Results 1 to 9 of 9
Thread: Factory Spark Plugs?
  1. 09-24-2012 10:22 AM #1
    My friend has a neglected 2008 Jetta S 2.5 CBTA at 104K miles, which has not been modified at all. It is beginning to run roughly. He has yet to change the plugs or do a tune up.
    My experience with other cars (Honda, Toyota, Ford) has taught me to use the exact same plugs as came with the car originally. I have had a real struggle trying to ascertain what came originally in his Jetta. Websites say that the original plugs could be Bosch, NGK or even Denso.
    What is the model number of the original spark plugs? Any suggestions for brand/model for the other tune up parts?
    Thanks,
    az in sc
    (Newbie here)
  2. Member mldouthi's Avatar
    Jun 26th, 2010
    Concord, NC
    08' Rabbit, 97 zx6r (Fighter Project)
    09-24-2012 10:42 AM #2
    http://www.ecstuning.com/Volkswagen-...gine/Ignition/
    Service kits at the bottom of the page.
  3. 09-24-2012 11:12 AM #3
    There are three different kits.
    One uses NGK and has red coil packs. The second has black coil packs and matches with Bosch plugs. The third uses Karlyn coil packs and Bosch plugs.
    My experience with Bosch plugs leans me toward the NGK and standard coil packs...but only if the are the factory original. Did VW use both brands as OEM?
    I imagine that the Karlyn coil packs are an upgrade from OEM. Are the other coil packs offered at the site OEM?
  4. Member mldouthi's Avatar
    Jun 26th, 2010
    Concord, NC
    09-24-2012 12:30 PM #4
    I have the first kit with the NGK Plugs and red coil packs.
    I dont remember what I pulled off the car in way of spark plugs. I think they were NGK also.
    sorry.
  5. 09-24-2012 01:13 PM #5
    Thanks. As long as I know which ones work, I'll be good.
    NGK it shall be. His car is red too, so he'll like the matching coil packs.
  6. Member
    Nov 27th, 2011
    Pittsburgh,Pa
    bagged jetta 2.5/ 86 cabby lawn ornament/ 00 cabrio/ 2012 beetle
    09-24-2012 07:48 PM #6
    there was a factory recall on the oem coil packs. should have changed them at 60k
    BAGRIDERS
    I AM THE 3M GUY.
  7. 09-24-2012 08:46 PM #7
    Recall. Interesting.
    I really doubt he's done anything with the car at all. He changes the oil every 10K, but that's it. Could he still collect on the recall if it never has been done?
    Oct 2nd, 2009
    Richmond, Va
    2006 Jetta 2.5, 1996 Jetta 2.0
    09-28-2012 06:55 PM #8
    Quote Originally Posted by allenzachary View Post
    Have him call the dealer with the VIN first...not many 2008's were affected, to my knowledge.
    Jul 31st, 2011
    Brampton, Ontario
    2007 Volkswagen Jetta Wolfsberg Edition
    10-04-2012 12:33 AM #9
    If i recall correctly the oem plugs i pulled out of my car were labelled VAG, so it was neither bosch or NGK branding wise. I replaced them with lazer welded NGK Platinum tip plugs and so far so good after 25000miles.
