VWVortex.com - "While it's opened up...."
    Page 1 of 3 123 LastLast
    Results 1 to 25 of 64
    Thread: "While it's opened up...."
    1. Member GeoffD's Avatar
      Aug 13th, 2001
      15 Outback 3.6R
      09-12-2012 11:01 AM #1
      My bathroom remodel was done other than installing the skylight. Before that could be done, I needed to replace the roof since it was about 15 years into a 20 year life cycle. That project just kicked off. Everything that gets touched ends up being yet another project. After the asphalt shingles were stripped, the boards underneath were a mess so those are being replaced with plywood. Once the boards came off, some dubious rafters need some attention.
      ...all to install a skylight.
    2. Member GeoffD's Avatar
      Aug 13th, 2001
      15 Outback 3.6R
      09-12-2012 01:09 PM #2
      My bathroom brightened up a lot!
    3. Member robr2's Avatar
      May 5th, 2005
      Boston
      2015 Passat "Limited Edition"
      09-12-2012 01:43 PM #3
      Every project is like that - think "If You Give a Mouse a Cookie."
      Remember the 3 most dangerous words in home renovation is "While you're here..."
    4. Senior Member abeR's Avatar
      Sep 13th, 2002
      Joe's Garage / Deals Gap
      gorf
      09-12-2012 04:48 PM #4
      looks great
    5. Member barry2952's Avatar
      Jun 13th, 2007
      Farmington Hills, MI
      09-12-2012 06:12 PM #5
      Nice space. Great use of light. We had skylights in our last house that would frost up from the humidity from kitchen use. How are you going to vent that space. We just ran our fan a lot.
    6. Member GeoffD's Avatar
      Aug 13th, 2001
      15 Outback 3.6R
      09-12-2012 10:40 PM #6
      There is a 100 CFM bathroom fan on a timer about a foot from the skylight. The bathroom has its own radiant heat loop in the floor and I plan to keep it a little warmer than the rest of the house. That should create some convective air flow. It's a pocket door so it's normally all the way open. The skylight is also low E argon-filled so it's hopefully a little less prone to collecting frost.
    7. Geriatric Member spockcat's Avatar
      Jun 4th, 2003
      West Coast, not that west coast. Bay area, not that bay area.
      11 328i Touring, 16 Colorado Crew, Versys, 2017 Barracuda
      09-12-2012 11:17 PM #7
      Have you checked the foundation?
      Touareg Audio Accessories - Keyless Start - Paddle Shift
      If you use Tapatalk, you aren't seeing the whole message. Tapatalk shortens GIFs, cuts URLs and deletes signatures.
    8. Member Sizzla's Avatar
      Nov 10th, 2005
      Hutto, TX
      '03 VW Jetta GLS; '08 GSX-R 750; '13 F150
      09-13-2012 05:14 AM #8
      Looks good! Enjoy!!
    9. Senior Member Mk1Racer's Avatar
      Apr 16th, 1999
      NJ
      '01 B5.5 wagon, '81 Scirocco, '04 FXDWG and too many A1,2, & 3 cars to remember. '93 Miata for S&G
      09-13-2012 08:35 AM #9
      Geoff,
      That's a familiar story I tell pretty much all of my clients when we are discussing remodeling projects. It's impossible to know what's going on in there until you open it up. Could require some significant repair work. Gotta say though, your bathroom came out great.
    10. Member GeoffD's Avatar
      Aug 13th, 2001
      15 Outback 3.6R
      09-13-2012 11:53 AM #10
      Quote Originally Posted by Mk1Racer View Post
      Geoff,
      Yeah, well... Serves me right for buying a chicken coop and then opting to pay to have it remodeled in stages rather than tearing it down and starting from scratch.
      This section of roof is now just about ready for paper. The back of the house is getting the same treatment. The master bedroom was an addition and has 2x4 rafters. Those are being replaced by 2x8s in anticipation of vaulting the bedroom ceiling this winter as the last major interior project.
      The skylight still needs to be trimmed inside but it's installed.
    11. Member barry2952's Avatar
      Jun 13th, 2007
      09-13-2012 11:59 AM #11
      Couldn't see the fan in the other fixture. The fan in our most-used bathroom is on a line-voltage humidistat with a single-pole switch as a bypass. The hard part is remembering to turn off the bypass.
      Didn't you just put a cedar roof on this place?
    12. Member GeoffD's Avatar
      Aug 13th, 2001
      15 Outback 3.6R
      09-13-2012 12:04 PM #12
      I'm just one person. A timer on the bathroom vent fan is fine. I run the A/C 24x7 in the summer so I don't have a humidity problem. Next spring after I'm done remodeling inside, I'm adding a couple more mini split wall units off a 2nd heat pump for the bedrooms so it will be even less humid.
      My sister has a humidistat in her bathrooms in Vancouver, B.C. but that's a temperate rain forest with mild weather so no A/C in the summer and not much heat in the winter during the rainy season. I don't think I need one. The shower stall is dry after an hour with the fan running.
      No. I had the front re-sided and a new roof installed just on the front of the house. I'm using GAF lifetime GrandSlate Bristol Gray. That part of the roof was intact so it was just 1/2" plywood over the existing roof boards.
      You can't use cedar on the roof any more. It doesn't meet the building code. In my town, you also have to use 30 year shingles or better. This roof should out-live me other than the 10x10 flat roof part where I'm using a 20 year rubber roof. The alternatives would require a seam and I'd rather start with a 20' roll and cut it down to fit with no seams.
      Here's a Memorial Day photo. Other than the Hydrangeas and Impatiens much bigger in front and the roses in full bloom, it looks the same now other than some crabgrass problems.
    13. Member Tornado2dr's Avatar
      Mar 31st, 2001
      Split Pants, VA
      09-13-2012 12:22 PM #13
      Quote Originally Posted by GeoffD View Post
      I'm only in here to give you **** about building a new house out of an old house, all the while telling us how your last house was a nightmare of constant project management - and smaller houses are better.
      Sky-light looks great. Natural light is always the most pleasant in any room.
      ps-does it open?
      Quote Originally Posted by Turbio!
      They make my ass look pretty.
    14. Member GeoffD's Avatar
      Aug 13th, 2001
      15 Outback 3.6R
      09-13-2012 12:54 PM #14
      ps-does it open?
      The difference in this house is that I'm mostly not living in it during the remodeling. It will also be 100% done inside by next spring. A 100+ year old house that is 4x larger is never ending.
      The skylight opens. The manual crank is at about 7' 8". I can (barely) reach it to crank it open. The Velux kit didn't come with the crank to open it for non-6 footers. Need to order one of those.
    15. Member Tornado2dr's Avatar
      Mar 31st, 2001
      Split Pants, VA
      09-13-2012 01:10 PM #15
      That's gotta be nice in spring and fall - should help get rid of moisture quickly, too.
    16. Member robr2's Avatar
      May 5th, 2005
      Boston
      09-13-2012 02:26 PM #16
      Spend an extra $100 and have them ice and water shield the entire roof instead of just the first 36".
    17. Member barry2952's Avatar
      Jun 13th, 2007
      09-13-2012 02:33 PM #17
      Quote Originally Posted by robr2 View Post
      I'd agree with that.
    18. Member GeoffD's Avatar
      Aug 13th, 2001
      15 Outback 3.6R
      09-13-2012 03:36 PM #18
      I'm very close to salt water, I have excellent insulation in the attic, and very good ventilation with button vents in the soffits every 12", 3 gable end vents, and a ridge vent. Here, the snow doesn't last on roofs long enough to get ice dam problems even if you have a hot roof. It's unnecessary on my roof.
      Edited:
      Besides, too late now
    19. Member robr2's Avatar
      May 5th, 2005
      Boston
      09-13-2012 09:38 PM #19
      So they used Tri-flex and felt paper?? I'm not an expert but the former is used in place of the latter.
      i presume they will be ice and water shielding the first 3'? It's code here in MA.
    20. Member GeoffD's Avatar
      Aug 13th, 2001
      15 Outback 3.6R
      09-13-2012 10:34 PM #20
      That's 36" of ice & water shield with Tri-Flex overlapping it by about 12". Tri-Flex is UV-resistant polypropylene.
      I had a problem getting the shingles I'd ordered last winter. The regional distributor was having a spat with GAF and late-November orders didn't get filled until February. My front section of roof sat exposed for 3+ months like that with no leaks. Not exactly what I wanted but no harm done. Things have certainly changed from the old tar paper days.
    21. Member robr2's Avatar
      May 5th, 2005
      Boston
      09-14-2012 02:14 PM #21
      Got it. I'm familiar with the Tri-Flex. It's perfect when they don't expect to get the roof done soon.
      As for the ice and water shield, I didn't see any writing on it so it looked like tar paper to me.
    22. Member VW KEVIN G's Avatar
      Oct 26th, 2000
      Willoughby Hills, OH
      1993 Corrado, 2006 2.0t Audi A3, 2008 3.2l Audi TT Roadster
      09-15-2012 01:25 PM #22
      That looks to be a great looking bathroom.
    23. Geriatric Member firefighterjunkie's Avatar
      Mar 26th, 2004
      PNW, Washington State
      '04 GTI and '03 Passat Wagon
      09-15-2012 03:18 PM #23
      That looks great!
    24. Member GeoffD's Avatar
      Aug 13th, 2001
      15 Outback 3.6R
      09-17-2012 10:58 AM #24
      The side is almost done. The last of the shingling will get done eventually.
      Today's project is to repair the hack carpentry in the back where they tacked the master bedroom wing onto a hip roof. Replace the ridge board with a 2x10, replace all the 2x4 rafters with 2x8s. Hack out the hip roof buried in the attic and install a few collar ties.
    25. Member Tornado2dr's Avatar
      Mar 31st, 2001
      Split Pants, VA
      09-17-2012 11:41 AM #25
      I'm thinking that the shingling running up that second roofline (where the horizontal seams turn vertical) is going to be overlapped by the next stage of shingles? Otherwise I am getting turned around.
