VWVortex.com - Flashing Brake Light, Beeping - Full Brake Fluid
    Results 1 to 13 of 13
    Thread: Flashing Brake Light, Beeping - Full Brake Fluid
    1. 09-21-2012 09:08 AM #1
      Over the last year or so, my brake light will occasionally flash during a drive cycle and beep incessantly. I know the main cause of this is brake fluid level, but it has always been completely full when I check it.
      The last two days, it's come one and beeped the every drive cycle and for much longer than before, yet the brake fluid is still full. What else can cause this light to come on and beep? I have read stuff on the forums about the ABS module going out, but doesn't that cause the ABS light to come on as well?
    2. Member VWBugman00's Avatar
      Mar 16th, 2009
      Kennewick Wa
      00 Beetle
      09-21-2012 12:58 PM #2
      Quote Originally Posted by Baumer2000S4 View Post
      Check your fuses. Make sure they're good. If that isn't it, you should get it scanned with a VAGCom, to see which codes are popped. If you don't have one, go to the Regional Forum, and someone will likely scan it for you for beer
      2000 Beetle, 1991 CR-X, 2005 Chevy Malibu 3.5 LS, 1988 F-150 (R.I.P)
    3. Member OddJobb's Avatar
      Nov 6th, 2004
      Greenville SC
      2004.5 Jetta GLI, 1995 Golf III City
      09-23-2012 10:36 AM #3
      What make/model/year car is this? If it randomly goes off, I'd check all the wiring connections first.
      Quote Originally Posted by LG6R View Post
      I never understood this and don't take it personally because people come on here and say that all the time. But if you don't know what it is or what it does, why don't you leave it the hell alone?
    4. 09-24-2012 09:46 AM #4
      It is a 2000 S4. I checked the fuses and everything seems fine. Even got to the point of removing the filter from the inlet of the reservoir and fingered the float to make sure that it wasn't stuck. The constant beeping tailed off by the end of the weekend though.
      Car is in the shop this morning to get a wheel bearing replaced (was humming), so hopefully VAG-COM will have the answer. Will update this if they find the problem so if anyone else runs into this, they know...
    5. Junior Member
      Mar 1st, 2010
      Charlestown, WV
      01.5 S4 Stg 2+
      09-24-2012 09:52 PM #5
      Not certain but I think it has something to do with the E-brake wire. I had the same problem before with both of my S4's.
    6. 10-15-2012 01:56 PM #6
      The shop was unable to find anything wrong with the car a few weeks ago, though it wasn't beeping/flashing for them when it was in, go figure. Car had stopped beeping/flashing until this weekend, took it in today while it was still doing it. There were no codes in the car related to this. There is fluid in the reservoir, and they even tried jumping the connector for the level sensor to rule out a bad sensor.
      So this is either wiring between the connector and the cluster, or a cluster. The only other thing that I think this could be is that my brake wear indicator has been on for a very long time (the wire got caught on something and broke over a year ago, there is plenty of pad still) and does anyone know if there is some sort of backstop timer that will cause the car to flash/beep, thinking that I've ignored the wear indicator for too long?!?!?
      Feb 25th, 2012
      Augusta, GA
      BPY VW GTI
      10-15-2012 07:06 PM #7
      Have you checked the wheel speed sensor in the wheel bearing? You mentioned you had work done on the bearing recently. That'll cause the ABS light to flash if its malfunctioning/destroyed.
    8. Member lbandt's Avatar
      Sep 13th, 2012
      Wiscompton
      02 gti 1.8t R.I.P. 00 vw gti 1.8t. 15' Jetta 1.8T
      10-25-2012 01:44 PM #8
      Quote Originally Posted by albinorineo View Post
      im having this same problem. my wires were damaged on my passenger side for my hweel speed sensor so my abs and traction control lights are on. just the other day tho my 'brake' light would blink at start up and beep. it will then stay flashing throught the time the car is on. if i remove the switch in the reservoir n flip it upside down theoretically i would think the light would go off? also unplugging does not affect it. i wouldnt think my wheel speed sensor would affect this either since its been bad for awhile.
      please post what u find out is wrong
      Feb 25th, 2012
      Augusta, GA
      BPY VW GTI
      10-26-2012 05:54 AM #9
      lbandt,
      Check your front pad thickness.
      In addition, fix your wheel speed sensor as your ABS will not function without it; should the occasion arise for ABS to engage. Flipping or unplugging the sensor will not get rid of the light, as if just responds with a simple flag state to show the ECU if the reservoir has fluid in it, no matter the orientation.
      Side note:
      Fixing a problem with the braking system by unhooking random sensors until the dash lights go away is a terrible idea and will likely end up with you getting yourself hurt or even worse, someone else. VW put the lights in the dash for a reason.
    10. Member lbandt's Avatar
      Sep 13th, 2012
      Wiscompton
      10-26-2012 09:03 AM #10
      lbandt,
      Side note:
      ill check the pads. and all i was trying to do is rule out a bad reservoir float. i didnt intend on leaving anything unplugged, bcuz like u said thats stupid. previous owner had same problem as me and he cleaned the float in the reservoir cap and the problem stopped
    11. 10-29-2012 11:48 AM #11
      I haven't checked any of the ABS wiring, but I'm fairly certain that's not the issue since the ABS light is not coming on, just the red parking brake light. I'm going to check the pads (and the wiring for the wear sensors) next, need to find time to get the car up and get under it.
      But in the meantime, the buzzer coming on every minute or less is getting very annoying. Does anyone know if it's easy to unplug the buzzer in the cluster?
      Feb 25th, 2012
      Augusta, GA
      BPY VW GTI
      10-29-2012 01:50 PM #12
      You made it sound like the ABS light in your previous posts. IIRC the handbrake just pulls a cable to engage your rear brakes, unless you have the motorized version. There should be a sensor under the handbrake lever where it pivots, pull the plastic and check the angle sensor. When I get home tonight I'll see if I can post a diagram.
    13. 11-12-2012 03:27 PM #13
      Hey guys please check your the three fuses on top of your battery! The 10 amp ones. Mine was doing the same thing and all the fuses were good but were not making contact! move them around and see if it goes away! Let me know if it fixes your problem. Thanks!
