VWVortex.com - Spacers? Yes? No?
    Results 1 to 25 of 25
    Thread: Spacers? Yes? No?
    1. Junior Member
      Jun 16th, 2012
      02 GTI 337
      09-10-2012 10:02 PM #1
      I was thinking about getting spacers because I recently slammed my 337 and i want my wheels to look flush with the fender, but i've heard stories about the wheels falling off, any recommendations?
    2. 09-10-2012 10:05 PM #2
      wheels falling off
    3. Junior Member
      Jun 16th, 2012
      02 GTI 337
      09-10-2012 10:11 PM #3
      Quote Originally Posted by sikknasty28 View Post
      wheels falling off
      Friends cousin was running adapters and thats what caused his wheel to come off and he flipped over the median and rolled 3 times. GTI was totaled.
    4. Member trev718's Avatar
      Dec 11th, 2009
      Beating you
      05/Gli
      09-10-2012 10:12 PM #4
      The same stories you heard was probably followed by a thread called "forgot to tighten wheel lugs"
      the majority of the euro world has spacers...Join the club.
    5. 09-10-2012 10:12 PM #5
      Quote Originally Posted by steeze20 View Post
      adapters an spacers are different but as long as you have quality spacers this highly unlikely
    6. Junior Member
      Jun 16th, 2012
      02 GTI 337
      09-10-2012 10:14 PM #6
      Quote Originally Posted by trev718 View Post
      What size should I get so it runs perfectly flush?
    7. Junior Member
      Jun 16th, 2012
      02 GTI 337
      09-10-2012 10:15 PM #7
      Yes I know, but theyre run the same way
    8. Senior Member 87vr6's Avatar
      Jan 17th, 2002
      SLC snow life
      THE IY AWD BT 20TH and Ti edition RS4
      09-10-2012 10:21 PM #8
      using the proper lugs (ball or cone), the proper length lugs, at the proper torque setting you have nothing to worry about.
      Buy quality spacers from either H&R or 42DD. Since you don't like searching, get 10/20 spacers, front and rear.
    9. 09-10-2012 11:34 PM #9
      the majority of the euro world has spacers[img]http://www.****.info/6d.jpg[/img][img]http://www.****.info/d.jpg[/img]
    10. Member Markg813's Avatar
      Jul 20th, 2010
      Magnolia, DE
      2004 Jetta TDI
      09-10-2012 11:36 PM #10
      10 mm spacers up front... 20 in the Rear.... DONE!
      INSTAGRAM: Markg813
    11. Member Justin_Eshelman's Avatar
      Dec 3rd, 2010
      South Alabama
      82' VW Caddy, RIP-2003 20th Anniversary GTI #0024
      09-10-2012 11:39 PM #11
      I'm one of the unlucky one's whose wheel fell off. What happened was i was using the wrong bolts. I had aftermarket wheels and bolts for those wheels. I ended up going back to stock wheels but didnt think and kept the aftermarket bolts. 3000 miles later the wheel fell off. Luckily i was doing 30 mph in a no traffic area, so i was alright but the car was totalled.
      Spacers are safe when they are ran correctly. 10 in the front and 20mm in the back will make stock wheels look good. Just remember to get longer bolts and torque the bolts properly. After theyre torqued go for a short drive and then re-torque them.
      My entire situation could have been prevented if i had done a 15 min google search.
      “A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”
    12. Senior Member 87vr6's Avatar
      Jan 17th, 2002
      SLC snow life
      09-11-2012 12:44 AM #12
      Quote Originally Posted by Justin_Eshelman View Post
      So, again, to repeat, it had nothing to do with the spacers. You used the wrong bolts. I have run spacers and adapters for the better part of 5 years straight. Not one single problem. Attention to detail.
    13. Banner Advertiser ECS Tuning's Avatar
      Oct 2nd, 2006
      Wadsworth, OH
      Modified Ones
      09-11-2012 11:18 AM #13
      We have spacer and bolt kits to insure that you get the correct length bolts to fit all OEM/ball seat wheels.
      Running aftermarket wheels? No problem, PM me and we will get you set up with the correct spacers and bolts!
      Andy
      http://www.ecstuning.com
      :: Phone: 1.800.924.5172 - Hours: Mon. - Fri. 8:00AM - 11:00PM EST Saturday 10:00AM - 7:00PM EST :: Email: sales@ecstuning.com & customerservice@ecstuning.com :: Facebook :: YouTube :: Live Chat :: Instagram
    14. Senior Member 87vr6's Avatar
      Jan 17th, 2002
      SLC snow life
      09-11-2012 05:27 PM #14
      Too bad your website has been down for the better part of 24 hours... I need a late model MK1 TT 225 pass side axle, bolt end style, and before your website went down, it said you had them in stock...
    15. Banner Advertiser ECS Tuning's Avatar
      Oct 2nd, 2006
      Wadsworth, OH
      Modified Ones
      09-11-2012 05:33 PM #15
      Quote Originally Posted by 87vr6 View Post
      Sorry about that, site was down for maintenance this morning and is now have been taken care of - After 9:00am the site was back up.
      PM me if you need anything, I would be glad to help!
      Andy
    16. Member Ducaud's Avatar
      Nov 18th, 2011
      Miami
      Porsche 996 Carrera, Mercedes w115 240d
      09-12-2012 10:48 AM #16
      10mm front 20mm rear with extended bolts ball seat of OEM and Conical is aftermarket.
      My wheel fell off last friday doing 20mph. I forgot to tighten the bolts on the back left wheel. Car slammed on the floor and the wheel rolled pass me. LUCKILY, nothing happened. the car landed on the coil over bolt and nothing else hit the ground, not even the brake rotor
    17. 09-12-2012 11:04 AM #17
      Do they sell a whole kit
    18. Member 3Dachs's Avatar
      May 21st, 2003
      Town of the Cow, TX
      IY 20th Ann. GTI #657 Original Owner
      09-12-2012 11:32 AM #18
    19. Member Zatch's Avatar
      Aug 13th, 2011
      Fancy
      20th
      09-12-2012 01:43 PM #19
      New milford isn't steezey yo
      Local
      search fail
      R135
      _246_
    20. Member
      Jun 20th, 2010
      Danbury, CT
      Bagged/Shaved/Stanced DBP .:R :: 2001.5 Audi S4 ::
      09-25-2012 06:51 PM #20
      Actually I am the one who was running the adapters that blew. I was running RH zwII's with RH adapters made specifically for the wheel with the correct lugs, they were also torqued to the correct given amount. I have heard other stories where they have blown on other people as well and I didnt think it would ever happen to me, oh but it did. Spacers are different, as the bolt goes directly into the hub instead of into a piece of metal in between the hub and wheel hub.
      You're not going to get that flush look with stock wheels whether you add spacers or not. Bigger rear wheels, stretched tires and lip to fender is considered "flush" to 90% of the people on here
    21. Junior Member
      Jun 16th, 2012
      02 GTI 337
      09-25-2012 09:35 PM #21
      Quote Originally Posted by bendoverr View Post
      Yeah I figured I just thought i'd try to figure something out just to see what answers i'd get, because I don't wanna dump too much into the car in case something were to happen then its basically money wasted. But I guess thats just the risk you have to take with cars.
    22. Member
      Sep 13th, 2003
      Edmonton, AB
      2003/VW/GTI 20th
      09-26-2012 10:27 PM #22
      Spacers are 100% safe and track friendly ONLY if they are hub centric and wheel centric, plus if your wheels have a different center bore (the middle hole that fits over your hub) use appropriate wheel hub centric rings that fit the spacer. That is the most important thing.
      If you don't have the weigh on the hub, then the weight is distributed over the lug bolts and then they break, wheels fall off and you crash. that is a given
      You will get flush look with stock wheels there are hundreds of examples on vortex alone. 20mm spacer with OEM aristos and they are sitting flush in the back. but tire choice and how low you are is important too.
      20th Ani GTI: FrankenTrubo F21T, Maestro, EV14 550cc, FMIC, MBC, H2Sport Spindles, Bilstein Sports, Neuspead Sport Springs, R32 rear LCA bushing, Neauspeed 28mm RSB, APR 2.5" DP, Milltek 2.5" turboback, Enkie RPF1 17x8, Tires: Sumitomo HTR Z III.
    23. Member
      Jun 20th, 2010
      Danbury, CT
      09-26-2012 10:46 PM #23
      Quote Originally Posted by [pl] View Post
      Couldn't have said it better
    24. Member Zatch's Avatar
      Aug 13th, 2011
      Fancy
      20th
      12-06-2012 01:52 PM #24
      steeze20, did I see you in new milli today, with another mk4 GTI and a yellow beetle?
      R135
      _246_
    25. Guest pete@blackforest's Avatar
      Aug 18th, 2011
      Raleigh, NC
      VW/Audi/BMW
      12-07-2012 05:18 PM #25
      We also carry spacers in several sizes for your application!
      I personally run 8mm and 15mm spacers on my GLI on RCs w/ 225/40 Michelin Pilot Sports. Looks good, no rubs.
      Like others have suggested, 10mm/20mm combinations work fine for most people as well.
      Each spacers description, as well as the wheel bolts, list what bolt lengths are required for each application.
      8mm spacers HERE
      10mm spacers HERE
      15mm spacers HERE
      20mm spacers HERE
      Wheel bolts HERE
      *8mm & 10mm spacers fit OEM wheels only
