Results 1 to 19 of 19
Thread: 2 misfires HELP?
    May 30th, 2012
    Sacramento, CA
    2004 Jetta GLI
    09-11-2012 04:06 PM #1
    Got a problem, car has CEL flashes when I start car and sounds like the car is choking, after 10 seconds cel stops flashes but is still on and car sounds normal, fuel injectors? I replaced my old ones with used ones worked fine for a day and started doing this again after. Any suggestions? (coil packs have been replaced under recall, and changed spark plugs a month ago) I scanned and have the codes P0300 P0301 P0303 for misfires.
    Jun 21st, 2010
    Darlington
    09-11-2012 05:54 PM #2
    Swap ign coils around and see if the misfire follows. Then do the same with the injectors. If the misfire doesn't follow either, check your ign coil harness for cracks. It may need to be replaced.
    Also make sure the valve cover isn't leaking oil into the plug ports.
    GLI / 1.8T / F23 / 550cc
    912 / Widebody / EJ20T / 915
    May 30th, 2012
    Sacramento, CA
    2004 Jetta GLI
    09-11-2012 06:59 PM #3
    Quote Originally Posted by STOICH View Post
    if the ign coil harness is cracked wouldnt the CEL stay on always? because sometimes it comes off n drives normally and then lights up again and starts bad
  4. Member
    Jun 21st, 2010
    Darlington
    09-11-2012 07:17 PM #4
    Not really. I would never relate the behavior of a CEL to eliminate possible issues. They can be very sporadic.
    May 30th, 2012
    Sacramento, CA
    2004 Jetta GLI
    09-11-2012 07:27 PM #5
    where could they crack? i checked the harnness on top looks to be in good shape, maybe its bad where i cant see it? also another important thing is I replaced my fuel injectors with used ones and after the car startedup perfectly no codes or anything but thenext day it started starting bad and CEL light on
  6. Member
    Jun 21st, 2010
    Darlington
    09-11-2012 07:43 PM #6
    Clear your codes.
    Move offending cylinder injector.
    Check codes again and see if the misfire code jumps with the injector.
    If not, do the same to your ign coils.
    If the misfire doesn't follow the moved parts, you're most likely looking at a plug or harness issue.
    May 30th, 2012
    Sacramento, CA
    2004 Jetta GLI
    09-11-2012 08:09 PM #7
    Clear your codes.
    will go ahead and try that, thanks for the advice
    May 30th, 2012
    Sacramento, CA
    2004 Jetta GLI
    09-11-2012 08:15 PM #8
    Clear your codes.
    can oil 0w-40 cause this problem? my car has 97,000 miles
  9. Member Rockerchick's Avatar
    May 10th, 2005
    Cary, NC
    '03 BMP 20th GTI, '84 TD Jetta
    09-11-2012 08:59 PM #9
    No, your oil isn't going to cause this. Do as its been suggested already and swap your coils around for starters.
    Quote Originally Posted by TM87 View Post
    VW-making mechanics out of owners since 1957.
    The project - '84 Jetta 1.6TD, 186k+, fully rebuilt, Giles IP and injectors, 2.5" custom exhaust, 51mpg
    Hers - '03 BMP 20thAE GTI, 125k, all stock...for now
    His - '01 Jetta TDI, 126k. Now has 3 pedals, as it should!
  10. Member
    May 30th, 2012
    Sacramento, CA
    2004 Jetta GLI
    09-27-2012 06:22 PM #10
    Replaced everything possible on this P.O.S. jetta and still misfiring, when i start the car in the morning it sounds like its choking.. and CEL flashes, after 5 seconds the idle smooths out and CEL stays lit. I replaced coil packs, spark plugs, coil pack harness, crankshaft position sensor. cleaned MAF. idk what else could be wrong. please help im supposed to get rid of this shty VW this weekend and i need to fix it by then.
  11. Member
    Jun 21st, 2010
    Darlington
    09-27-2012 06:37 PM #11
    What happens when you run the car with the airflow sensor unplugged? Better?
    May 30th, 2012
    Sacramento, CA
    2004 Jetta GLI
    09-27-2012 06:42 PM #12
    havent tried, sounds dangerous
  13. Member Rockerchick's Avatar
    May 10th, 2005
    Cary, NC
    09-27-2012 06:44 PM #13
    Its not. Unplug it and see what happens.
  14. Member
    May 30th, 2012
    Sacramento, CA
    2004 Jetta GLI
    09-27-2012 08:18 PM #14
    Quote Originally Posted by Rockerchick View Post
    Idont think it can be a MAF causing my car to startup bad and misfiring..
  15. Member Rockerchick's Avatar
    May 10th, 2005
    Cary, NC
    09-27-2012 09:08 PM #15
    A bad MAF can cause a lot of problems. If you unplug the MAF and nothing changes or it gets better, then the MAF is bad. If it gets worse, MAF is fine. Its a quick, easy test. I'd go ahead and do it.
    You also should try to keep all this stuff to one thread. It gets confusing when you have 2 going at once...
  16. Member
    May 30th, 2012
    Sacramento, CA
    2004 Jetta GLI
    09-28-2012 12:13 AM #16
    what do you mean by it gets better, and if it gets worse maf is fine??
    Sorry its just hard to get people to reply and I really need help asap
  17. Member Rockerchick's Avatar
    May 10th, 2005
    Cary, NC
    09-28-2012 09:46 AM #17
    If you unplug the MAF and the car behaves worse than the MAF isn't your culprit. If nothing changes than your MAF is likely bad.
  18. Member
    May 30th, 2012
    Sacramento, CA
    2004 Jetta GLI
    09-28-2012 11:57 AM #18
    oh okay thanks, also should i unplug it while the car is running, or unplug it and start the car?
  19. 09-28-2012 05:50 PM #19
    Unplug while the car is running and let the car idle
