VWVortex.com - 1993 eurovan clutch question
    Results 1 to 2 of 2
    Thread: 1993 eurovan clutch question
    1. n00b
      Aug 10th, 2012
      Huntsville, AL
      1993 Volksvagen Eurovan GL Rauchblau
      09-18-2012 12:51 AM #1
      My eurovan has seen better days as the past weeks have just been problems after problems. So i am on my way to work sitting at the red light and the clutch pedal can be pushed down but it feels like its 'loose' and i can not engage any gears it stays in neutral only. Luckily not too far from home so I turned the damn thing off, put it in second gear and started it to drive it home lol. While pressing the clutch pedal down starting the ignition in second gear, it started jerking and driving like it would in gear. What should I look for? Just had a new clutch put in 25.000 miles ago...
    2. 09-18-2012 02:17 AM #2
      Failure of one of the hydraulic cylinders or clutch cable (although the system is largely hydraulic, I believe there is a short length of cable IIRC used somewhere in the whole thing).
