What car?
#1
So when I start my car up from siting over night, it starts with about 1.5 cranks. When I have been running/driving it, it starts up with 3.5 cranks or so. Not a huge difference but something I of course would notice. I also noticed when its been running a while, the idle floats a bit, sometimes you can feel it but not often. Could this all be connected into the same thing? I've been wondering about this for a while now!![]()
#5
There is absolutely nothing. No codes, lots of power, everything is perfect, minus this slight idle floating. Basically if you really stare at the needle you can see it moving up and down (barely, you really have to look at it, very small amount). It only does this when the car is warmed up. And it takes about 1.5 extra cranks to start up when its been running....the normal person would totally NOT notice this. But me being the picky and anal person, I notice EVERYTHING. Usually you cant even hear the engine sounding different, occasionally, but not usually! Im just trying to make sure its nothing majoy (camshafts or something :p)
#6
I have decided its the lift pump, does anyone agree/disagree?
#7
#8
wouldnt there be like a huge issue if the tandem pump wasn't working right?
#9
Nope.. If you've got a early LUK tandem pump (black cover) there's a spring inside that can break, but the car will still function for the most part.. But you'll get erratic idle, etc... Most guys replace it with the Bosch unit and are good to go.. I'm waiting for my LUK tandem to give up the ghost any day now..
I also doubt it's your liftpump that's the issue.. Could be a bad temp sensor that's pulling timing once the engine is warmed up..
#10
I was also thinking the temp sensor could be it too....thats the ect sensor right? I might just replace that...its not too expensive. Mine I believe is just metal, no plastic that I can see, plus its an 05 so maybe its newer?
#11
#12
I know it's there lol, I will go check closer. so I should be looking for a black plastic piece on it?
#13
Where is the FTS located on my car? I couldn't get a straight answer on google!
