a8 d3 load sensor (epc light on)
09-11-2012 12:22 PM
#1
Hi,
i have been struggling to get the bottom the 18265 DTC load sensor problem i have attached a full scan on my car its an audi a8 D3 3.0l diesel it WOULD BE MUCH APPRECIATED IT IF SOMEONE CAN HELP URGENTLY OUT THERE.
THANKS
AUDI FANATIC
VCDS Version: Release 11.11.4
Data version: 20120807
Tuesday,11,September,2012,17:07:40:52953
Chassis Type: 4E0
Scan: 01 02 03 05 06 07 08 09 15 16 17 18 19 1E 25 34 36 37 38 42
46 47 4F 52 53 55 56 61 62 72 76 77
VIN: WAUZZZ4E35N011184 Mileage: 137530km/85457miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: OK 0000
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: Sporadic communication error 1000
Address 01: Engine Labels: Redir Fail!
Part No SW: 4E0 910 401 J HW: 4E0 907 401 B
Component: 3.0L V6TDI G000AG 0020
Revision: --H01--- Serial number: AUX3Z0DN153709
Coding: 0011973
Shop #: WSC 02313 785 00200
VCID: 2241D276FD012808171
2 Faults Found:
17953 - Throttle Valve Controller
P1545 - 002 - Malfunction - Intermittent
Freeze Frame:
RPM: 0 /min
Torque: 167.7 Nm
Speed: 0.0 km/h
Voltage: 13.22 V
Duty Cycle: 92.7 %
Bin. Bits: 010
Mass Air / Rev.: 0.0 mg/str
Voltage: 0.000 V
17978 - Engine Start Blocked by Immobilizer
P1570 - 000 -
Freeze Frame:
RPM: 0 /min
Torque: 249.6 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 11.02 V
Bin. Bits: 00101100
Torque: 1035.3 Nm
Torque: 89.7 Nm
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4E0 910 156 F HW: 09L 927 156
Component: AG6 09L 3.0lTDI RdW 0100
Revision: 00000001 Serial number: 0000999
Coding: 0000001
Shop #: WSC 00000 000 00000
VCID: 254BC96AEC2FDF30723
1 Fault Found:
18265 - Load Signal
P1857 - 000 - Error Message from ECU
Freeze Frame:
Fault Status: 01110000
Fault Priority: 0
Fault Frequency: 2
Reset counter: 40
Mileage: 137088 km
Time Indication: 0
Date: 2012.09.03
Time: 20:14:07
Freeze Frame:
RPM: 736 /min
RPM: 736 /min
RPM: 0 /min
(no units): 30.0
(no units): 21.0
Temperature: 62.0°C
T.B. Angle: 0.0°
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H44 0510
Coding: 0008357
Shop #: WSC 02313 000 00000
1 Fault Found:
18265 - Load Signal
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131
Component: FBS AUDID3 H04 0140
Revision: 01404004 Serial number: AUX3Z0DN153709
Coding: 0265216
Shop #: WSC 02311 785 00200
VCID: D8B5309E6BDD32D8B95
Part No: XXXXXXXXXXX
Component: ELV XXXX
No fault code found.
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H08 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4063328
Shop #: WSC 00000 785 00200
VCID: 234FD772E21B21001C7
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 730 P HW: 4E0 035 729
Component: Interfacebox H43 2120
Revision: 00000000 Serial number: 343JJ047541312
Coding: 0000002
VCID: 2D5B314AB4DFE770BA3
Part No: 4E0 910 609 A
Component: Bedienteil MMI H42 0020
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 A HW: 4E0 820 043
Component: KLIMAAUTOMAT 016 0340
Revision: 00000029 Serial number: 00000000057059
Coding: 1067009
VCID: 1B3FEF92DA6B19C0D47
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 L HW: 4E0 907 279 L
Component: ILM Fahrer H12 0210
Coding: 0020121
VCID: 31632D3AA8E783909EB
Subsystem 1 - Part No: 4E2 910 113 B
Component: Wischer WWS D3 H50 0420
Coding: 00000037
Shop #: WSC 02313
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 HW: 4E0 959 655 G
Component: Airbag 8.4E+ H10 0940
Coding: 0431707
VCID: E3CF1772229BE100DC7
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H13 0040
Coding: 0112041
VCID: E5CB096A2CAF9F30323
Component: Lenkradmodul H04 0080
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 950 F HW: 4E0 920 950 F
Component: KOMBIINSTR. VDO H49 0200
Revision: D03 Serial number: AUDID3D9000899
Coding: 0000413
Shop #: WSC 06795 116 50998
VCID: 2757C3629623CD2040F
1 Fault Found:
16346 - Control Module - ROM Error
014 - Defective
Freeze Frame:
Fault Status: 00000011
Fault Priority: 1
Fault Frequency: 1
Mileage: 162351 km
Time Indication: 0
Date: 2008.05.13
Time: 09:11:05
Address 18: Aux. Heat Labels: None
Part No SW: 4E0 910 105 A HW: 4E0 815 069 E
Component: Heizgeraet H07 0100
Revision: 0000000B Serial number: 00000009006406
Coding: 0000001
VCID: 1A31EA96D55160C8CF1
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 HW: 4E0 907 468 A
Component: Gateway H07 0070
Revision: 07 Serial number: 160030482415B3
Coding: FCFE7BDE2B3104
1 Fault Found:
01303 - Telephone Transceiver (R36)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 4
Reset counter: 110
Mileage: 137539 km
Time Indication: 0
Date: 2012.09.10
Time: 15:59:07
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBD6031043
VCID: 1C3DEC8EDF651EF8DDD
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0265216
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 4480
Coding: 0015510
VCID: 2855C05E9B3DC258495
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H08 0060
Coding: 4063330
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 P HW: 4E0 919 887 C
Component: MNS ECE H43 1060
Revision: 00000000 Serial number: 353JU047586313
VCID: 3B7F0F127AAB79C0347
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H02 0090
Serial number: 00000426000247
Coding: 0035840
VCID: 1D3BE18AC47F17F02A3
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E2 959 802 B
Component: Türsteuer.FS BRM002 0060
Coding: 0028450
VCID: 2045D87EF30D3A18015
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H04 0040
Revision: 00400004 Serial number: W040411090075
Coding: 0000217
Part No: 4E0 907 719
Component: Neigungssensor H03 0020
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 L HW: 4E0 035 223 C
Component: Amp.-Basis H42 0290
Revision: 00000000 Serial number: 00000047541271
Coding: 0000003
VCID: 2649CE669129D4287B9
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H09 0040
Revision: Serial number: 00000000050636
Coding: 0010101
VCID: 1E39E686C9790CE8339
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E2 959 801 B
Component: Türsteuer.BF BRM002 0060
Coding: 0028450
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 C HW: 4E0 907 801 A
Component: EPB A32C0220 H02 0220
Revision: A32C0220
Coding: 0000221
Shop #: WSC 00370 210 91461
VCID: 1F47DB82CE7305E038F
1 Fault Found:
02596 - Rear Brake Pads Worn
008 - Implausible Signal
Freeze Frame:
Fault Status: 01111000
Fault Priority: 6
Fault Frequency: 2
Reset counter: 108
Time Indication: 0
Freeze Frame:
Voltage: 5.90 V
Count: 61
Address 55: Xenon Range Labels: 4E0-910-357.lbl
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0040
Coding: 0000001
VCID: E2C112763D81E808D71
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 L HW: 4E0 035 541 B
Component: TUNER EU/US/RDW H41 0560
Revision: 00000000 Serial number: 304KR047604646
Coding: 0000001
VCID: 2953C55A8037FB5056B
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: ENERGIEMANAGER H11 0390
Revision: 00000000 Serial number: 00000000014162
Shop #: WSC 00115 210 16290
Subsystem 1 - Part No: 009 2S5 015 0
Component: von VA0 1410300311
Coding: 303039325335303135302056413031343130333030333131
Shop #: WSC 12345 128 00289
5 Faults Found:
02273 - Quiescent Current Stage 2
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 165
Mileage: 122712 km
Time Indication: 0
Date: 2011.06.01
Time: 13:37:36
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 155
Mileage: 123216 km
Time Indication: 0
Date: 2004.03.30
Time: 15:59:52
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Mileage: 136445 km
Time Indication: 0
Date: 2004.04.02
Time: 21:04:05
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00110010
Fault Priority: 1
Fault Frequency: 6
Reset counter: 249
Mileage: 132452 km
Time Indication: 0
Date: 2011.12.05
Time: 13:52:51
02255 - Voltage Measuring Lead from Vbat
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 4
Reset counter: 239
Mileage: 130047 km
Time Indication: 0
Date: 2011.09.26
Time: 23:16:05
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Türsteuer.HL BRM002 0060
Coding: 0028450
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: Türsteuer.HR BRM002 0060
Coding: 0028450
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
Component: Parkhilfe 8-Kan H12 0020
Revision: --.--.-- Serial number: 08730415800043
Coding: 0001008
VCID: 2143DD7AF80733100EB
Address 77: Telephone
Cannot be reached
End ---------------------------------------------------------------------
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
Forum Rules
