Results 1 to 2 of 2
Thread: 1981 VW Rabbit Stumbling on Acceleration
  1. n00b TJ_Johnson21's Avatar
    Sep 19th, 2012
    Green Bay, Wisconsin
    09-19-2012 07:20 PM #1
    please delete
    Nov 24th, 2003
    Bellingham, WA
    81 caddy; original owner; 335,000 mi
    09-21-2012 06:46 PM #2
    You can access the fuel level sensor under the rear seat. Remove seat & there is a small round panel that comes off with 3 screws. Then remove fuel level sensor & shine light in tank. check for slude & rust, There is an intank screen that may be clogged from rust/old fuel. You may need to replace fuel filter again if there is a lot of crud in tank
    Tom
