I'd like to help everyone out with wideband gauge solutions for you cars. The wideband gauge setups will allow you to log and monitor air/fuel ratios as well as do a few periphery things as well to help you maintain overall engine health and make peak power. These two solutions are the best bang for the buck on the market right now offering loads of features and usability without requiring thirteen other boxes for logging, tuning, and secondary features.
Zeitronix:
ZT-3 with ZR-1 Gauge Wideband Package
-complete wideband solution with gauge package
-can choose brushed aluminum or brushed black annodized alum bezel with either red or blue digits
-narrow band output, wideband output, analog wideband output (easily integrateable to any standalone or oem aplication with this features)
-most compact solution and simple 4 wire hookup
-Incredibly thin 60mm gauge which can be surface mounted, gauge pod mounted, or sat flush in a custom recessed pod like a vent with ulta thin cord for easy routing
-logging via included cable
Includes:
ZT3 controller
logging cable
gauge splitter
instructions
software
box
gauge in your choice of bezel and color
Bosch wideband sensor
weather tight molded sensor wiriing with protective sleeve and slim connector for easy run through walls
More info on website:
http://www.zeitronix.com/Products/Zt-3/Zt-3.shtml
Price: 250 + free shipping
ZT-2 with ZR-2 Gauge WIdeband Package
-narrow band output, wideband output, analog wideband output (easily integrateable to any standalone or oem aplication with this features), rpm input
-optional egt, boost, and temperature sensor inputs
-feature rich logging suite with the ability to log and display all inputs on screen such as boost, egt, etc all while still being able to see AFR readings
-waning outputs
Includes:
ZT2 controller
logging cable
gauge splitter
instructions
software
box
egt connector for any k type thermocouple
optional sensors such as boost, egt, temp sensors and alum and steel bungs available at extra cost
http://www.zeitronix.com/Products/zt2/zt2.shtml
Price: 355 + free shipping
Dash II XL with ZT-2 Controller
-Screen based viewing of not only wideband and other ZT-2 and ZT 3 features but also OBD2 data
-Two or more (up to 8) Zt-2s/Zt-3s can be connected to the DashDAQ II XL display. The DashDAQ can read and display wideband and sensor readings from each Zeitronix device plus OBDII data all at once.
-The DashDAQ has two additional 0-5 volt analog inputs and data logging is supported through an SD card slot on the side of the display.
-Easily mountable via the included suction cup window mount or via flat panel like mounting to the dash or home made bracket or recessed molded installation.
-easily portable transfer between vehicles and live info with lap-top less logging
Includes:
Dash DAQ II XL screen with USB B inputs, SD Card slot, mounting locations and integrated speaker
Serial logging cable
OBD 2 cable
Software CD and instructions
suction cup window mount, and fixed plate mount and hardware
box/warranty
ZT-2 controller, instructions, software, bosch sensor, egt connector, 2x wiring harness, data splitter
videos and further info on Dash DAQ II XL:
http://www.zeitronix.com/Products/dashdaq/dashdaq.shtml
Price: 700 + free shipping
AEM Failsafe Wideband
-complete all in one gauge wideband solution
-no external boxes - full controller is integrate into the gage
-single wiring harness packaged nice and tight
-included bung for 02 sensor
-rpm based logging for map comparision
-integrateable easily via wideband and narrowband output into standard or aftermarket ecus
-all included silver and black gauge bezels as well as various colored screens and lamba/AFR selectable screens
-boost and AFR simultaneous viewability
-USB based logging
WIDEBAND FAILSAFE GAUGE FACEPLATE STYLES:
Kit comes with 6 different faceplates and black and silver bezels.
•Black and White AFR in sweeping LEDs
•Black and White Vacuum/Boost in sweeping LEDs
•Black Vacuum only in sweeping LEDs
•Black Lambda in sweeping LEDs
WIDEBAND FAILSAFE GAUGE TECHNICAL FEATURES:
•Displays both boost or vacuum and AFR or Lambda simultaneously on the same gauge
•No free air calibration required – ever
•Internal boost sensor
•Bosch Wideband UEGO sensor and weld-in bung included
•On-Board 3+ hour Datalogging capability at 20hz per parameter
•Full color Organic Light Emitting Diode (OLED) Display in center, user selectable feature (boost/vacuum or AFR)
•24 three-color sweeping LEDs, user selectable feature (boost/vacuum or AFR)
•Intuitive set up software
•Interchangeable faceplates and bezels (see options, above)
•Data analysis using AEMdata software
WIDEBAND FAILSAFE GAUGE INSTALLATION FEATURES:
•AEMnet compatible (CAN 2.0)
•Differential AFR analog output
•Differential boost analog output
•Configurable RPM input for logging
•One low-side driver output (Ground with 1.5 amp max draw)
•Positive-lock connectors
•Tunable PC-based software with USB connectivity
•Time based reset for outputs
Info on website:
http://www.aemelectronics.com/wideba...safe-gauge-84/
Price: 275 + free shipping
