Page 1 of 2 1 2 LastLast
Results 1 to 35 of 57
Thread: Cheap man's air ride question lol
    Jan 4th, 2012
    2003 Jetta 1.8T / 1975 Bug
    09-09-2012 09:06 PM #1
    so i want to lower my 75 bug soon and i was thinking starting with 2 1/5" drop spindles, and then some Gabriel hijackers on the front and rear of the car. these shocks are air assisted and instead of the car bleeding the air out when it is parked and what not i could just set the ride hight the way i want and keep them that way. unless i could figure a way to add a air pump and tank to them.
    thought id ask what you all thought about that set up.
    here is a picture of the shocks for reference.
    http://a.cdnbrm.com/images/products/...ker_shocks.jpg
    Jan 4th, 2012
    09-10-2012 08:25 AM #2
    Does anyone happen to know off the top of their head what the stock bug's shock > overall lingth, and travel would be? That way I know about what size hijackers to look for. Thanks
  3. Member JDII's Avatar
    Apr 1st, 2011
    1965 TYPE 1, 1956 TYPE 1, 1948 SPLIT
    09-10-2012 04:47 PM #3
    I find this statement to be very interesting, so if you have air bags you really have no idea what ride height your ride may be at any given time, especially when parked man......bags sound really complicated. I cant believe no one thought of using those air shocks before sounds alot easier.
    Smile it will get Worse!!
  4. 09-10-2012 05:03 PM #4
    Quote Originally Posted by JDII View Post
    leave it to the MK4 kids to show the way and enlighten us to all things lowered of an aircooled
    my slammed baywindow bus build...a labor of love
    Quote Originally Posted by LooseNuts View Post
    the only time you will be done is the day before you sell it.
    Jan 4th, 2012
    09-10-2012 10:49 PM #5
    So I guess you all like where this is going ? And plus the mk4 is my wife's car, she won't let me play with it to much. So I got some measuments today for the front and rear stock shocks.
    Front - compressed from stud bushing to eyelit is 13 1/4"
    Front - uncompressed from stud bushing to eyelit is 18"
    Rear - compressed from eyelit center to eyelit center is 10 1/2"
    Rear - uncompressed from eyelit to eyelit is 16"
    So I found the hijackers for the rear that have both eyelits but the font is where I'm stumped. I'm not sure if hijackers come in a stud to eyelit. So the search goes on. Hope to have some results soon.
  6. 09-10-2012 11:31 PM #6
    Quote Originally Posted by Hackintosh View Post
    no we don't. it's called sarcasm.
    you think you're coming up with something amazingly new and different? you're not.
    this setup will not work successfully.
    Jan 4th, 2012
    09-10-2012 11:41 PM #7
    Why wouldn't it work ? I like to know that's why I was asking, so that someone that knew more than I do about it would share what they know on this subject. Sorry for the dumb question I guess.
  8. 09-10-2012 11:56 PM #8
    there's boat loads of info on air ride setups for aircooled beetles/buses/type III's/etc out there....and unless you are a good fabricator or have deep pockets there isn't another viable option to making an air ride setup.
    why won't your idea work? first up your shock mounts are not designed to take the load of the vehicle. then secondly, what are you gonna do about your torsions? your air shock setup would be fighting against the torsions no matter what height you put it at...and which, more than likely, would make it ride like total ass as a result. third? sure. if you check out air beam setups they are removing the torsions, and/or incorporating them into the air bag setups so that they still work like factory. and above all they are usually leaving the stock shock mounting locations for one to run shocks...so that the setup would ride decently at a driveable height.
    google-ing "air beams for vw's" will get you off and running on the information that's out there on this subject
    Jan 4th, 2012
    09-11-2012 12:06 AM #9
    Ok thanks, I know it wasn't a new found idea at all I just wanted to know if it was possible to do that set up and you answered that. I did think about the tortion bars and how that would work out. So if I were to legitamently buy a bag set up and have on bag in the front been an two in the back what would happen to the tortion bars then ? I saw someone here do a set up like that but they were not clear on how the bag moved the beam. Here again I'm just tossing ideas around if I wanted to bag my bug or make it static, but thanks for all the help so far
  10. 09-11-2012 08:44 AM #10
    Quote Originally Posted by A1steaksauce View Post
  11. Member
    Jan 4th, 2012
    09-11-2012 10:11 AM #11
    So what do you do with the tortion bar when you bag it ?
  12. Member JDII's Avatar
    Apr 1st, 2011
    09-11-2012 10:28 AM #12
    thats the beauty of fabbing the suspension set up yourself...... it's totally up to you!!!!
  13. Member
    Jan 4th, 2012
    09-11-2012 12:56 PM #13
    "if you check out air beam setups they are removing the torsions, and/or incorporating them into the air bag setups so that they still work like factory." - A1steaksauce
    That's what I thought, you would have to remove the tortion bar or come up with another way.
  14. Member LooseNuts's Avatar
    Oct 3rd, 2010
    the Couve
    57 Lowlight B7
    09-11-2012 03:35 PM #14
    most everyone leaves the rear torsion bars in. set the pan to the lowest ride height you want when the bags are empty. then run the bag set up to rotate them downwards "which raises the car" when airing up.
    J
    Quote Originally Posted by WideFive
    If you have to ask if it's a good trade... then it isn't a good trade.
    Quote Originally Posted by Schell R32
    ACW's aren't a watercooled APPLIANCE,it's a classic air cooled pile that takes money,patience and attitude to own it.
    http://www.facebook.com/VWLoosenuts?sk=wall www.cultwagen.com.
  15. Member
    Jan 4th, 2012
    09-11-2012 04:22 PM #15
    Understood. Im still getting mixed answers about the front tortion bar. Some say they put a solid bar in place of the tortion bar and some say they took it completely out. So what's best for the set up I was trying to make work.?
  16. 09-11-2012 04:26 PM #16
    true. plus it gives you a suspension that's functioning somewhat like stock in the process.
    generally i've come across people removing the torsions and running a solid bar stock when they are running a dual air bag beam. however that's a bunch of work to make a dual bag front beam work. the single setup is much easier and cheaper
  17. Member JDII's Avatar
    Apr 1st, 2011
    09-11-2012 04:42 PM #17
    I had a brain fart. what if you left the front torsion stacks in. they are locked in place by the center mounting bolt in the tubes. when you put in adjusters you split the beam and put them in so they will let the torsion stacks rotate to the desired height and then lock them back in place. my fart is this, could you not rig the center locking like an adjuster so it will rotate free when being aired up or down then use some sort of air lock to lock them back in place to have a stock ride. only use a bag to air up and down?
  18. Member LooseNuts's Avatar
    Oct 3rd, 2010
    the Couve
    57 Lowlight B7
    09-11-2012 04:55 PM #18
    use the monroe air shocks in the front.
    remove the torsions add drop spindles and add in a solid rod trough and run the shocks
    monroe air shock thread. go through this
    http://www.thesamba.com/vw/forum/vie...shocks&start=0
    through bolt set up for up front after torsions are removed. note the air shocks also
    J
  19. Member
    Jan 4th, 2012
    09-11-2012 07:30 PM #19
    Thanks for the link I came accross that thred lastnight but didn't have muh time to read it all
  20. Member
    Jan 4th, 2012
    09-22-2012 01:04 AM #20
    So I decided to go with bags on the back and just make my own brackets. I already have the tank and pump so all I really need are the bags, fittings , and air line. Where would be the place to look for those maybe individualized. Thanks
  21. Member
    Mar 5th, 2003
    Baltimore
    67 Beetle, 99 Passat Wagon
    09-23-2012 09:30 PM #21
    you also need valves. and don't be a cheap skate when it comes to fittings. last thing you want is a crap home depot fitting blowing under pressure and you lay out at highway speeds. and in making your own brackets make sure nothing is anywhere near your bag that could potentially rub through it...
    what I'm saying is don't buy cheap stuff, it's your life when it fails
    -Maryland Nick-
    -DCI East-
    static is for poor people.
  22. Member
    Jan 4th, 2012
    09-23-2012 11:39 PM #22
    understood where is a good web site for fittings and also should i go with manual valves or electric ones
    i found a guy selling some air lift bags and hes asking $50 a pair, he says they only have 2K miles on both sets does that sound good our no ?
  23. Member
    Mar 5th, 2003
    Baltimore
    09-24-2012 08:55 AM #23
    suicidedoors.com, guagemagazine.com I got most of my fittings from them. I like electric valves, but manual valves are cheaper.
    -Maryland Nick-
    -DCI East-
  24. Member
    Jan 4th, 2012
    10-13-2012 02:06 PM #24
    ok so i know i need thru rods for the front end but do i need any for the rear or do i take out the torsion bar in the rear and let the air bags do all the work?
  25. Member Jade Wombat's Avatar
    Oct 20th, 2004
    Quito, Ecuador
    '66 Bus
    10-16-2012 09:29 AM #25
    Either one. It depends on how low you're going and where your mounting points for the rear bags/brackets are. You can re-index the torsion bars lower so they support some of the load, do a search on how-to, blah, blah...
  26. Junior Member
    Jul 24th, 2011
    chucktown. sc
    10-17-2012 05:25 AM #26
    Sry if I'm repeating what's already been stated but I only had a sec to thumb thru this thread but decided I needed to chime in wid my 2cents. Having the history of bagging and juicing ( hydraulics for those that don't remrber that bein the at one time only option for adjustable suspension)....airshocks if the right ones will work on the front of a standard....as a matter of fact there are several companies that sell air setups that the front is just that! And as for the torsion bars....takem out...remember they work in both directions.....when pushed up they push down...when pushed down...u guessed it they push up....so in other words they make ur bag or shock or cylinder work twice as hard to lift the car from a "preset" stance....a thru bolt as mentioned before will keep it all together in the front....as for the rear...slide them out and bolt it all back together....if your wheel/ tire combo allow it to hitrock bottom then u can get a different bump stop to limit its drop in the rear....as for the front....I've truthfully never fully worried about....I've always ran a big enough rim that rests the fender on it before the car hits ground....but there are ways to do whatever u want...depends on ur creativity and patience! But do please be carefull in ur trial and error! Hopefully this helps! Oh and dont skimp on valves!!!! Electric or manual. But if goin cheapest route manual will work just fine....remember these cars r light so they don't require a metric assload of force to pushem up! Hopefully this helps u on ur journey!
  27. Member
    Jan 4th, 2012
    01-07-2013 09:01 PM #27
    Ok so I know I'm brig this bak from the dead but didn't want to start a new thread.
    I got my tortion bars out and the thru rods in. I want to know what you all think in how I went about doing it. I have two steel washers / two neoprene washers/ one steel washer/ locking nut with cotter pin
  28. Member LooseNuts's Avatar
    Oct 3rd, 2010
    the Couve
    57 Lowlight B7
    01-08-2013 06:42 PM #28
    perfect. now cut off the extra all thread
    J
  29. Member
    Jan 4th, 2012
    01-08-2013 08:15 PM #29
    Thanks man i need to get some 2.5" drop spindles because the rear is lower than the front but an inch. Just wanted to make sure i was doing this right, don't want to have safety issues later
  30. 01-08-2013 09:23 PM #30
    hold the phone mr nuts...
    i spy one small...err big problem.
    if you ever for any reason have to take that assembly apart you're pretty much going to be SOL on getting that cotter pin to go back exactly how you have it.
    i would leave the rod ends out past the nuts somewhat and simply drill the rod and put the cotter pin out there, not thru the nut. that way you don't have to worry about trying to get the nut to line back up with the hole in the rod. and at the end of the day it does the exact same thing
  31. Member
    Jan 4th, 2012
    01-08-2013 09:41 PM #31
    thanks A1 that idea did cross my mind but i was told that it would be ok hahaha so i went ahead and did it this way till i can buy some of the squeez nuts in the picture that was posted earlier. i looked everywhere local and no one knew what i was talkinga bout. so i guess ill have to order them but might just do what you said seeings as i wouldnt have to order anything.
    also i know i have to cut the all-thread down this picture was taken just before i trimmed them down. But even cut down close, at both maximum low and high the all-thread seems to either touch the tire (when low) and the wheel (at high) so i guess ill have to adjust the bolts so that the wheel stops just before it touches the thread
    again thanks
  32. Member
    Aug 24th, 2004
    Anaheim,CA
    01-08-2013 11:14 PM #32
    thanks A1 that idea did cross my mind but i was told that it would be ok hahaha so i went ahead and did it this way till i can buy some of the squeeze nuts in the picture that was posted earlier. i looked everywhere local and no one knew what i was talking about. so i guess ill have to order them but might just do what you said seeings as i wouldnt have to order anything.
    again thanks
    Hi Hack ,
    There's Nylocks
    http://www.google.com/search?hl=en&s...INiPuLAp-LgNAB
    & crimp top nuts like
    http://www.google.com/search?hl=en&s...w=1280&bih=832
    Both should be available @ just ~ any local hardware store & both should be considered as one time use only since they lose their gripping ability pretty drasticly on reapplication due to being undistorted.
    Both are also used on things as critical as CV joints & stub axles on all late MK cars
    You could also probably lose 1 each of the doubled up neoprene washers for a skosh more room since 3 surfaces rubbing against each other is ~ the same as 4 frictionwise.
  33. 01-08-2013 11:28 PM #33
    I would weld them all together and beat stray cats to death. Stupid ****ing cats. Or you could sharpen the individual ones and chop off cat's heads with them, that may also be entertaining.
  34. Member LooseNuts's Avatar
    Oct 3rd, 2010
    the Couve
    57 Lowlight B7
    01-09-2013 09:58 AM #34
    or if it has to come apart for some reason. by a another .05 nut and drill a hole to match or re-drill your hole on the out side err-duh lol
    its fine, leave it and get it done, if you need to come back and take it apart then fix it then
    saucy is right tho, it would have been better to have the cotter on the outside of the nut.
    next time right. both saucy and i know about the next time stuff
    J
  35. Member JDII's Avatar
    Apr 1st, 2011
    01-09-2013 10:28 AM #35
    Or you could just buy the correct fastner for the application. AKA Castle Nut!!!
