Time for a new head unit
#1
Is there anyway you can put in an aux cord to play the ipod etc without buying some sort of kit? I am tired of using the cassette to ipod adapter as my cassette player is out of alignment or something.
#3
Short answer, no.
Kits are available fairly cheap. They plug in where the usual 6 disk CD changer would plug in on the back of the head unit. Some even charge iPods.
#4
I have a Kenwood unit that replaced stock that has a CD player and AUX port, cost around 80 bucks and it just snaps in.![]()
#5
Can you get a kit that will still allow you to change the songs on the ipod itself though? The ones I saw you have to control it through the cd thing
#7
I spent $450 on a double din headunit (I care way too much about SQ). But you could easily buy a single din HU for under $100 that sounds decent.
vAnd nowadays aux is pretty much a standard. Mine has a USB port and all that jazz too.
~TheGreatCatTakeover2012~Dat build thread doe~Lace up~
Forge 007, GHL 3" TB, EuroJet TIP, drive/pass Raxles, ECS Hybrid Oil pan, Samco coolant hoses, P-flo SRI, VR6 Lightweight single mass clutch, Ultimo's, etc.
#8
I ended up disassembling the whole headunit to find some conveniently labeled points where I could solder a 20ft headphone cord and extend it all the way under the center console and up into the armrest. Not sure if this applies to all headunits, I just had the standard unit from a 2001 GLS.
#9
Yes there is a way to do it
Buy this from ebay:
http://www.ebay.com/itm/3-5MM-AUX-IN...item53e2618eb1
or this one:
http://www.ebay.com/itm/VOLKSWAGEN-V...item5d2ea129da
Pull the radio and replace the cd changer plug with the one in the picture above.
Route the cable however you want to.
I chose to get one of these (3.5mm bulkhead female-to-female adapters and run that 3.5mm plug into the back and have a shorter cable plug in and out of the front)and mount to mount it on my dash somewhere but never got around to it:
http://www.made-in-china.com/showroo...d-Adaptor.html
I also got myself a panavise dash mount and iPod/iPhone holder:
http://www.panavise.com/pdf_indash/75138-404.pdf
http://www.panavise.com/index.html?p...qskudatarq=172
#10
go to walmart and buy a casset tape with a aux cord on it, i used that for 2 years had no problems
#11
#13
on mine the tape aux. only plays on passenger and rear passenger door
#14
I have a USA-Spec. I select playlists from my iPod and can change songs from the headunit. It can also be set up to act like a CD changer where you have 5 or 6 playlists you can select as if they were CD's in your CD changer. It's kinda pricey though.
#16
I'm not a big fan of aftermarket head units. After 16 years of big stereos I found that I usually just ended up with a broken window and no radio. After losing thousands of dollars in stereo equipment I started sticking with OEM. I do want a Kenwood touch screen navi unit though.![]()
#17
#18
The cassette thing works it just doesn't sound right unless you pull the cord coming out of it a little bit...if I could fix the cassette deck I would love to just use that....That one from ebay looks good! Maybe I will have to try that!
#20
