Results 1 to 11 of 11
Thread: Factory speaker wiring.
  1. Member v2.'s Avatar
    Oct 18th, 2007
    Johnson City, TN
    MKIV R32
    09-20-2012 08:18 AM #1
    I'm having an issue with my speakers/head unit in my MKIV R32. I have the factor double-din Monsoon unit and all factory speakers. A couple of days ago, I started my car and all I heard was a really fast clicky/static sound from all of the speakers. I took the Monsoon unit out to check the harness and connections and everything seemed to be fine, so I unhooked the battery for about 10 minutes and then the speakers started working again.
    When I started driving, the fast clicking noise came back and then a lot of static from the right rear speaker. I hooked my car up to the VAGCOM here at work and it had a code of "short to ground - right rear speaker", so obviously there's an issue with the speaker or its ground. Is the factory wiring for the speakers designed to turn all the speakers off if one or its ground is bad?
    Quote Originally Posted by VincewagenR32 View Post
    Torque is a motherf***er
  2. Member v2.'s Avatar
    Oct 18th, 2007
    Johnson City, TN
    MKIV R32
    09-21-2012 06:52 PM #2
    Anyone?
  3. Member dgirouard39's Avatar
    Dec 10th, 2009
    York, PA
    07 Jetta 2.5, Slammed B5 A4 1.8t
    09-23-2012 09:16 PM #3
    i know stupid question but did you check the the speaker and make sure it was connected tight. and check the factory unit again and make sure the rear right two speakers are in the connectors tight. they could be a little loose
    mk5 jetta 2.5 / 99.5-A4-SOLD / Contact me if your in PA and want PlastiDIP done /istagram me@gyro_mkV
  4. Member v2.'s Avatar
    Oct 18th, 2007
    Johnson City, TN
    MKIV R32
    09-23-2012 10:20 PM #4
    Quote Originally Posted by dgirouard39 View Post
    No I haven't checked the speaker or its connections. I was just curious if the short in just the one speaker would cause all of them to not work. Tearing into the rear quarter tomorrow and checking everything.
  5. 09-26-2012 06:10 AM #5
    2000 Alero are the factory speakers soldered or wiring harness?
    Are the factory speakers wired be being soldered or by a wiring harness?
  6. Member v2.'s Avatar
    Oct 18th, 2007
    Johnson City, TN
    MKIV R32
    09-28-2012 01:49 PM #6
    Bump. Any help would be appreciated. I unplugged the right rear speaker and the fast clicking still happens. Cleared the code with my VAGCOM and it still does the clicking. The code was:
    00869 - Line Output; Rear Right
    44-00 - Short Circuit
    I also tried another Monsoon unit and it still does the same thing. This is driving me insane, please help!
  7. Member FigureFive's Avatar
    Dec 21st, 2003
    Nashville, TN
    MkIV R32
    09-28-2012 04:03 PM #7
    Quote Originally Posted by v2. View Post
    Perhaps the short is in the wire that runs from the headunit to the amp.
  8. Member v2.'s Avatar
    Oct 18th, 2007
    Johnson City, TN
    MKIV R32
    10-01-2012 01:58 PM #8
    I still haven't gotten to the bottom of this, but something new started happening. I hooked the Monsoon unit back up to test some things and then when I left it plugged in, my horn no longer beeps when I lock my car.
    Dec 9th, 2011
    Allentown, PA
    02 VW jetta GLS 1.8t
    10-01-2012 11:37 PM #9
    It may sound like a lot of work hearing this but the fact your vag com says short to ground means you have a bad power or ground somewhere in that wiring. You'll need to remove the speaker and follow ALL the wires to their sources (amp/headunit) somewhere in those paths you'll likely find a wire loose or spliced somewhere touching something it shouldn't.
    If that seems like too much of a pain for you it's a good time then to upgrade those speakers and headunit and run new speaker wire to a new amp and bypass all that extra nonsense.
  10. Member v2.'s Avatar
    Oct 18th, 2007
    Johnson City, TN
    MKIV R32
    10-02-2012 09:44 AM #10
    Quote Originally Posted by BoostedGLS0218 View Post
    Thanks for the help! I did a bunch of searching yesterday and found several threads about checking fuse 42. The threads said that most of the time the fuse is good, but simply removing it and putting it back in fixes the problem, so I tried that. After I checked the fuse, I checked the connections at the factory amp, unplugged the harness and reconnected and then tried and I now have sound again
    I don't know if either of those things worked, or it was just coincidence, but it worked all the way to work this morning and I'm afraid to touch anything else since it is working again
  11. Member
    Dec 9th, 2011
    Allentown, PA
    10-02-2012 10:49 AM #11
    Hey man if It ain't broken don't try and fix it that's what I always think. Hopefully that fixed it. If it comes back though you may have to trace wires
