That does indeed look like the pad wear sensor and ABS sensor wire on the left. It should go through the top of the wheel well just below the tie rod. Gonna be fun getting that back through with the dash in placeYou might be able to poke a piece of stiff wire through from the wheel well side. I wonder ff someone changed or removed the strut previously and just chopped the wires instead of popping the grommet out and unplugging them?
Not entirely sure what the other one is - it looks like an early ABS sensor connector but that doesn't belong in a C5...![]()
