Results 1 to 16 of 16
Thread: Best coils for track use?
  1. 09-11-2012 03:55 PM #1
    Alright so I'm looking at getting my suspension in the next month and was wondering for you guys that race what would you say is the top 3 coils to get? I don't give a rats ass how low they will go since the lowest ill ever put the car is maybe a 2" drop. Id also rather not spend $2g's on a set so that I can afford the control arm and rear beam bearings and a good sway bar but if it's neccasary I'll do it.
  2. 09-11-2012 05:51 PM #2
    I really like the adjustability of the BC's and the b&g's and the price is great too but can they handle the abuse of autocrossin with occasional track and the monthly mountain runs?
  3. Junior Member pamatt's Avatar
    May 1st, 2012
    2012 GTI
    09-11-2012 10:12 PM #3
    We use H&R RSS they are under $2000.00 If money is no object there are even better choices.
  4. 09-28-2012 03:39 PM #4
    Quote Originally Posted by pamatt View Post
    For the sake of curiousity, care to list a few (sorry for a bit of a threadjack)
  5. Member Light on Fuel's Avatar
    Mar 1st, 2011
    North Jerzy
    01,VW,GTI GLX
    09-28-2012 05:51 PM #5
    I personally like the Koni 1150's. They're under $1200, adjustable and come with a lifetime warranty.
    PS~If you're interested in tuning your setup you can check out this thread I started that has been getting some really good info (thanks to meboice and others). GL
  6. Member theHAGGIS's Avatar
    Mar 3rd, 2002
    Atlanta, GA
    00 Jetta 1.8T
    09-29-2012 09:48 AM #6
    Before you buy a set, be aware of where the adjustable damping is situated. If you're in a mk4 any top adjusted coilover will need to be dropped out of the rear of the car to be adjusted. PITA. Not sure about the other generations. A few manufacturers address this issue.
    PS: Avoid Vmaxx Xxtreme for track use. I made that mistake, I blame my scottish frugalness.
  7. Member Light on Fuel's Avatar
    Mar 1st, 2011
    North Jerzy
    01,VW,GTI GLX
    09-29-2012 10:39 AM #7
    ^ Some rears require that you remove the shock to adjust dampening. This isn't such an issue if you intend to set it and forget it.
    Pretty much all decent coilovers within the price point of the 1150's will be like this. If you go up to the next range in price, you'll find several that have a dial adjuster in the rear.
    I'd also stay away from Raceland and FK.
    \X/
    May 30th, 2010
    Houston, TX
    10 JSW TDI, 12 R
    09-29-2012 10:30 PM #8
    I've had pretty solid results with Koni SS. My current build will be using Eibach Multi-Pro R2's which are around $2k.
  9. Junior Member pamatt's Avatar
    May 1st, 2012
    2012 GTI
    09-30-2012 11:50 PM #9
    Ohlins or the fully adjustable Eibach.
  10. 10-01-2012 11:55 PM #10
    i guess i should specify i have a MKIV GTI 1.8T
  11. Member Light on Fuel's Avatar
    Mar 1st, 2011
    North Jerzy
    01,VW,GTI GLX
    10-02-2012 10:56 AM #11
    Quote Originally Posted by WickedWorksVW View Post
    That doesn't really matter. A buddy who had a 20AE used Bilstein PSS9's. The rears can be adjusted w/o having to remove them and they run about $1500.
  12. 10-02-2012 12:20 PM #12
    I specified cause eibach doesn't make coilovers for my car that I could find.
    MKIV 1.8T: HKS SSQ Black series, Eurojet TIP, Forge short shift, B&M Shifter, 42DD Shifter bushings, EUROsport CAI, 42DD Pillar pod w/VDO boost Gauge, R32 brakes, Kamie grille, Enkie RPF1 17x8, Shine RSB, Never ending project...........
  13. Member Light on Fuel's Avatar
    Mar 1st, 2011
    North Jerzy
    01,VW,GTI GLX
    10-02-2012 01:47 PM #13
    I found them very easily.
    \X/
  14. 10-02-2012 03:50 PM #14
    If it is a full primarily track car find a used set of the AST/B&Gs. They sold out of them and are not making any more.
    Chris Lane - fifteen52 - Join us on Facebook
    chris@fifteen52.us 813.505.7910 - direct : 213.373.1552
    RML | 52 Wheels | KW | ST | B&G | Newing-Alpil | C2 | Air-Lift
  15. 10-03-2012 09:04 PM #15
    I couldn't find Ohlins for the mkiv.
  16. Junior Member pamatt's Avatar
    May 1st, 2012
    2012 GTI
    10-03-2012 11:45 PM #16
    Call Redline Speed Works in N.J. they will point you in the correct direction. It seems the other options are no longer available.
