Results 1 to 5 of 5
Thread: Diagnostic Port has no power
  1. 09-09-2012 04:26 PM #1
    Trying to use diagnostic computer/vag-com but no power in the port. Sometimes the the handheld will power on and then stop working days later, what sends power to the diagnostic port? Any ideas would be appreciated
    Sent from my LG-P999 using Tapatalk 2
  2. Member emmwhat's Avatar
    Jan 18th, 2010
    Baltimore, MD
    2005 Audi S4
    09-10-2012 04:53 AM #2
    I don't know why it would be intermittent but I'm almost 100% sure there's a diagnostic port fuse you may want to check. It's in the fuse panel when you open the driver side front door, between the door and the dash.
    -Steve
    Baltimore, MD 21234
  3. 09-10-2012 02:29 PM #3
    Quote Originally Posted by emmwhat View Post
    Yes you're correct, I need to check that when I her home from work
  4. 09-16-2012 02:59 PM #4
    Looked in manual didn't see anything close to it so I checked all of them again
  5. 10-03-2012 09:49 AM #5
    If its similar to a Vw fuse block the diag fuse is a 7.5 amp mini in the fuse block inside by a pillar
