VWVortex.com - GM spot welding Aluminium
    The Car Lounge
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 35
    Thread: GM spot welding Aluminium
      Sep 16th, 2000
      Transitioning
      1994 Land Cruiser
      09-27-2012 08:02 AM #1
      Just saw this article over at GMinsidenews and through it might be interesting to the more cerebral of our members.
      The link...http://www.gminsidenews.com/forums/f...uminum-113610/
      The gist.... GM can now spot weld aluminium reliably. It saves weight on rivits and glue and will probably allow further integration of aluminium structures into future GM vehicles (it is all ready used in some currently in production).
      Cheers
      Chris
    2. Member sicklyscott's Avatar
      Jun 24th, 2002
      Metuchen, NJ
      2015 SS, 2012 S60 T6, 1980 911
      09-27-2012 08:17 AM #2
      Granted I'm not a structural engineer by any means but I thought bonded panels with "glue" was stronger than any spot weld. I can't imagine the weight of the glue adding much. If that's true, I'm confused as to why they even persued this
      1980 911 SC - Black on Red
      Chronicles of my '80 SC: http://forums.pelicanparts.com/porsc...y-80-911-sc-91
    3. Member theAntiRiced's Avatar
      May 6th, 2005
      Baltimore
      09-27-2012 08:18 AM #3
      Yea, but they shouldn't say saving two pounds actually increases fuel economy...
      I sold my bagged VW and bought a 5.0?
    4. Member GoHomePossum's Avatar
      Nov 7th, 2007
      KLPR
      '14 GMC Sierra, '88 Mitsubishi Jeep CJ3B
      09-27-2012 08:25 AM #4
      Quote Originally Posted by sicklyscott View Post
      Welding is cheaper than adhesives, even though adhesives are now the preferred way to bond seams in body shells.
      I now have an InstaGram: emmettlodge
    5. Banned patrickvr6's Avatar
      Dec 29th, 2001
      Marietta GA
      '77 Bronco '85 Toyota 4x4 '87 930 '91 M5 '08 Xterra
      09-27-2012 08:36 AM #5
      Speed. A weld is full strength moments after it is finished while adhesives need time to cure. I would also assume that welding is cheaper and surface prep is easier.
    6. Senior Member
      Jun 10th, 2000
      Motown
      1957 Testa Rossa
      09-27-2012 08:38 AM #6
      A continuously bonded joint would be ideal, but since mainstream vehicles (i.e. not exotic super cars) always have compromises to afford cost savings to customer and OEM... spot welding is the better practice. It is faster (not waiting for adhesive to dry... or bake) and more affordable.
      When you already have tons of spot welding equipment... you want to utilize it and not have to add new processes. When you are building mainstream cars (high volume) you can't afford long cycle times for certain operations.
      What is curious is the tool "dresser" which gives the tips the rings. I wonder how long the tips can go before requiring a dressing. That would impact cost/cycle time.
    7. 09-27-2012 08:45 AM #7
      Good for GM.
      Now lets hope this translates into cheaper(cost not quality) vehicles for us, or at least higher quality for the same price.
    8. Senior Member Air and water do mix's Avatar
      Aug 5th, 2004
      Southern Indiana
      '66 Beetle (X2) '08 Fit
      09-27-2012 08:46 AM #8
      As everyone else has said, it's more about cost than strength. There will likely be places that are still bonded for strength, but if a particular section/assembly/part doesn't need adhesives to meet it's design goals, I'm all for the spot welding technique.
    9. Member GoHomePossum's Avatar
      Nov 7th, 2007
      KLPR
      09-27-2012 09:13 AM #9
      Quote Originally Posted by patrickvr6 View Post
      The seam adhesives used today do not require cure time. Seam adhesives for most manufacturers are now provided by 3M - the most common is 3M's VHB tape, which provides an instantaneous bond.
      Seam sealers - a goo which is laid over floor panel seams on the weather exposed side to prevent moisture intrusion - still require some cure time but are typically "ready" by the time the car is being final QC'd and parked.
    10. Geriatric Member ATL_Av8r's Avatar
      Oct 17th, 2002
      Gapiana
      09-27-2012 09:24 AM #10
      Meh. Call me when they start friction stir welding
      Buy my wife's old laptop!
    11. Member GoHomePossum's Avatar
      Nov 7th, 2007
      KLPR
      09-27-2012 09:34 AM #11
      The Toyota Prius's rear hatch inner and outer skin seams are FSW'd.
    12. Banned patrickvr6's Avatar
      Dec 29th, 2001
      Marietta GA
      09-27-2012 09:35 AM #12
      They are not referring to seam sealers or trim adhesives. They are talking about bonding structural aluminum panels together.
      The ability to weld aluminum body structures and closures in such a robust fashion will give GM a unique manufacturing advantage...
      This new welding process would replace epoxy type adhesives and riveting.
    13. Member GoHomePossum's Avatar
      Nov 7th, 2007
      KLPR
      09-27-2012 09:37 AM #13
      Yeah, that's what I'm talking about too.
    14. Banned patrickvr6's Avatar
      Dec 29th, 2001
      Marietta GA
      09-27-2012 10:09 AM #14
      Ok, show me a manufacturer that tapes structural parts together.
    15. Member atomicalex's Avatar
      Feb 2nd, 2001
      Detroit and Düsseldorf
      dark blue stick shift station wagon, shiny yellow motorbike, dirty green motorbike
      09-27-2012 10:18 AM #15
      "Tape" and tape are not the same thing. And 3M isn't the only game in town - Orbseal invented the seam tape process, and they are part of Henkel now.
      The tapes used for seam sealing and bonding are extruded adhesives without backing material. The word Tape comes from the form it is delivered in, not the traditional tape with a film and adhesive bonded to it.
      Most seam sealers are weld-though, also, and it is unlikely that spotwelding will replace that type of product.
      On a bonded steel unitbody, up to 98% of the seam strength comes from the adhesive. The spotwelds are used to fixture the thing while the adhesive takes its minute to cure.
      A(u). Klasse A, unbeschrankt, ungedrosselt
      Compared to a British roadster, all Volkswagens are reliable!
      nevAr Lose - DE Minister of Foreign Affairs and Deputy Bankruptcy Controller - IPROfftopikstan, Den Mother - Team Emmett
    16. Member curvedinfinity's Avatar
      Oct 11th, 2004
      Highway to the danger zone
      F14 Tomcat
      09-27-2012 10:24 AM #16
      Always learn something from the TCL hivemind
    17. Member GoHomePossum's Avatar
      Nov 7th, 2007
      KLPR
      09-27-2012 10:28 AM #17
      Quote Originally Posted by atomicalex View Post
      Thanks for explaining "tape" better than I can
      Cool, I knew about Henkel/Orbseal but didn't know they had invented the process. We deal almost exclusively with 3M here at our company so it's easy to become "product blind" and think nobody else can offer anything
      I would love to see welding disappear completely from structural body manufacturing, if only as a way to further speed up the manufacturing process. I definitely feel today's adhesives are up to the task. They're used so much already anyways.
    18. Senior Member Air and water do mix's Avatar
      Aug 5th, 2004
      Southern Indiana
      09-27-2012 11:25 AM #18
      Wow. Didn't know that.
      This makes sense. I assume that spot welding would still speed-up/lessen the cost of this phase of assembly though, correct? It would also do so for other non-critical/larger areas, where costs could be better contained.
    19. Member
      May 15th, 2007
      Wilmington, DE
      2012 Jeep Wrangler
      09-27-2012 11:38 AM #19
      Quote Originally Posted by CBJ View Post
      Cheers
      Chris
      But will this save them from needing another bailout?
    20. Banned hognhominy's Avatar
      Jan 31st, 2005
      sleeping at the overlook
      53 Cylinders & 6 turbos
      09-27-2012 12:07 PM #20
      Quote Originally Posted by theAntiRiced View Post
      2 pounds x 15,000,000 new vehicles x 20,000 miles = quite a lot of fuel savings.....
    21. Member Uberhare's Avatar
      Jul 30th, 2003
      Spokane WA
      2012 Golf TDI, 2015 Triumph Rocket 3 Roadster
      09-27-2012 12:13 PM #21
      I think some of you are misreading the article. The article didn't say it would replace adhesives to create body shells. It said the spot welding will be used to replace aluminum rivets. It did not mention adhesives. This technology would be used in addition to adhesives.
    22. Geriatric Member Aonarch's Avatar
      Dec 4th, 2006
      Atlanta, GA
      A Few Alphas
      09-27-2012 12:17 PM #22
      Quote Originally Posted by gambit420s View Post
      Agreed.
      I am all for this.
      Take a direct rationalist approach and weigh the pros and cons, the pros win out.
    23. Senior Member .LSinLV.'s Avatar
      Nov 13th, 2009
      Vegas Bitches!
      12' V6 TDI ........ 00' VR6T ..........72' 914-6.................15' Honda CTX700N
      09-27-2012 12:19 PM #23
      Quote Originally Posted by uncleho View Post
      I appreciate your posts, as they are always informative and based upon ACTUAL knowledge in the industry. (unlike the majority of posts in our beloved forum)
      Larry
      Demokratikally Elekted Minister of Shekels and Cuddles Therapist of the Independent People's Republik of Offtopikstan
      The boobs. I am waiting on the boobs here.
    24. Banned patrickvr6's Avatar
      Dec 29th, 2001
      Marietta GA
      09-27-2012 12:23 PM #24
      The way I read it is that it would replace the rivets in existing panels and allow them to create new panels out of aluminum where before they could only use steel because of limitation of the riveting procedure.
      Current panels would be better and new panels would be possible.
    25. Senior Member
      Jun 10th, 2000
      Motown
      1957 Testa Rossa
      09-27-2012 05:06 PM #25
      Quote Originally Posted by Uberhare View Post
      Agreed. It's always nice to have a lot of options for engineers to choose from. When you think about it... the history/experience/equipment for spot welding is so prolific that it makes a lot of sense to evolve it more in order to incorporate aluminum.
      A lot of people wonder why "new materials" aren't used more often in big MFG industries like autos. The simple answer revolves around the simple fact that A LOT of not only money (processes), but time (experience/know-how) already forms a strong foundation in MFG. And just tossing that aside to jump on something fairly new is risky. New materials are always being tried... and maybe some day something will overtake the traditional methods, but there is a reason why some more traditional methods are so beloved... THEY MEET THE CRITERIA THE INDUSTRY REQUIRES!
      The advent of this will surely help bring aluminum to more and more of what we mainstream customers can afford.
