Results 1 to 8 of 8
Thread: Mk3 VR6 Reverse Gear Selection Issue
  1. 09-22-2012 01:23 PM #1
    I am having issues with a VR6 5 speed manual reverse gear. It is very hard to select reverse gear in any case. When I manually select reverse at the transmission with the engine off, you really have to force down on the selector linkage HARD and then turn to find it. In the car, you have to shove left HARD after pushing down to get reverse, and 4 out of 5 times you get first gear.
    So far I have:
    Checked the dumb plastic shift cable retainer piece, it's good
    Adjusted the cables
    Replaced the shifter box/cables, original had worn bushings/play
    Drained and filled with new synthetic 75W90 GL4
    I am out of ideas here. I'm not sure what to do next. Have you heard of this issue before with the 02A?
    Reverse gear selector fork issue? If so, how could this have happened?
    Thanks in advance
    http://www.ebay.com/itm/VW-VR6-02A-T...-/290225729512
    Golf bumpers don't belong on Ventos
    European Performance Products
    PVW 5/11 Held It Down
  2. 09-22-2012 09:20 PM #2
    Slow in here
  3. 09-24-2012 10:34 PM #3
    ttt
  4. 09-25-2012 06:43 PM #4
    ttt
  5. 09-26-2012 07:02 PM #5
  6. 10-07-2012 09:30 PM #6
    ttt
  7. Member Scrubbs's Avatar
    Mar 13th, 2006
    GB Maryland
    Mk2,s Mk3's
    10-08-2012 05:43 AM #7
    If your having a hard time pushing down on the shift tower at the trans, that picture is more than likely NOT the problem. Try disconnecting the cables and see if the problem is still there. Check the cables if they are binding. Probably have something in the shifter box, or alignment issue. If it is in the trans, pull the tower. ( 2 bolts, and sealant, after the cables are disconnected.) You can inspect the lower cover too.( 2 bolts and sealant, and lots of gear oil.) Inspect the tower and look for a bad detent ball spring, or debris in the lower cover hole.
    The part in the pic is only operated when the tower is twisted. So difficulty ,up and down, on the tower is just lining it up with selector forks for each gear set. And remember, a spinning gear train is easier to engage than when the motor is off. Unless it just happens to be lined up perfect. So it can be difficult to engage gears if the motor is off. sometimes it goes right in. Not a good diag tool.
  8. Member Scrubbs's Avatar
    Mar 13th, 2006
    GB Maryland
    Mk2,s Mk3's
    10-08-2012 05:45 AM #8
    Pics if you take stuff apart please.
