Results 1 to 10 of 10
Thread: New enland winter + air ride = ??
  1. Junior Member The Fonzz's Avatar
    Mar 16th, 2012
    Fall river, Massachusetts
    (RIP) 97 jetta 2.0, (RIP) 95 jetta VR, 03 jetta AWP
    09-26-2012 06:45 PM #1
    im new to the air ride i was wondering if any one had problems with the lines freezing up or compresser getting too cold, im running a bagriders v2 accuair set up for a daily driver in the harsh new england winters.
  2. Member Bierce IV's Avatar
    Apr 5th, 2010
    NY
    Bagged Blueberry
    09-27-2012 12:52 AM #2
    only real issue i could see if water were to get in the lines/bags. But, that would a while to do damage to the bags. Just empty your traps/tank on a weekly basis and you will be fine.
    Quote Originally Posted by mk4boost View Post
    If you don't want to break the bank you have the wrong hobby
    My Thread
  3. Member MechEngg's Avatar
    Jan 12th, 2009
    Calgary, AB
    09-27-2012 01:13 PM #3
    Havent' experienced any winters on my setup but my plan is to add some fluid to the first buffer tank to prevent the water freezing in the bottom of it and a bit to the water traps. Also empty the tanks very very frequently.
  4. Member Bierce IV's Avatar
    Apr 5th, 2010
    NY
    Bagged Blueberry
    09-28-2012 02:03 AM #4
    is that the stuff used in the truck airlines in cold weather? I was told about that by a local who used it.
    My Thread
  5. Member BMP_3918's Avatar
    Jun 21st, 2011
    Springfield, VA
    2012 VW Jetta SE, 1988 VW Cabby
    10-03-2012 05:54 PM #5
    Quote Originally Posted by Bierce IV View Post
    Yup, just put a little bit inside the air tank worked for me last winter with my MKVI GTI on air
    2005 BLITZ COROLLA - 2001 AUDI A4 QUATTRO - 2003 BMP GTI #3918 - 2008 FORD FOCUS - 2010 BAGGED CW GTI - 1995 370 WHP VRT GTI -2012 BAGGED CW JETTA - 1988 VW CABBY
  6. Member OVRWRKD's Avatar
    Jul 1st, 2010
    Toms River, NJ
    08 CW GTI
    10-04-2012 07:05 AM #6
    You can always add extra water traps if your really concerned. A trap for each compressor and one between your tank and manifold, drain any water from your tank regularly and your system will stay nice and dry. The air brake antifreeze stuff works great, I put a little in every year, but I'm in NJ and it's not that cold.
  7. Junior Member The Fonzz's Avatar
    Mar 16th, 2012
    10-07-2012 07:33 PM #7
    Hey thanks guys for the input.
  8. Member BMP_3918's Avatar
    Jun 21st, 2011
    Springfield, VA
    10-09-2012 04:25 PM #8
    Just to add to this.. what if I don't have water traps?
  9. Member Nanozic's Avatar
    Sep 11th, 2000
    Boston
    2008 R32
    10-09-2012 04:28 PM #9
    Quote Originally Posted by BMP_3918 View Post
    Add them.
    FWIW 2+ years in NE winters and 0 problems.
  10. Member BMP_3918's Avatar
    Jun 21st, 2011
    Springfield, VA
    10-09-2012 04:36 PM #10
    Quote Originally Posted by Nanozic View Post
    Add them.
    Ok, I will do that then. Thanks I had water traps on my MKVI GTI, but not on my MKVI Jetta.
