after looking up your post have you solved the issues to why you are burning so much oil?
#1
For sale is my 2005 B6 S4 with a little under 89,000 miles. It's a six speed manual transmission, it has black leather heated seats with white alcantara inserts, it has the multifunction steering wheel, rnse navigation, aluminum interior trim, rear sun shades (the back window is motorized, the 2 rear passenger windows are manual), it has Bose audio, h&r lowering springs, 35% window tint. Everything on the car works perfect, I've take great pride in this car and have always used OEM parts when doing maintenance.
There are 2 problems with the car, the driver seat bottom has a tare in the alcantara - the passenger front has a stain on the bottom alcantara, I got quotes at 2 different shops and they both gave me an estimate of around $400 to have both seat bottoms reupholstered; also the driver side front cv boot has a small tare in it (not causing a problem, but may not pass inspection), I have a whole new axle shaft for that side that will be included with the car.
It has almost brand new continental tires, rear ebc green brake pads that are almost brand new as well.
Maintenance:
64,060 Miles - 5/24/10
(8) Ignition coils - 077905115T
(8) Spark plugs - Bosch 7406
Induction service
New air filter / cleaned pre-filter
77,845 Miles - 6/12/11
Clutch kit
Clutch disc
Pressure plate
Release bearing
Flywheel
Front brake pads
Front brake rotors
82,690 Miles - 10/03/11
Battery
OEM crank angle sensor - 077905381F
Oil cap with seal
Lucas fuel injector cleaner service
MAF cleaned
EBC - Green stuff rear brake pads / lube hardware
82,859 Miles - 10/13/11
OEM driver front window regulator
OEM wiper blades
85,471 Miles - 12/02/11 (most recent oil change)
Castrol Edge with Syntec Technology Full Synthetic 5W-40 Motor Oil
OEM Audi / Hengst oil filter
OEM drain plug / crush washer
3.5 qts Motul Gear 300
86,637 Miles - 12/27/11
Audi RNS-E factory navigation - 8E0035192J
K&N 33-2209 air filter
PCV Valve replaced -077103245B
No check engine light, no abs light, no problems what so ever; everything is up to date and runs perfectly, this car is very clean and very well taken care of. I'm only the second owner.
More pictures @ https://www.icloud.com/photostream/#A3JtdOXmGGjUWZ
The car is for sale as is for $16,500 or $16,000 without factory navigation (regular Audi 6cd changer will be installed).
Tech Specs are located @ http://www.edmunds.com/audi/s4/2005/features-specs.html
Thanks for looking! Please message me with any questions / concerns. I'm located in Baltimore, MD 21234.
-Steve
-Steve
Baltimore, MD 21234
#2
For Sale 1981 VW Rabbit Diesel/veggie oil conversion
#3
Yeah I replaced the PCV valve and it made it a whole lot better; it still burns a little oil during long trips (2 hours+) in the hotter summer months, looking through forums it's because of so much heat build up in the engine bay. I've added 1 qt of oil since the PCV valve was replaced.
-Steve
Baltimore, MD 21234
