Results 1 to 8 of 8
Thread: FS: 2004 A4 Avant 6 speed manual sport package, 104,800mi, New England
  1. Member windsorblue's Avatar
    Jul 23rd, 2001
    Brunswick, ME
    2012 Golf R
    09-19-2012 01:43 PM #1
    SOLD. Car will be missed
    My 2004 Avant is for sale.
    About the car:
    It currently has 104,800 miles. The car had three adult owners, I am the third and a life-long VW/Audi enthusiast as well as an active Audi Club North America member. The first owner special ordered it and leased it, the second was an older woman who purchased it CPO to replace her BMW and unfortunately she passed away about a year and a half afterward. I purchased the car in August of 2008 from the second owner's son. I am a former VW trained technician and have taken very good care of the car in the four years and 48,000 miles I have owned it. The car was obviously a special order car from the last days of ala-carte options before the "package" system completely took over. I can say with reasonable confidence that there is not an identical car to this in the US or Canada. It has been extremely well-maintained and documented during my ownership and I can provide maintenance records from the second owner as well. This is a no-excuses, adult owned car. I would install the snow tires and drive to Alaska tomorrow with confidence, if I had the time.
    Factory Specs/options:
    2004 Audi A4 Avant 1.8t quattro 6 speed manual
    Atlas Gray Metallic Paint
    Gray CLOTH interior
    Cold Weather Package(heated seats, washer nozzles and a ski bag in the rear center arm-rest pass through)
    Sport Package(springs, shocks, sway bars, 17" wheels, aluminum interior trim)
    Painted lower body
    Bose with Sirius radio
    Rear seat side-impact airbags
    NO Sunroof
    Maintenance History:
    Serviced per Audi recommendations at Audi dealerships through 55,000 miles
    Every 5,000 miles beginning at 60K: Oil and filter change using Redline 5w/40, and OE filter, and a fresh drain plug; tire rotation
    Every 10,000 miles beginning at 60K: 5k service plus wiper blades, engine air filter, and cabin air filter.
    Every 20,000 miles beginning at 60K: 10K service plus spark plugs and fuel filter.
    70,853 Battery
    71,848 miles, Timing belt including the following: Timing belt & tensioners, waterpump, thermostat, radiator(due to a pin-hole leak), coolant flange on the back of the head, ECT sensor, coolant expansion tank, coolant, power steering fluid. All parts used for this service were factory parts sourced from the local VW/Audi store.
    87,352 miles, Suspension project: Koni FSD stuts and shocks were installed along with a factory RS4 rear swaybar, a complete Meyle HD upper and lower control arm kit, Meyle HD complete tie-rods, Meyle HD front swaybar end links, factory front sway bar bushings, and all associated hardware.
    90,451: Redline transmission and rear differential fluid
    93,610: Front O2 sensor(no CEL, just noticed a drop in fuel efficiency)
    104,214, Brakes: Centric re-manufactured front and rear calipers painted before installation with Eastwood's silver high-temp ceramic paint(calipers were properly masked off and the paint was allowed to cure for over a week prior to installation.) Centric premium high carbon rotors(F&R), Stoptech street performance brake pads(F&R), Goodridge stainless lines, Motul DOT 5.1 fluid.
    Minor Modifications:
    APR stage 1 software(currently turned off)
    Neuspeed TIP
    K&N drop-in filter
    Koni FSDs
    RS4 rear sway bar
    Dension iPod adapter(the expensive one with text display on the MFD, works with iPhone as well)
    Sylvania Silver-star high and low beam headlight bulbs and fog light bulbs
    2008 B7 SE wheels currently installed(stock Pirelli all-seasons tires with ~10,000mi left), also comes with stock 17" wheels with good Dunlop snow tires(probably 2-3 seasons remaining.)
    Audi factory hatch spoiler
    Repair History:
    Thankfully, there is not much to report here. This car has never let me down and has been very reliable. When I did the Suspension, nothing was "wrong" with any of the parts that were replaced, I'm just picky about handling and wanted to freshen things up after nearly 90k. Similar story for the recent brake project.
    65,315 valve cover gasket, cam tensioner seals, breather tube
    65,XXX Engine speed sensor
    69,109 Driver's front window regulator
    80,730 Serpentine belt & Tensioner
    103,xxx Passenger front window regulator
    The bad:
    Nothing really. But as with any 100,000 mile car there is bound to be something worth mentioning.
    I removed the o-ring from the glove box brake to prevent the hinge from breaking. The glove box light still works and the hinges are in decent shape, it just doesn't lower itself slowly any more.
    The belly pan is in decent and useable shape overall, but the rear center fastener is no longer there. I drilled one small hole on either side of where the fastener used to be and use a zip tie on each side to keep the belly pan secure(it actually seems to be more secure than it originally was...lol.)
    The lower door trims are showing some age.
    That is it! Everything works, just three minor things that I would rather disclose up-front.
    Condition of the car:
    Overall, closer to "excellent" than "very good."
    Clean Carfax, no non-factory paintwork
    Fresh Maine State Inspection sticker
    Clear & clean title in hand
    I would rate the exterior 8-9 out of 10. I've tried to touch-up any rock chips or scratches. I have always kept the car clean inside and out and just clayed and waxed the paint.
    I would rate the interior a solid 9, maybe 9.5. drivers seat show very little wear, there are no peeling buttons, stains on the carpet or damage to the plastics, everything works. I last had the seats shampooed about two years ago and they still look good but it could be done again within the next year or so. I have never used any greasy, shiny, slimy products to clean the interior plastics.
    It is currently garaged and will remain so until it is sold, I have my new car so the mileage/condition will remain the same.
    Pricing:
    I usually try to average the three major pricing guides when buying or selling a car. I also look at the broader market on Autotrader, Cars.com, and the classifieds sections of enthusiats sites.
    KBB says between $8500-9000
    NADA dealer retail is $10700
    Edmunds hates me and says $7500
    Most dealers are north of $10,000 for similar cars with higher mileage and without service records.
    This car is in FAR better condition than any car on any dealer's lot and it is very well documented.
    My very fair price for a quick, no-haggle sale is: $8750
    Contacting me:
    My name is Tom Seymour
    PM on here is best
    You can e-mail me at thomws2 ~At~ gmail /dot\ com but I'd prefer PM if possible for you.
    You can reach me on my HOME PHONE(no text messages) after 7:00 PM most nights 207.406.4060 please leave a message if no one picks up, I promise to get back to you asap.
    Reason for sale:
    Bought a Golf R
    On to the pictures:
    All of the summer wheels look this good.
    I've been losing lots of keys lately
    I don't know what that means but maybe
    I'd be better of with things that can't be locked at all
  2. 09-19-2012 02:53 PM #2
    Quote Originally Posted by windsorblue View Post
    haha love that. And Love the car. VERY VERY interested. Must speak with wife before I bother calling you as I will be flying out to pick it up.
  3. Member windsorblue's Avatar
    Jul 23rd, 2001
    Brunswick, ME
    2012 Golf R
    09-19-2012 03:22 PM #3
    Quote Originally Posted by Distrackted View Post
    Thanks, I flew from Washington DC to Buffalo NY to pick it up four years ago. Took the long way on the back roads of NW Pa on the way home, great experience! Sorry I will not get to experience a cross-country trip in this car, I'm sure it would be fantastic!
  4. Member VWjetta_vr6's Avatar
    Apr 26th, 2012
    Upstate, NY
    2003 VW Jetta GLI VR6, 1995 VW Jetta GLX VR6
    09-22-2012 07:33 PM #4
    very nice car!!
  5. Member LeeHech's Avatar
    Jun 8th, 2010
    NYC and CT
    2001 A4 1.8TQMS
    09-23-2012 12:19 PM #5
    Quote Originally Posted by VWjetta_vr6 View Post
    very nice car!!
    Agreed, if this was black interior I think I'd sell mine and come buy yours.
    - Lee
    GRFXP.com for all of your sticker/decal/vinyl needs.
  6. Member windsorblue's Avatar
    Jul 23rd, 2001
    Brunswick, ME
    2012 Golf R
    09-23-2012 04:47 PM #6
    Sale pending. Car will be missed.
  7. Member BlackA4stage3's Avatar
    Feb 1st, 2010
    GA
    2003 Audi A4 Avant 1.8T GT28
    09-23-2012 10:56 PM #7
    if you dont mind me asking, where did you get the hatch spoiler? i have B6 Avant and that looks really good so i might look into getting one
  8. Member windsorblue's Avatar
    Jul 23rd, 2001
    Brunswick, ME
    2012 Golf R
    09-25-2012 08:06 PM #8
    Quote Originally Posted by BlackA4stage3 View Post
    It came on the hatch, I think is it just the dealer accessory one.
