Results 1 to 8 of 8
Thread: Diesel-ly noise - help!
  1. 09-17-2012 04:59 PM #1
    Car is running fine, gets normal mpg, has normal power, no CEL, but it sounds a little dieselly - grumbly. Car has 86k, original injectors, recent spark plug change, recent air filter change, just changed the oil.
    Dirty injector? Something else?
    Thanks.
  2. Member scotts13's Avatar
    Feb 15th, 2007
    Lehigh County, Pa.
    2004 GLS 1.8T
    09-17-2012 07:48 PM #2
    People describing their cars as "sounding like a diesel" generally have one of two problems - if it's a clatter from the rear of the head, it's a cam chain tensioner. If it's more of a rumble, it's an exhaust leak, usually from a torn flex joint.
  3. 09-18-2012 01:09 PM #3
    It's not a mechanical sound - more like an exhaust sound. I'll look at the flex pipe tonight.
    How difficult it is to replace the flex pipe?
  4. Member scotts13's Avatar
    Feb 15th, 2007
    Lehigh County, Pa.
    2004 GLS 1.8T
    09-18-2012 02:30 PM #4
    Two ways to approach flex pipe repair. The "official" VW way is to replace the entire segment of the exhaust that contains it (it's welded in). Cost and details vary depending on the car, but non-trivial. The smart way is to have an exhaust shop cut it out, and weld in a generic ($30-$40) part, Total job is usually under $200.
  5. 09-18-2012 04:10 PM #5
    Germanautoparts.com has the pipe listed at $116.95. It's a 1.8T Automatic, 2WD. What needs to be removed to replace the pipe?
  6. 09-19-2012 11:47 AM #6
    Could it be noise from an accessory bearing? It doesn't sound like an exhaust noise, more a grumbly light vibration.
  7. Junior Member
    Sep 21st, 2011
    2002 Passat 1.8t, 5 speed, Wagon
    09-23-2012 02:33 PM #7
    I had a similar noise. I thought it was the tensioner for the accessory belt, but it turned out to be the skidplate had shifted or warped enough to intermittently rub against the belt. Freaked me out but it was a quick fix.
  8. 10-03-2012 06:26 PM #8
    It was an air leak where the air hose left the filter box. It was causing a rough idle. Smooth now.
