VWVortex.com - Anyone with some Windows XP knowledge to lend a hand?
    Results 1 to 16 of 16
    Thread: Anyone with some Windows XP knowledge to lend a hand?
    1. 09-15-2012 08:52 PM #1
      So today I took a barebones PC and installed Windows XP w/ Service Pack 3 DVD on it (the SP3 is part of the installation.)
      So far so good except for one problem: The internet does not work.
      Previously this PC used various versions of Ubuntu, Lubuntu, and Linux Puppy - all of them had no issues getting on the Internet.
      I've gone online and searched for all possible resolutions to this issue.
      First, I tried resetting Winsock - this did not work.
      Next, I tried uninstalling the Service Pack 3 updates. Unfortunately there is no entry for uninstalling them likely because it was embedded during the installation process.
      Has anyone run into this situation before? The box connects directly to a router and requires no user id/password and like I've said, several other versions of Linux had no issues with connecting straight after installation.
      Another oddity surfaced also - which is probably not affecting this - but I noticed that Windows decided to reformat / relabel the C:\ drive as the I:\ drive now for whatever reason. Anyway of changing this back to C:\?
      The only other thing I can think of is going to Fry's and purchasing a wireless adapter and see if I can connect that way. I'd really hate to do if a direct connection is already available.
    2. Moderator DanG's Avatar
      Nov 16th, 2000
      Winnipeg
      2014 Wrangler
      09-16-2012 12:43 AM #2
      Obvious question you didn't mention anything about, did you load the drivers for the network card? They're not build into windows.
      Does the computer get an IP address? Can you ping the gateway? If you log into the router, do you see the MAC in the DHCP table?
    3. Member georgekelp's Avatar
      Aug 15th, 2005
      Arizona
      09-16-2012 07:09 AM #3
      You didn't mention, but do you have other computers that are able to get on the internet via the router? Have you tried bypassing the router and going directly to the modem?
      It was mentioned above, but make sure the drivers are correct. Even if device manager says there are no problems, it may have used the incorrect drivers for the install. Try going to the motherboard or NIC manufacturer's website (whichever the LAN port is on) to get the latest network drivers.
      As far as changing the letter of the root drive, it isn't possible without a reinstall. That being said though, since you did just install, it might not take too much of your time to reinstall and make sure it installs as C.
    4. 09-16-2012 09:11 PM #4
      Quote Originally Posted by DanG View Post
      I did not load the drivers because I couldn't find them - the PC is ancient. I figured that since three different distributions of Linux could figure the network card out so could Windows. I could not ping anything.
      Quote Originally Posted by georgekelp View Post
      I couldn't find the drivers. This is a fairly old PC (512MB maximum allowed memory)...
      After 3 hours messing around with it I stopped by my local Fry's and picked up a $10 Wifi USB card and that worked just fine.
      One thing is for sure: I am not alone. There are a lot of users with the same problems with the XP distribution that includes Service Pack 3 on the same DVD.
    5. Geriatric Member BRealistic's Avatar
      Dec 16th, 2005
      East-10EC
      88 F150, 04 RX8, 96 T&C LXi
      09-16-2012 10:17 PM #5
      Quote Originally Posted by dirtyfingers View Post
      Good gravyville.
      Pentium III?
      What are you using this beast for?
      Just an email machine?
      "Sometimes, I have a sudden urge to fart on this chair."
    6. 09-16-2012 10:31 PM #6
      Good gravyville.
      Pentium III?
      It's one of the first Pentium 4's; this particular configuration seems pretty rare for the strict memory limitation. This was probably used to encourage people to upgrade to the next more expensive model.
      My dad uses it for paying bills, playing solitaire - and when my mom isn't looking - looking at porn.
    7. Geriatric Member BRealistic's Avatar
      Dec 16th, 2005
      East-10EC
      09-16-2012 11:18 PM #7
      What was it rocking originally- Windows 98 or Windows 2000?
      Gateway?
    8. Member NOTORIOUS VR's Avatar
      Sep 24th, 2002
      Toronto
      D3 A8 4.2 - E36 Turbo
      09-17-2012 10:31 AM #8
      That's your problem.
      SCHNELL ENGINEERING · BLOG · STANDALONE ECUS · TUNING · DYNO · WIRING · PARTS · VEMS
    9. Moderator DanG's Avatar
      Nov 16th, 2000
      Winnipeg
      2014 Wrangler
      09-17-2012 10:35 AM #9
      Linux may have had a generic built in driver that will work with pretty much any network card. Windows does as well, but may just not have the right one.
      Right click on my computer and go into device manager. Under network adapters, does the network card show up in it, or is it a yellow exclamation or question mark for unknown device?
      What brand of PC, or network card is it?
    10. Member mdhemphill's Avatar
      Oct 24th, 2000
      Long Beach, California
      2000/ VW/ Jetta 2.0
      09-28-2012 12:06 AM #10
      You also need to install the drivers for the motherboard
    11. 10-01-2012 11:53 PM #11
      yeah, i think so ,Linux may have had a generic built in driver that will work with pretty much any network card. Windows does as well, but may just not have the right one.
    12. Member WD-40's Avatar
      Oct 8th, 2005
      Midwest USA
      10-02-2012 03:39 AM #12
      Did you remove all of the Linux partitions before installing Windows?
      If not, Windows might have installed over just one of the existing partitions, leaving others on the disk wasting space (unless you have it set up to dual-boot)...
    13. Senior Member F1_Fan's Avatar
      Apr 16th, 2001
      Canada
      10-08-2012 06:58 PM #13
      Quote Originally Posted by stevenjoywell View Post
      Oh good... all is normal here. I don't visit this forum for a few months and when I do, I see the Indian/Asian tech support crew is still active.
      There's always money in the banana stand.
    14. 10-08-2012 08:38 PM #14
      This seems like L1 tech stuff. If it's some knockoff brand hardware and you didn't install the drivers yourself, it's probably not going to work.
      Buy Intel next time. I wouldn't expect Microsoft to slipstream drivers in XP for the no-name Huayang-Chuyang chipset your mobo has.
      edit- I sound like a d-bag in my post, and I apologize. MS has a finite amount of financial and human resources and they're not going to devote those to providing built-in support for hardware with a tiny user base.
    15. Geriatric Member Hostile's Avatar
      Nov 18th, 2001
      Near Rabbit5GTI
      '15 STI & '16 R
      10-09-2012 07:04 AM #15
      Edit- nevermind
    16. Member x047x's Avatar
      Mar 16th, 2004
      Pittsburgh
      MKVII GTI
      10-25-2012 11:30 AM #16
      is picking up a cheap NIC an option?
      Something like: http://www.newegg.com/Product/Produc...82E16833156107
      eBay even has stuff for like $5
