Results 1 to 3 of 3
Thread: FS: Two - 0.71 5th gear sets and One - 0.75 set 5th gear set
  1. Member flowmastergfunk's Avatar
    May 30th, 2007
    Jamul, Ca
    89 1.8l Crabbit (RIP), 79 Rabbit C "Diesel" 2.0l, 96 Jeep Cherokee 4.0l 4x4 tractor on 33's
    09-09-2012 04:20 PM #1
    I have been collecting and hoarding these for too long but I am ready to thin the heard! If you need info on how to swap these into your 020 or parts for the 5th gear swap, go to www.brokevw.com Brian is a genius, has great walkthroughs, all the parts you would need at a fair price, and is happy to answer any questions that you might have. I might also be able to help with any questions so feel free to ask me too!
    You do not need to take out the transmission to install the gear set (even though it is a little more tricky with the mk1 frames).
    Major millage and top speed upgrade! Also great for diesels!
    0.71 set ~ $110 shipped SOLD
    0.75 set~ $80 shipped SOLD
    There are no chipped, damaged or worn teeth. I would personally run any of these sets as is but it would be up to you whether or not to replace the bearing, sync rings,keys and springs. Unlike what you would find on ebay, these sets are complete and ready to bolt in. You will need a new 5th bolt, circlip and 5th housing gasket. Brian will hook you up with any and all parts that you desire
  2. Member flowmastergfunk's Avatar
    May 30th, 2007
    Jamul, Ca
    09-10-2012 12:19 AM #2
    Only one 0.71 set is left! Both the other sets sold fast
  3. Member flowmastergfunk's Avatar
    May 30th, 2007
    Jamul, Ca
    09-11-2012 05:09 PM #3
    Split up with the old lady and moved out. Freedom bump.
