Results 1 to 10 of 10
Thread: Recommended motor/trans mounts for mk2?
  1. Member TheGreenspanator's Avatar
    Sep 20th, 2005
    Downingtown, PA
    2 57 Bel Airs 65 Corvair 66 SS396 68 Dart 73 Vette 86 Golf 97 GTI 99/04 Neons & a truck
    09-12-2012 10:02 AM #1
    Pretty sure I just destroyed another (stock) trans mount in my 86. Warmed over ABA/JH combo. The car mostly sees track days, a 3 mile commute to my work on nice days, and the occasional autocross, so I'm not TOO concerned about vibration (although I do sometimes drive it to the track rather than trailer).
    I'm just wondering what everyone else is using- I was thinking about the solid front mount, but for the trans mount I wasn't sure if the regular old G60 upgrade (for a whopping $20) would do the trick, or if I should step up to the poly (delrin maybe overkill?) Basically my husband is tired of replacing them () and I'd like something that will improve the performance but more importantly, last for a reasonable amount of time.
    Just an old racecar
  2. Member chois's Avatar
    May 12th, 2000
    Chicagoland
    09-12-2012 12:00 PM #2
    I have been using all stock stuff in my ITB car, and never broke one. Any chance that something is misaligned, or that you are being especially harsh with launches or gear changes? Moving to the stiffer stock mounts (from a diesel?) will reduce the deflection and wear. I would not go solid, even on my race car. It is beneficial to isolate drive train vibration from the rest of the chassis, to keep things from vibrating loose, and limit fatigue loading of mounting points.
    Recent rules changes have me looking at making something lighter an stiffer, but there is a lot in front of that item on the list.
    Chris
    2007 GTI 16v, 4 door, 6sp (well really that one is Brandy's)
    2004.5 Passat Wagon 20v, 1.8t, 4mo, 5sp
    1986 GTI 8v road racer - DIYAutoTune.com
  3. Member TheGreenspanator's Avatar
    Sep 20th, 2005
    Downingtown, PA
    09-12-2012 01:15 PM #3
    I don't know, I'm not a hamfist or anything This one has 3 track events and 2 autocrosses on it; the one before lasted a couple years of autocross. I've just been led to believe they are a weak point that don't stand up to much abuse, and if I toasted this one already, I thought the poly might be a good upgrade.. Just wanted to see what other people were doing before spending money on the "wrong" things.
    Just an old racecar
  4. Member flyinglizard's Avatar
    Aug 6th, 2006
    Spring Hill, FL. USA
    FSP. ITB,wide body,Chumpcar
    09-12-2012 01:25 PM #4
    I use the horizontal bolt ,style of front mount, not the pancake style. Also , you can not use one solid mount, it will break as the others keep moving. All plastic works fine, but wil wear out in a year or two.
    I add a tie chain under the mount to the starter bolt, from the cross member. You can also /or push a long bolt through the holes in the rubber. Long enough to torque the metal parts of the mount when it moves too far.
    Mike and Michael Ogren, Protech Racing,25 yrs of Racing VWs. mogren@tampabay.rr.com, 352.428/8983 "Home of the world famous Turbo Jett"
    www.fwdracingguide.com
    Money back guarantee!, You can go100$ faster with this 20$ guide to all racing VWs, and oval track/Road race/Chumpcar/ FWD cars.
  5. Member TheGreenspanator's Avatar
    Sep 20th, 2005
    Downingtown, PA
    09-14-2012 08:51 AM #5
    OK, one more potentially stupid question - my car is a 1986, so it has the early hydro front mount. I've now found poly or heavier duty mounts for the rear and trans, but is there anything better non-solid I can replace the front with?
    Just an old racecar
  6. Member chois's Avatar
    May 12th, 2000
    Chicagoland
    09-14-2012 09:26 AM #6
    If your car is a 1986 it came with the "spool" style front mount with a horizontal bolt through it that Mike referenced above. A lot of folks downgraded to the later part though.
    I suggest doing some looking around at aftermarket front mounts that are firm, but not solid, and looking for diesel rear mounts. I have also heard that the G60 trans mounts are beefier, but do not know that for sure.
    I have never seen that trans mount fail personally...
    Chris
  7. Member flyinglizard's Avatar
    Aug 6th, 2006
    09-14-2012 01:05 PM #7
    The front mounts fail enough to bother you.
    The side mounts can fail and allow the engine to move laterally, breaking axles. I also stuff the pass side mount, for the race cars, so that it moves less.
  8. Member CHETVW007's Avatar
    Jul 25th, 2001
    Carlisle PA
    2002 Eurovan, 1992 Jetta GLi 16V
    09-15-2012 11:30 PM #8
    I use a solid stock rear mount. A g60 tranny mount. And a powerflex insert in an early style front mount...but the best upgrade was the Poweflex front subframe inserts. Its a great setup And has seen many track days.
    WTB Tornado Red Mk2 Jetta rear pass door
    WTB WTB: 16v 268 or higher exhaust cam only.
  9. Member TheGreenspanator's Avatar
    Sep 20th, 2005
    Downingtown, PA
    09-26-2012 07:38 PM #9
    OK, wasn't the trans mount but the front. I have the early-style bonded cylinder one, and it's moving like the rubber is torn- where the hell do you guys find replacement inserts/mounts/anything for the early ones? All I can find, either OEM-style or aftermarket, is the later version Trying to get this done for Pocono next week.
    Just an old racecar
  10. Member flyinglizard's Avatar
    Aug 6th, 2006
    09-26-2012 08:50 PM #10
    Push a long bolt through the mount so that it contacts the metal as it moves.
    Than run a short chain from the starter bolt to the lower crossmember bolt.
    Than ,buy my book.
    MM
