VWVortex.com - VR6 Hard Reverse Gear Selection 5spd ~ Input?
    Results 1 to 17 of 17
    Thread: VR6 Hard Reverse Gear Selection 5spd ~ Input?
    1. 09-19-2012 01:04 AM #1
      I am having issues with a VR6 5 speed manual reverse gear. It is very hard to select reverse gear in any case. When I manually select reverse at the transmission with the engine off, you really have to force down on the selector linkage HARD and then turn to find it. In the car, you have to shove left HARD after pushing down to get reverse, and 4 out of 5 times you get first gear.
      So far I have:
      Checked the dumb plastic shift cable retainer piece, it's good
      Adjusted the cables
      Replaced the shifter box/cables, original had worn bushings/play
      Drained and filled with new synthetic 75W90 GL4
      I am out of ideas here. I'm not sure what to do next. Have you heard of this issue before with the 02A?
      Reverse gear selector fork issue? If so, how could this have happened?
      Thanks in advance
      http://www.ebay.com/itm/VW-VR6-02A-T...-/290225729512
      PVW 5/11 Held It Down
      mk2 1.8t ~ mk3 vr6t ~ mk3 vr6 ~ 7p5 3.6exec
    2. Member Peetah05's Avatar
      Apr 8th, 2007
      Denver, CO
      09-19-2012 03:41 AM #2
      This happened to me the other day actually. Was trying to back out of my spot and took a good 6-7 tries before I got it in reverse and not 1st. I was pressing/pushing pretty hard too.
    3. 09-19-2012 07:42 PM #3
      Yeah most times its the plastic piece or adjustment. Not my case..
    4. 09-20-2012 02:30 PM #4
      Lone ranger
    5. 09-22-2012 12:50 PM #5
      ttt
    6. Member
      Sep 11th, 2011
      Naples, FL
      98 Gti Vr6
      09-22-2012 03:48 PM #6
      I had the same problem. It came to the point that I had to slam it into reverse while releasing the clutch... Then the plastic "Actuator Arm" Part # 1J0 711 256 cracked so it was still functional but i couldnt see the crack because it was on the lower end on the backside of the part.
      I replaced the part with my concauction of a temporary replacement and it works fine.
      Sep 11th, 2011
      Naples, FL
      98 Gti Vr6
      09-22-2012 03:48 PM #7
      I ordered this thought through gruvenparts
    8. 09-22-2012 10:20 PM #8
      Hey thanks for the input. I did replace that part already. I am at a loss.
    9. 09-24-2012 11:34 PM #9
      ttt
    10. Member
      Sep 3rd, 2011
      Milwaukee, WI
      1996 Jetta GLX VR6
      09-25-2012 07:48 PM #10
      Bleed the clutch?
      I have to imagine it is in the clutch or the trans itself if you've replaced all the cables and the box.
      Edit: I guess the clutch cant really be an issue if the problem is happening with the engine off...
      I would guess internal
      Quote Originally Posted by X37 View Post
      I'm drunk and your thread annoys me.
      Quote Originally Posted by swirvtheman View Post
      And then when im on the on ramp to the highway I punch it and wind out 3rd gear and hear that intake and the exhaust together in perfect harmony as it rips a humongous hole in the ozone layer and causes the spontaneous explosions of tree huggers faces.
    11. 09-26-2012 08:03 PM #11
      Yeah, it is weird. This car is 15 years old, I can't be the first to have this issue.
      Jan 28th, 2010
      Ft. Lauderdale FL
      95 GTI VR
      09-29-2012 04:17 PM #12
      This has always happened to me. I just go into second gear then to reverse. If i dont it's impossible to get into reverse.
      7
    13. 09-30-2012 02:49 PM #13
      Thanks
    14. 10-07-2012 10:29 PM #14
      ttt
    15. Member eurotrash_pd's Avatar
      May 30th, 2002
      Moose Jaw, SK
      1998 Volkswagen Jetta GLX VR6
      10-08-2012 06:20 AM #15
      Had this issue once. Pulled up on the clutch pedal with my hands and it kinda reset the cable. No more grind..
    16. 10-08-2012 09:53 PM #16
      Its a VR6. No clutch cable.
    17. 10-08-2012 11:19 PM #17
      I just want to say that, whenever I CAN, on the flat, and I can see all around me, I push my car backward. Saves reverse I like to think just that much longer.
      Did you change the 3 bushings for the bracket on transmission that holds cables? Did you replace the bushings at the cable to shift box hold point? Also did you re-tighten these well? A new bushing there is not included in the shifter box kits that I have seen. Those 5 bushings are your problem. I changed my shift box bushings, but nothing else. Still feels like crap captain, so I'm in the same boat as you. I have the draft42 bracket bushings, but still trying to find the bushings for cables going into shift box.
      If you change those 5 and same issue, then you could have internal issues.
      Quote Originally Posted by Jeffeypoo View Post
      I LIKE DIS. Allot.
      Did you know that it's not pronounced Em Kay ? ALL OF THE CAR LOUNGE WILL BE HAPPY TO LET YOU KNOW THAT. SERIOUSLY. IT STANDS FOR MARK. DID YOU KNOW THAT? BEFORE THAT A1,A2, A3, ETC WAS USED. LIVE UP TO TCL STANDARDS BEFORE YOU GET ON MY ASS. THAT'S DISGUSTING.
      Example of TCL's standards
