Results 1 to 10 of 10
Thread: 276 cam or stock ABA cam?
  1. 09-25-2012 07:09 PM #1
    I'm turbo-ing the my OBD1 ABA.
    I'll be running on stock internals, low-compression (9:1), T3 60 trim .48 exhaust side, #42 injectors and Megasquirt 1v3.
    My question is: I have a Shrick 276 cam right now in the engine. Should I use it or go back to stock cam due to the overlap on the 276?
    I'm looking at around 200 hp and 10 psi.
    Sep 20th, 2004
    se pdx
    87abat drag gti, 95 jetta beater
    09-25-2012 08:12 PM #2
    i would leave the 276 in, with the stock cam the power runs out around 5k, tt does make a 176 for the turbo cars, you should be fine,
    also with the set up you have that engine will take 20psi really easy or more as long as fuelling is there. so 200 will be very easy to get to.
  3. 09-25-2012 09:06 PM #3
    Yeah 20 psi might be possible but I want to keep it reliable too.
    And it remains a stripped out fwd mk2 .. no need of too much power.
    Any other thoughts?
  4. 09-25-2012 09:15 PM #4
    cam specs :
    *276 camshaft measured @ .004”
    Advertised Duration: 276*/276*
    Duration @ .004 276*/276*
    Valve Lift: .453” / .453”
    Lift @ TDC: .083"/.083"
    Centerlines: 110*/110*
    Lobe Center: 110*
    Valve Timing: 28/68 – 68/28
    Valve Overlap: 56*
  5. Member Prof315's Avatar
    Jan 5th, 2009
    Melbourne, FL
    1992 Corrado ABA and MS3-Pro powered, 84 Honda V65 Sabre
    09-26-2012 06:45 AM #5
    You should be ok with that. Is it ideal, no, a turbo specific cam would work better but it'll definitely make more power than the stock cam.
    The Professor
    Melbourne, FL
    92 Corrado OBD2 ABA Powered by MS3Pro
    M & L EFI Performance
  6. Forum Sponsor Quintin@USRT's Avatar
    Oct 6th, 2009
    DC
    A founding Member of the 8v 350+whp Club, Now rocking a B7 S4 mmmmm V8!
    09-26-2012 01:03 PM #6
    boost pressure doesnt dictate reliablity.
  7. 09-26-2012 06:32 PM #7
    then I should boost 30 psi
    Sep 20th, 2004
    se pdx
    09-26-2012 09:39 PM #8
    As long as your tune is dead on you could I'm building a aba now that will run 9-1 compression and 30 + psi but will be tuned by Kevin black so I know it will be spot on
  9. Forum Sponsor Quintin@USRT's Avatar
    Oct 6th, 2009
    DC
    09-26-2012 09:56 PM #9
    Quote Originally Posted by max9505672 View Post
    ....i did.
    ....everyday.
  10. Member kevinescobar15's Avatar
    Apr 27th, 2010
    Auburn, Wa
    Mk4 2.0T on megasquirtII
    09-29-2012 11:35 AM #10
    Stick with the 276. Boost will kick in a little later than the stock cam but you'll have power all the way up to your redline. if down the road you can get your hands on a tt 276 turbo cam then that would be your best option. stay away from the stock cam. you'll have good spool but ad people stated you'll feel how it goes dead after 5k. Hope that helps.
    One slow MK4 8vT
