I do. Just assumed it was standard nvh.
Hi All,
Since I purchased 2012 Routan SE 2 weeks ago, when I start the engine I feel little vibration under my foot and it will linger around 2-4 mins and once the engine warms up I don't feel it anymore. Do I need to worry about this? Or mention this to dealer?
Are you in Econ mode? I'd get it check while under warranty.
I had something similar under acceleration and they replaced my valve body in my transmission.
2011 Calla Lily White Volkswagen Routan SEL Premium
No, I was not in Econ Mode. I will mention when I go to next service. Also, the number of replies made me think that it is not normal to feel the vibration as most of the folks didn't mention in this forum.
So the vibration during idle is driving me nuts. Last Friday I took it to the dealer and they said "my van was road tested by an experienced VW Routan Mechanic and it seems it is normal" I also asked them to look into acting up transmission and right side pull. They said "didn't find any issues with Transmission, checked fluid and reset the transmission to factory default (I don't know what this means). Also said, alignment is good and etc"
Thanks guys!!
1958 VW Ragtop Bug
2005 VW Passat Wagon
2010 VW Routan SEL
Be sure to check out the Original Routan Dead Pedal Click Here
Mine doesn't have climatic control and I usually switch off all fans (rear and front) and so the system is not working. I will double check again.
Yes, no vibration after warm up.
