where are u located?
#1
hi there i need to check my timing chains on my R32 and i seem to remember find quite a in depth guide on here for espically the cam pulleys and have to set them up i just of put it in my favourites can anyway link it to me or sugguest another place to look please
#3
the uk, i am having problem with cam 2 throwing a error code 17755, if have doube checked the timing and it looks spot on the car is running a 9.1 spacer plate with a split gasket
#4
Is it the "Cam 2 / Engine speed correlation" error? This means the ECU can't see the exhaust cam. The most common reasons for this are:-
1) The ECU is wrong for the engine
2) Chain stretch has thrown the timing off. Have a look in VCDS measuring blocks 208 and 209. If the KW reading is outside of the -8 to +8 allowable range, there's your problem.
3) The head spacer has effectively done the same thing as chain stretch, so again, the above measuring blocks are your friends.
I believe there's some discussion in the Forced induction thread about spacers throwing the timing. And if I recall, there was talk of either adding or removing 1 link from the cam chain. Or some people in the 12V days used to clock the intermediate shaft round 1/8 turn.
4) The timing is wrong. Did you clock the cam sensor trigger wheels on the VVT housings fully to the right before fitting them to them the cams? This is critical. 16 chain rollers between the arrows on the VVT housings?
#5
kevhayward
that is correct that is the error i am getting
its the correct ecu with a united file on it currently
i have vagcom and i can check i will have a look in the morning
as above
would the intermediate being 180 cause this as i cant see it as the teeth are equal all the way around the sprocket and all the intermediate does is drive the oil pump ?
there is 100% 16 rollers between the chains and the vvt was turned fully clockwise
#7
pulled the engine to triple check the timing marks and all seems to line up :s this is really doing my head in nowlol
#8
