down to where it used to be, with the idle screw.. its pointing towards the firewall on mk1 cars..
      Apr 16th, 2006
      Brokelyn, NY
      90 fox, 85 gli
      09-10-2012 10:23 PM #3
      you may have not secured one of the boots on fully, resulting in an air leak. the ecu sees lean from the o2 sensor and compensates, resulting in a higher idle.
      you can determine your mixture properly with a dwell meter, or just warm the car up, unplug the o2 sensor and measure the voltage.
      I really suck at smog.
