Results 1 to 5 of 5
Thread: Starts, alternators, cyl heads, pulleys
    Dec 3rd, 2009
    Ashland, OR
    1978 Rabbit Diesel 4 door
    09-11-2012 03:28 PM #1
    I have a bunch of this stuff that needs to go:
    - 11mm 1.6D bare cylinder head casting with small oil return hole
    - 12mm 1.6D bare casting with a flat deck and a very minor cam rock
    - 2 good used cams, 1 cam with a chip out of the timing slot
    - 2 good starters
    - 2 good AC casting Bosch alternators with correct short pulleys
    - Misc AC and non AC pulleys & water pump, crank pulleys
    - One or two complete sets of injector lines
    - Several IP, cam, and small bore crank pulleys
    - 2 1.6 cranks that need to be turned or whatever - just pay for ship and handling/effort
    - couple of valve covers and oil pans
    Pics and prices coming later today...
    Jun 18th, 2010
    sacramento,ca
    1982 vw truck diesel, 79 rabbit 2 door diesel
    09-11-2012 10:51 PM #2
    you got other misc. stuff?
    like little l bracket that secures alt bracket to ip bracket?
    conical nut and bolt/washer that bolts ip to mount underneath?
    Dec 3rd, 2009
    Ashland, OR
    09-12-2012 03:03 PM #3
    Quote Originally Posted by damac2004 View Post
    Yep I should have all of it. If i`m missing any small pieces there I can find it.
  4. Member
    Dec 3rd, 2009
    Ashland, OR
    09-13-2012 11:17 PM #4
    Quote Originally Posted by Featured Cars View Post
    Found it & the conical bolt.
    AC setup (alternator/compressor not pictured)
    Dec 3rd, 2009
    Ashland, OR
    09-13-2012 11:19 PM #5
    11mm head...
    12mm head...
    1985 golf diesel radiator hose & return line...
