#1
My 03 Jetta will not go in to any gear in the mornings I have change the fluid but still have the same troubles .Anyone run into this problem after the the car warms up it shift and goes into gear with no problem.
#2
#3
What does "go in to gear" mean?
Are you saying it wont move till it warms up? Or are you saying it "wont shift into next gear" as you drive it, till it warms up.
Auto trans fluid change or flush will not make a trans fail. Stop spreading the wives tale/urban myth.
ASE Master Certified Technician with L1 Advanced Diagnostic Rating Recently passed ASE certification for Light Diesel repair.
www.KansasCityTdi.com
#4
Or maybe you mean "wont go into reverse" till it warms up. If thats the case I would agree with carfreak that it probably needs solenoids.
usually with the "wont go into reverse till it warms up" problem it WILL go into forward.
