Originally Posted by
MtDew
I can get some pictures on Thursday. The Cabby is unmolested. Not been lowered. About the only thing that's not stock are the window cranks and the muffler! The entire front suspension been replaced, ball jounts, inner and outer tie rods, all new motor mounts. I've been thru most of the fuel system, new injector and new injector seals, new O2 sensor. When replacing the injectors, one of the tips came loose and dropped into the cylinder. So the head was pulled, tip was retrieved, then I rebuilt the head with need gaskets and value guide seals. The motor got a new head gasket, timing belt, water pump and thermostat.
The A/C has been removed, you could source some used parts and reinstall if you so chose.
I'm near Allentown, PA. The Eagles side of PA. My zip is 18944 to give you a general idea where the Cabby sits.
