If I wanted stg2, stg1 93, and stock with all of the other goodies would that be allowable under this sale? I'm untuned but installing a turboback this weekend only mk6 gti.
#1
From now until October 14th, APR's huge Fall into Power sale is on! Save on all sorts of products, from ECU software upgrades to motor mounts, silicone, Carbonio intakes and APR's excellent hard-parts.
First up, the software...as you can see you can save over $600 on many applications! Both NGP locations have on-site flash capability and can turn around most software appointments in a brief period of time. To book your APR ECU upgrade appointment today, just contact the location closest to you. Plus we're offering free install labor on all DPP flash upgrades!
Install labor on Mk6 / CC / TT and all other late model TSI upgrades that require pulling the ECU and older EMCS hard chips, are regular price for install.
• ECU Upgrade Sale:
• * All 2.0T FSI or TSI or 2.7T – $599 For a Fully Loaded ECU! Normal Price $1203
• * All DPP 1.8T – $499 For a Fully Loaded ECU!* Normal Price $1103
• *3.0 TFSI V6 - $1499 for a fully loaded ECU! Normal price $2103
• * All VR6, 2.5L, 4.2L, are $100 off! Normal Price $499-599
• *$50 off single program option, where applicable
• *10% off all 'exotic' ECU upgrades such as RS6, RS4, Porsche turbo, Audi R8, etc.
• *Certain DPP / 1.8t models cannot accept loaded chip flashes and must be hard-chipped for multiple programs.
• *Certain program options not available on all models
• A Fully Loaded ECU Includes your Choice of 4 of the Following Programs:
• * Stock Mode :: Exact Original Mapping and Performance
• * 91 Octane Performance
• * 93 Octane Performance
• * 100 Octane Performance
• * Valet Mode :: Limits RPMs and Power Output
• A Fully Loaded ECU Also Includes:
• * Fault Code Erase :: Erases Fault ECU Fault Codes
• * Security Lockout :: Locks Advanced Functionality of Cruise Control, Password Protected
• * Anti-Theft :: Disables Throttle to Render Vehicle Inoperable, Password Protected
Don't forget, APR's high quality line of hardware is also on sale, with discounts of 10% on almost every part number they manufacture. Make your upgrade complete with a matching turbo back exhaust system and Carbonio intake. Provide the final touch with APR motorsport parts or an R1 diverter valve.
• APR Hardware Sale:
• * APR Carbonio Carbon Fiber Intakes 10% Off!
• * APR Stage 3 and K04 Turbocharger Systems 10% Off Select Systems!
• * APR Exhausts Systems 10% Off!
• * APR Intercooler Systems 10% Off!
• * APR Bipipe 10% Off!
• * APR R1 Diverter Valve 10% Off!
• * All APR Motorsport Items including Silicone Hoses and APR FSI Fuel Pump 15% Off!
Check the full line up of APR parts online at NGP Racing.com, just by clicking here, or contact your NGP location to find out more information.
• -Aberdeen, MD - 410.994.0000 / servicemd@ngpracing.com
• -Lorton, VA - 703.454.3000 / serviceva@ngpracing.com
#2
#3
You would just be stage II. The ability to switch between programs is for different octane ratings, stock, and valet. To go between stages you would have to get re-flashed at NGP.
What I went with (as recommended by NGP Aberdeen) was Stock, 91, 93, 100.
The only hardware that you are required to have for stage II is a downpipe, which will be taken care of by your TBE.
Enjoy your new car. Once you are tuned it is completely different.![]()
APR Carbonio Stage I Intake | APR Stage I tune | Euro Shift kit | misc light aesthetic mods
#4
#5
#6
So stage 2 is where I'm at withe the tbe. Are there different options within stage 2?
Thanks
Jason
#7
All of the options that are listed above are included in the "fully loaded ECU", along with your choice of 4 tune levels. The only real differences in the stg 1 vs stg 2 tune is some magic behind the scenes that you won't have to worry about, but if you're curious there are a lot of different dissections of the programs in the MK6 forum.
Is there anything in particular that you are curious about?
#9
#10
#11
Be sure to get the non-test pipe file when going stage II otherwise you WILL NOT pass VA emissions. When you are installing your TBE, install a o2 sensor spacer on the last o2 bung, this will eliminate the p420 CEL code, if your car is CCTA.
If you are CBFA, read here:
http://forums.vwvortex.com/showthrea...CEL-Fix-Thread
Enjoy your new software, I'm waiting for my CPO warranty to run out before I get mine done.
#12
VA only requires emissions testing in certain counties within the state (Stafford being one)... if you garage the car out of the county requiring emissions testing (and can prove this) you will be exempt from the test. I'm active duty AF, live and garage my car in MD but I'm a resident of Stafford. I never get emissions done and don't have to according to the DMV. State inspection is still required. Not sure if this helps but if you've got family in another state nearby, I'd ask them if it's all right if you "garage" the car at their house, in their state, per the title just to avoid emissions... there's also a shop I go to on Oakland St. in Sherlington near the DMV that does my state inspection. They pull the car in, honk the horn, flip the lights and back it out... Granted it's an '09 and nothing should be wrong, it's not very thorough and I don't doubt they'd slip you a sticker for a few extra bucks. If you're an honest Abe, I can't help you haha.
#13
Question about the software: I see you mention that it's regularly $1103 for a fully loaded 1.8T ECU... On APR's website, it states the Stage 1 chip/flash is only $499 and has reflected this for quite some time. Does that mean you regularly charge $600~ for labor or am I getting this backwards somewhere?
#14
Thanks for all of the advice fellas. I got the awe-tuning turboback and I have no cel stock. I got the stage 2 non test pipe file and it rocks. I love it. Whole new car.
