VWVortex.com - Liqui Moly Oil Forum
    Page 1 of 4 1234 LastLast
    Results 1 to 25 of 78
    Thread: Liqui Moly Oil Forum
    1. Former Advertiser
      Jul 7th, 2012
      Washington Capital area
      2005 Passat W8 6sp Wagon, 2010 Audi RS6 Wagon, 2004 Jetta GLI VR6
      09-11-2012 10:04 PM #1
      Hello Everyone!
      We at LIQUI MOLY are proud to be here interacting with you and helping you in any way we can on matters of lubrication. If it has moving parts it needs lubrication. Even when it doesn't - it still needs it since corrosion protection is one of the main purposes of lubrication. Lubrication is a science - not voodoo. It is measured in microns, milligrams and infinitesimal units - not rabbit ears or dove tails. And it doesn't accept tales - only facts. What your older brother knows about oil - is probably already outdated. The pace of change is fast - and we are here to assist you, to be of service to you. So, give us your questions and your opinions.
      We look forward to hear from all of you.
      Follow us on Facebook at http://www.facebook.com/liquimolyusa.com
      All the best,
      Ludwig
      Sep 12th, 2010
      2008 GLI FSI, 1977 VW Bus, 1967 Karmann Ghia
      09-15-2012 01:56 PM #2
      Loving the oil, just got my analysis back and it looked great!
    3. Former Advertiser
      Jul 7th, 2012
      09-18-2012 11:06 AM #3
      Blake, great show in your Karman Ghia!!! My Dad had this car in the Sixties - and still today he sheds a tear for the memories as soon as he sees one! Please tell me what the oil reads at 7k from the good folks at Blackstone. Now listen - tell me which is the exact oil you got. The Synthoil Premium or the Leichtlauf High Tech? Probably the Premium. If so you got to try the Leichtlauf High Tech, much stronger oil with high SAPS (sulphated ash) which makes it an even stronger lubricant. And don't forget the CERATEC!
      Let me know! Can you send us pictures of your car?
      liquimolyusa@gmail.com
      Also, kindly follow us on Facebook at http://www.facebook.com/liquimolyusa
      My best to you.
      Ludwig
    4. Member
      Sep 12th, 2010
      09-18-2012 04:24 PM #4
      Sadly, the Ghia is sold but I'll try to get some pictures of it pulled up! It was the synthoil premium. I just shot some photo's of the GLI (this is the oil analysis of it), I'll get those emailed right away!
    5. Former Advertiser
      Jul 7th, 2012
      09-18-2012 10:12 PM #5
      Hi Blake,
      You got to try Leichtlauf High Tech and the additive Ceratec. It is the best possible combination for that car. That oil is already substantiallyu fortified with hi SAPS and the Ceratec makes it a super combination. After 10 days of immobility I started my Passat W8 and it was silent from the first turn. No dry beating valves, chains, etc. Silent. Amazing. On the other hand, the wife's Jetta with Castrol (it is still new) screamed for almost 15 seconds...this after we returned from vacation in August.
      I rest my case.Try it.
      And make sure you come to our shows. We will be in Sonoma at the Infineon Race track with the WTCC this weekend, where our team will be coming from Germany. In November we will be at The SEMA Show in Las Vegas, with our booth.
      You are our guest. Come see us.
      Luis
    6. Member
      Mar 6th, 2011
      2011 VW Jetta 2.5L SE w/convenience
      11-05-2012 11:06 AM #6
      Just wanted to congratulate you guys on your next step into the US market with the NV show!
      I use MOS2 in my cars and your 5w40 in my Jetta. Very satisfied with both!
      Keep up the great work.
      Herzlichen Glückwunsch!
      2011 Candy White VW Jetta 2.5L SE w/Convenience
    7. Former Advertiser
      Jul 7th, 2012
      11-12-2012 12:12 AM #7
      Dear Biggs88,
      Vielen danke!!!
      We thank you for those kind words - please be sure we work very hard to deserve them. Next time please try - CERATEC. Micro ceramics beats our trusted MOS 2. You see, MOS 2 comes out with the old oil when you change your oil. You need to replace it with a new bottle with the new oil. Not so with the CERATEC. It stays in your engine for 30,000 miles.
      Please keep us in the loop with your news!
      Best,
      Ludwig.
      Mar 24th, 2012
      Wappingers Falls NY
      2008 Passat 2.0, 2012 Golf TDi 2015 GTI SE
      11-14-2012 05:26 PM #8
      I know nothing about your oil...I've been using Mobil 1 0W40 or 5W40 TDT in my wife's 2007 Passat 2.0. I was about to move to Castrol SLX Professional 5W30 or 5W40. Any thoughts? We also own a 2012 golf TDi.
      The Passat is driven 3 miles to work every day...so it barely if ever warms up in winter. In addition, once my wife leaves our street, she has to merge onto a 55mph highway...abruptyl at times. I cringe! FYI.
    9. Former Advertiser
      Jul 7th, 2012
      11-18-2012 06:17 AM #9
      Michael -
      1- You NEED to know which approval codes your car needs: in the manual or the service dept. at the dealer will tell you. This is crucial as each approval code may require different additive packages in your oil! KNOW the approval required for your car first.
      2- If it is a diesel car = diesel approval, diesel oil, no matter what.
      3- If your car has a DPF (diesel particulate filter) you need a low ash oil. High ash content is best for lubrication but not on new diesels as they have DPF's and high ash will clog your DPF then ruin your converter.
      4- For any gas car, the high ash oil is best as high ash means best lubricity.
      5- No matter what, do not drive that engine cold. Give it at least 3 minutes before going over 2k rpms, seriously. The engine will survive!
      Low ash 5w30 = LIQUI MOLY TOP TEC 4200
      Low ash 5w40 = LIQUI MOLY TOP TEC 4100
      High Ash 5w40 = LIQUI MOLY LEICHTLAUF HIGH TECH
      And for those driving conditions in the cold - please use Ceratec. This microceramic-based friction modifier will do wonders for engines that have to perform in cold conditions!
      Thank you for your interest! Let me know if we can help.
      Ludwig.
    10. Member
      Mar 24th, 2012
      Wappingers Falls NY
      11-18-2012 07:04 PM #10
      Thank you! High ash for the 2.0 Turbo, but I don't see that exact oil on Liqui Moly's website - TopTech MoS2 look the closest...? VW 502 is specified for our 2007 Passat. The 2012 Golf diesel is 507. I will find a dealer in my area, thanks again Ludwig!
    11. Former Advertiser
      Jul 7th, 2012
      11-23-2012 01:24 AM #11
      LIQUI MOLY's high ash oil is called Leightlauf High Tech. Part number for the US market is 3864 for the 5L jug. If you have a gasoline engine - you simply cannot go better. And if you add some Ceratec to that oil - you enter lubrication bliss. I did it.
      Best,
      Ludwig
    12. Member dhenry's Avatar
      Feb 9th, 2009
      Va Beach
      mkv
      11-23-2012 02:12 AM #12
      how is the Leightlauf any better than the synthoil premium. i currently run the 5w40 synthoil premium with ceratec. but i do not think that i have any local dealers. I have a 2009 vw rabbit 2.5l 0A4 transmission. I also need some 75w-90 gl4+ gear oil. would you recommend the mos2 gear additive along with the oil?
      follow me @dominickhenry | 2.5l UM tuned! | SCCA Solo FSP class |Flickr | Build Thread | FS Benz wheels
    13. 11-30-2012 01:58 PM #13
      can i mix two 5w40s i have a bit of top tec and looking at purchasing the synthoil premium
    14. Member
      Feb 6th, 2001
      Coral Springs, FL
      '11 S4, '10 GTI, '03 VR6 GLI
      12-11-2012 03:03 PM #14
      Who can I get Ceratec from?
    15. Former Advertiser
      Jul 7th, 2012
      12-13-2012 02:13 AM #15
      MOS2 for gears - part #2019 is a tube you add to the gears when you are working on it - different than the MOS2 to be added to the engine oil - part # 2009. you can add MOS2 for the engine LM2009 to the engine oil for SUBSTANTIAL friction reduction. HOWEVER -
      1.Never overfill your engine with oil;
      2.Never use it in a setup with a wet clutch (bikes, for instance)
      3.It will leave the engine and need replenishment at each oil change.
      You will most likely experience a gain in mileage of about 1,5 - 3, 5 miles per gallon. Just read the forums. Just go to our Facebook page for the latest posts on the product. Try it yourself and them post your results as well.
      All the best!
    16. Former Advertiser
      Jul 7th, 2012
      12-13-2012 02:21 AM #16
      Both are excellent oils - you can see the posts right here with the actual oil analysis...
      But the Leichtlauf is a much newer oil and not yet widely distributed in the US. Available in fewer outlets.
      It is a HIGH SAPS OIL = sulphated ash, phosphurus and sulphur. This mean highest lubrication additive packages. Not good for the newest diesels as they have particulate filters and this high saps will clogs those filters - but the BEST OIL for gas cars. Thats the type of additive we run at the WTCC LIQUI MOLY TEAM ENGSTLER. And at Daytona 24hrs with our RSR.
      If you can find the Leichtlauf - don't hesitate.
      Best!
    17. Former Advertiser
      Jul 7th, 2012
      12-13-2012 02:32 AM #17
      Just once more - and let me make this absolutely clear - we are all Vdubers here, right? That means me too, and you can believe it - just look at the cars I have, w8, r32 MK4, Jetta VR6 MK4, Audi RS6. The wife has a Jetta 2.5 08. See? What am i telling you all about the oil? Yes - the Synthoil Premium is excellent - BUT THE LEICHTLAUF IS THE STUFF I HAVE IN MY CARS - along with the Ceratec!!!!!
      What does that tell you? Just saying....!And one word for the Ceratec: phenomenal. The absolutely BEST friction modifier for the times - microceramics - hence the name Ceratec.
      Please ask away - it is a pleasure to talk to you.
      You can get it at Bavauto.com , for instance.
      Best!
    18. Member
      Nov 10th, 2010
      mid hudson valley
      2002 jetta 2.0tx, 2003 passatx, 2006 jetta 2.0tx, 2014 tiguan se awd, 2015 gti
      12-13-2012 10:57 AM #18
      Quote Originally Posted by liquimolyusa View Post
      Best!
      let your product stand on its own and forget the bs.
    19. Former Advertiser
      Jul 7th, 2012
      12-13-2012 03:03 PM #19
      We report to you the results from our labs. A opposed to some other companies, we don't make commercials with oil blobs traveling in a toboggan thru the air and thru a makeshift crankshaft to depict quality, Sir. Ready the reports, the oil analysis posted here. BS doesn't live here - it is despised by us.
      Thanks for your participation.
    20. Member
      Nov 10th, 2010
      mid hudson valley
      12-13-2012 06:22 PM #20
      bs is bs, somebody elses lab report is nothing more than that. it's not the car you drive, it's not you driving, etc.. you've got good stuff leave it at that.
    21. Member finklejag's Avatar
      Apr 4th, 2002
      WA
      12-15-2012 11:56 AM #21
      Are you guys getting rid of the Lubro Moly name in the US? Do you know if Napa will start stocking the High Tech 5W-40? They show the High Tech bottle in the photo, but still show the LM2041 Premium part number.
    22. Former Advertiser
      Jul 7th, 2012
      01-10-2013 02:08 PM #22
      It happened two years ago, but sometimes you still have questions about the name change. The name Lubro Moly has been dropped for LIQUI MOLY - which is the name of our company since the beginning. We used the name Lubro Moly in the US for several years but now decided to replace it with the same name as we are known for and use all over the world in the 110 countries our band is present in: LIQUI MOLY.
    23. Semi-n00b AntiMatterMaus's Avatar
      Jan 15th, 2013
      SoCal
      12V GTI VR6
      01-23-2013 05:22 AM #23
      I heard of your brand before, but recently got a chance to get my hands on your products. I've used Injector Cleaner & Engine Flush on my 98 Holf VR6 (120k & counting). After an oil change I've added Engine Saver - VR6 purred like a kitten!! Unfortunately not for long, since my buddy dumped about 1/2 liter of Lucas Oil viscocity modifier into my engine. I never trusted that product, it flows like cold honey! For a couple of days, during start-up and warm-up, it sounded like i have a supercharger on my Dub, then it went away. Now Im wondering if I should change oil again or if I can squeeze some milage out of it Also, which motor oil would you recomend for high milage engine like mine.
      For my transmission I've used LubroMoly 75w-90 G5. Amazing transformation - now it glides into gears with ease (compared to jamming it in there, and ratcheting when downshifting to 1st gear), and noise level is almost non-existent now! Just Magic! Thank You Guys!
    24. Member 2006_A3_2.0T's Avatar
      Jan 11th, 2013
      Chile
      02-01-2013 09:02 AM #24
      Guys, Ive used Liqui Moly Top Tec 4100 5w40 since a year in my 2006 2.0T.
      But just readed that the oil for the gas engine is LAINCHFURMS somethng like that.
      Ive been doing harm to my engine?
      Will the use of Top Tec 4100 will damage the engine in the long term because its designed for diesel engines? Everywhere it says that 4100 is 502.00 rated TIA
    25. Member
      Mar 29th, 2002
      Maryland
      '07 Audi A3 2.0T DSG
      02-04-2013 03:54 PM #25
      liquimolyusa, can a high mileage 2.0T FSI motor benefit from Ceratec? I'm the second owner of a well maintained A3 with 110,000 miles. Am I throwing my money away adding Ceretac with this many miles? Also, the directions read to add it to fresh oil, but I have also heard of some adding it to old oil and running the engine for 5–10 minutes and then changing the oil. Thoughts?
      Brian
