sounds like a misfire
#1
Well, I just went to grab some lunch and on the way home I got on it a bit. I was met with sluggish acceleration and a flashing CEL. Before I could even turn the car off, the CEL went away. I was about 200 yards from my house so I coasted home. What could the issue be?
2008 Passat 2.0T Tippy with APR stage 2.
#2
2007 Candy White/Black Passat 2.0T Wolfsburg Edition| APR Stage 2+ | APR HPFP | Forge WINtake | S3 Intercooler | B&B 3" Turbo-Back Exhaust | Dogbone Insert | FK Silverline+ Coilovers | Front Lip Spoiler/Hi-Def Sideskirts | Votex Trunk Lip Spoiler | R-Line Fog Grilles | Clear Corners | HID Kit - low beams & fogs | RCD-510 | Podi Boost gauge | R-Line Pedals | GTI Steering Wheel |
#3
#4
its a misfire, like B6 Passat said. It could be caused by many things though. bad coil bad plug. get the car scanned w/ vagcom and see if it is a specific cylinder or all 4 to help narrow things down
Unitronic Stage III w/ PT5558BB Turbo (What a difference UNI is from APR!!)Unitronic.ca,HPFP Upgrade Stage 1 pump, 3in.TBE, BSH throttle pipe/27mm RSB/Endlinks , Forge 007 DV , RalcoRC SS, 42Draft Design CNC Shifter bushings, N2MB WOT box, BFI stage 2 motor/tranny mounts, 034 Dogbone, Koni FSD shocks, Neuspeed springs/25mm FSB, Whiteline Anti-lift kit/Front control arm bushings, 18x8.5 VMR VB3s, JBL stereo, CTS Turbo 2.0t FSI Big turbo kit!
#5
First it was cylinder 4, replaced coil pack, now it's cylinder 2.
Is there a TSB on coil packs?
#6
