Results 1 to 10 of 10
Thread: input needed please 91 Gli project
  1. Member 98AudiboyA4's Avatar
    Jan 23rd, 2007
    East Hartford CT / Cranston RI
    03 Audi A4 18TQ, 06 Yamaha R6 Raven, 91 Jetta Gli
    09-18-2012 06:11 PM #1
    picked up a 91 gli cheap due to it having a blown head gasket under $300 and was going to go about fixing it but, a friend of mine had a 1.8l 16v sitting in his garage from a previous project. the only thing he didn't have was the computer which i assume was different then the one in my 2.0? i'd like to use his engine as it has aftermarket cams and also the pulley. what other then a computer for a 1.8l would i need? the engine he has is complete and came out of his 88 gti!
  2. Member leon whalen's Avatar
    May 27th, 2007
    truro n.s.
    94 gti aba16v stroker
    09-18-2012 06:41 PM #2
    buy a head gasket. put his 1.8 head with cams on your 2.0 bottom end....... job done. best of both worlds
  3. Senior Member PowerDubs's Avatar
    Jul 22nd, 2001
    NWNJ
    09-18-2012 10:40 PM #3
    Yea... What he said.
    - Josh
    -Josh
    444hp/413tq - bone stock, all motor, Volkswagen.
  4. Member
    Nov 26th, 2000
    New Jersey
    A2 GTI,B5A4,B6A4, 2.7t
    09-18-2012 10:55 PM #4
    Yup, what they all said.
  5. Member 98AudiboyA4's Avatar
    Jan 23rd, 2007
    09-19-2012 12:09 PM #5
    Ok sounds good. Thanks guys for the input it has been a great help in me getting the wheels turning so to speak!
  6. Member
    Apr 16th, 2006
    Brokelyn, NY
    90 fox, 85 gli
    09-21-2012 03:26 AM #6
    nice buy!
    I really suck at smog.
  7. Member justinhannoldVW's Avatar
    Jul 27th, 2009
    HBG
    89'Helio jetta"now" 87' Toyota 4x4 22r"now",91'jetta,gone,00'passat,gone,'90 jetta,gone
    09-29-2012 04:38 AM #7
    I did about the same swap before...1.8 motor swap to a 2.0 motor. Look at both motors take pics, and check sensor for sensor and if all is good then you can jst swap it. No need to remove heads. I think there were only a couple different sensors like 3 in different places or "not there" and i had to add them, from original 1.8
  8. Member leon whalen's Avatar
    May 27th, 2007
    truro n.s.
    09-29-2012 04:37 PM #8
    Quote Originally Posted by justinhannoldVW View Post
    you definitely want to use the 1.8 head. it is about 10 extra horsepower on the 2.0 bottom end.
  9. Member 98AudiboyA4's Avatar
    Jan 23rd, 2007
    09-30-2012 04:31 PM #9
    thanks all for the help thus far it helped greatly, i haven't started to mess with the engine tasks to much as i am rebuilding the whole car more or less and started in the interior and also on the exterior. i had a friend who claims to know a lot tell me that i should "get the bottom end of the 2.0 machined due to the fact that the head gasket blew and could've done harm to the bottom end" any input on this matter would be great since i plan to tackle the engine in two weeks on my vacation
  10. Member leon whalen's Avatar
    May 27th, 2007
    truro n.s.
    10-01-2012 06:14 PM #10
    Quote Originally Posted by 98AudiboyA4 View Post
    with a bad head gasket it is more likely the head would warp because it is aluminium, but having a machine shop check the top of the block should not cost much $$. just to be safe.
