Results 1 to 10 of 10
Thread: Can anyone help me please?
  1. Member Arman's Avatar
    Jan 27th, 2009
    La Crescenta, CA
    Member Since 2001
    09-27-2012 05:04 AM #1
    Hey, just bought a garrett turbo and the seller told me it is a 50 trim t3t4 garrett. I just want to know the a/r Inside the turbine housing has a stamp that says 48...i dont know if that means anything. On teh side of the exhaust manifold flange it says 29359...Is this a 50 trim .48a/r? or 84 a/r
    05 BMW M3 - 99 GTI VR6 400HP - 02 BT GTI 337
    WWW.EUROMOTIV.COM - EUROPEAN PERFORMANCE PARTS - BEAT THE COMPETITIONS PRICES!
  2. 09-27-2012 01:47 PM #2
    Trim and a/r are different. Trim has to do with the wheel (inducer/exducer)^2. It's just a coincidence in this case that the compressor a/r and trim are both 0.50, if that's what is making you confused. You have a 0.48 a/r exhaust housing. You wouldn't be able to tell the trim on the turbo by looking at it unless you can look up the part number. Otherwise, you would need to remove the housing and measure the wheel
  3. Member Arman's Avatar
    Jan 27th, 2009
    La Crescenta, CA
    Member Since 2001
    09-27-2012 03:21 PM #3
    Its weird because i ran the numbers stamped on the housing it said .84 but the guy i bought it from said its a 50 trim for a srt4
  4. 09-28-2012 02:06 PM #4
    Just show us the hotside.
  5. Member Arman's Avatar
    Jan 27th, 2009
    La Crescenta, CA
    Member Since 2001
    09-28-2012 02:50 PM #5
    i put more pictures up
  6. 09-28-2012 06:10 PM #6
    Hot side looks small def .48 ar
  7. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    01 Jetta Wolfsburg Ed, 92 Honda Prelude Si JDM H22 Swapped
    09-28-2012 08:21 PM #7
    you have some type of t3/t4 there. def .48a/r hotside. run a check on the serial number of that turbo and you should have your answer
    My Thread Fk AK Coilovers, Full 3" Exhaust, Custom FMIC, Forge Evo14 BOV, Forge Unos MBC, Forge Throttle Body Hose, GodSpeed Aluminum Radiator, Prothane Dog Bone Mount, BFI STG 1 Eng/Trans Mounts, Sachs VR6 Clutch Kit, TT Short Shifter, Siemens 630s, Walbro 255, DBB Garrett 50 Trim Turbo Kit, Eurodyne 630cc MAFLESS PAGPARTS FTW -- STEVEBILT.COM -- Integrated Engineering -- FourSeasonTuning.com Don't Buy Anything From *ChunkyPeanuts*
    Jul 31st, 2007
    PR
    98'NB 2.0T
    09-28-2012 10:50 PM #8
    You have a Garrett compressor housing and a Turbonetics turbine housing, i would be curious about what the actual brand of the center section is....
  9. Member Arman's Avatar
    Jan 27th, 2009
    La Crescenta, CA
    Member Since 2001
    09-28-2012 11:11 PM #9
    Thanks for the help guys, i will open it up and check the center. Is there a reason why people put a turbonetics housing? Is there a benefit to it?
  10. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    09-29-2012 01:36 PM #10
    Quote Originally Posted by jose_vw View Post
    this...
    Quote Originally Posted by Arman View Post
    maybe the previous owner needed a new hotside or somthing. or its a turbonetics turbo with garrett compressor housing... what does the plate on the CHRA say? that will tell you what the internals are unless they were changed
