Results 1 to 6 of 6
Thread: why does my 93 Fox GL idle so high?
    Sep 12th, 2012
    Elkton MD
    93 VW Fox GL ( black )
    09-26-2012 05:27 PM #1
    hey guys woodardman here i have a question regarding why my 93 Fox GL is idleing so high i dont think its suposed to be idleing ate 1500 rpms i think it should be at 900-1000 rpms and i do not believe the previous owner installed a aftermarket camshaft cus i didnt i want to but i need money first so whats the norm for the idle??
    Apr 16th, 2006
    Brokelyn, NY
    90 fox, 85 gli
    09-27-2012 03:08 AM #2
    How does it drive otherwise, especially before it's warmed up? What are the revs when you first cold start the car?
    You need a small flathead screwdriver. On the side of the throttle body (facing the passenger side), you'll see a screw. Turn it clockwise to bring down the idle.
    I really suck at smog.
    Sep 12th, 2012
    Elkton MD
    09-27-2012 05:56 AM #3
    it drives amazing no rough idle only it steadily reving at 1500rpms and i havent notice a diff from a cold start it drives amazingly for having 149,XXX original miles it doesnt stall or have trouble starting
    the first or second turn over it starts i just hate how loud it is at idle cus all the other cars idle at around 1000rpms ive noticed unless they have a rough idle from a preformance cam
    Nov 27th, 2011
    Toronto, On, Canada
    1988 VW Fox, 1989 Peugeot 505 Wagon rolling shell
    10-07-2012 10:12 PM #4
    There could also be a piece of gunk or sludge holding the throttle plate slightly open, Iv'e seen that before. If adjusting the idle air screw does not help, I would look at the throttle body.
    Oh and consult your Bently's, pretty sure they have an "idle is too high" section somewhere under trouble shooting.
  5. Member doppelfaust's Avatar
    Aug 15th, 2007
    Tacoma, WA
    1988 Fox GL Wagon
    10-08-2012 11:37 AM #5
    You could have a stuck idle stabilizer valve. Pretty sure since it is Digifant it has a standard ISV like a MK2 Golf or Jetta. They can be cleaned with contact cleaner.
    This may help...
    http://forums.vwvortex.com/showthread.php?2894334
    Apr 16th, 2006
    Brokelyn, NY
    90 fox, 85 gli
    10-08-2012 03:30 PM #6
    Digifoxes have the same idle boost valve(s) + AAR as CIS Foxes. No "fancy" ISV.
    As for being stuck open, the OP says idle drops to normal after warming up, so it is closing enough.
