VWVortex.com - 2012 Tiguan Pano trouble
    Results 1 to 13 of 13
    Thread: 2012 Tiguan Pano trouble
      Nov 2nd, 2006
      South FL
      2012 Tiguan SEL 4Motion
      09-27-2012 04:02 PM #1
      I was trying to code for the fob/rain activated roof, and my roof is not working correctly (via the console switch) now. I'm not sure it ever did, truth be told, because I've only used it once or twice. It does what it is supposed to vie the key fob.
      I guess I want to know what the Cent. Elec. + Centr. Elec. II coding should be for a 2012 Tiguan SEL 4Motion (w/ RVC) should be so I can determine whether it's the coding, or the switch at fault. I know, I know I was supposed to write it down, but I never had any trouble recoding my 09 Tig with the same specs.
      Thanks very much!
      I have included a scan:
      VCDS Version: Release 11.11.4
      Data version: 20120807
      Thursday,27,September,2012,15:52:41:33962
      Chassis Type: 7N0
      Scan: 01 02 03 05 08 09 15 16 17 19 22 25 2B 2E 36 37 42 44 46 47
      4C 4F 52 53 55 56 62 6C 72 77
      VIN: WVGBV7AX4CW609XXX
      01-Engine -- Status: OK 0000
      02-Auto Trans -- Status: OK 0000
      04-Steering Angle -- Status: OK 0000
      05-Acc/Start Auth. -- Status: OK 0000
      08-Auto HVAC -- Status: OK 0000
      09-Cent. Elect. -- Status: OK 0000
      15-Airbags -- Status: OK 0000
      19-CAN Gateway -- Status: OK 0000
      22-AWD -- Status: OK 0000
      2B-Steer. Col. Lock -- Status: OK 0000
      2E-Media Player 3 -- Status: OK 0000
      36-Seat Mem. Drvr -- Status: OK 0000
      37-Navigation -- Status: OK 0000
      42-Door Elect, Driver -- Status: OK 0000
      46-Central Conv. -- Status: OK 0000
      47-Sound System -- Status: OK 0000
      4C-Tire Pressure II -- Status: OK 0000
      4F-Centr. Electr. II -- Status: OK 0000
      52-Door Elect, Pass. -- Status: OK 0000
      53-Parking Brake -- Status: OK 0000
      55-Xenon Range -- Status: OK 0000
      56-Radio -- Status: OK 0000
      62-Door, Rear Left -- Status: OK 0000
      6C-Back-up Cam. -- Status: OK 0000
      77-Telephone -- Status: OK 0000
      Address 01: Engine (CCT) Labels: 06J-906-026-CCT.clb
      Part No SW: 06J 906 027 BH HW: 06J 907 309 A
      Component: MED17.5.2 TFSI 2 04 1119
      Revision: P3H07--- Serial number:
      Coding: 0423010A190F0160
      Shop #: WSC 01357 011 00200
      VCID: 72C515F06D2B8B88271
      No fault code found.
      Readiness: 0000 0000
      Address 02: Auto Trans Labels: 09G-927-750.lbl
      Part No SW: 09G 927 750 LR HW: 09G 927 750 LR
      Component: AQ 250 6F 1971
      Revision: 00H90000 Serial number:
      Coding: 0000840
      VCID: 8C39EB08EFCF7D78CDD
      Address 03: ABS Brakes Labels: 5N0-614-109.clb
      Part No SW: 5N0 614 109 AP HW: 5N0 614 109 AP
      Component: J104 C6 450M VD1C 0005
      Revision: --H07--- Serial number: 00000005707733
      Coding: 0005161
      VCID: 79D722DC305DF8D066B
      Address 05: Acc/Start Auth. (J518) Labels: 5K0-959-434.clb
      Part No SW: 5K0 959 434 B HW: 5K0 959 434
      Component: VWKESSYPQ35GP 085 0902
      Revision: 00085000 Serial number: 0174716423
      Coding: 030C0C
      ASAM Dataset: EV_KESSYPQ35G A02013
      ROD: EV_KESSYPQ35G_VW36.rod
      VCID: 3449D3E89FBFC5B8F5D
      Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
      Part No SW: 5K0 907 044 FE HW: 5K0 907 044 FE
      Component: Climatronic H18 1112
      Revision: 00001004
      Coding: 0000001002
      ASAM Dataset: EV_Climatronic A01010
      ROD: EV_Climatronic_VW36.rod
      VCID: 73CB10F4DA3182802C7
      Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
      Part No SW: 5K0 937 086 N HW: 5K0 937 086 N
      Component: BCM PQ35 M 021 0064
      Revision: BJ021001
      Coding: 6B180ABFC8232EC4008800C134000D4448550006576D8DF0E4 840000A040
      VCID: 3FA38CC4AEF916E018F
      Subsystem 1 - Part No SW: 5N1 955 119 HW: Labels: 1KX-955-119.CLB
      Component: Wischer 07051 013 0203
      Coding: 009795
      Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
      Component: RLS 050512 05 54 0403
      Coding: 02304D
      Address 15: Airbags Labels: 5N0-959-655.lbl
      Part No SW: 5N0 959 655 S HW: 5N0 959 655 S
      Component: J234__20G VW10 HI 2118
      Revision: 24017000 Serial number: 003L6P92CHMV
      Coding: 0012359
      VCID: 4DBFA60CD455B4709A3
      Part No: 5N0 959 339 B
      Component: BF-Gewichtsens. 003 0001
      Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
      Part No SW: 5K0 953 501 BL HW: 5K0 953 569 L
      Component: LENKS.MODUL 014 0140
      Revision: FF010041 Serial number: 20120509300189
      Coding: 110A140000
      ASAM Dataset: EV_VW360SteerWheelUDS A03004
      ROD: EV_VW360SteerWheelUDS_VW36.rod
      VCID: 75CF2EECD4459CB0023
      Multifunction steering wheel control module:
      Subsystem 1 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C Labels: 3C8-959-537.CLB
      Component: E221__MFL-TAS H31 0033
      Coding: 820000
      Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
      Part No SW: 5N0 920 972 E HW: 5N0 920 972 E
      Component: KOMBI H04 0617
      Serial number: 00000000000000
      Coding: 211F01
      ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
      ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
      VCID: 354FEEEC94C5DCB0C23
      Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
      Part No SW: 7N0 907 530 P HW: 1K0 907 951
      Component: J533 Gateway H40 1623
      Revision: H40 Serial number: 050512F2002544
      Coding: 356002
      VCID: 3D5FF6CCA4F504F00A3
      Address 22: AWD Labels: None
      Part No SW: 0AY 907 554 E HW: 0AY 907 554 E
      Component: Haldex 4Motion 0043
      Coding: 0000005
      Shop #: WSC 00000 000 00000
      Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
      Part No SW: 5K0 953 234 HW: 5K0 953 234
      Component: IMMO H04 0617
      Coding: 000007
      ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
      ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
      VCID: EAF58D900DFBC3481F1
      Address 2B: Steer. Col. Lock (J764) Labels: 5K0-905-861.clb
      Part No SW: 5K0 905 861 A HW: 5K0 905 861 A
      Component: ELV-PQ35 H20 0230
      Revision: 00000000 Serial number: 12000096148002
      Coding: 4900000000000000
      ASAM Dataset: EV_ELVMarquMPVW36X A01001
      ROD: EV_ELVMarquMPVW36X_VW36.rod
      VCID: 2E7DC1807193EF68839
      Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
      Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
      Component: SG EXT.PLAYER H13 0240
      Revision: A1001003 Serial number: 7662476482
      Coding: 010000
      VCID: 2977329C407D885056B
      Address 36: Seat Mem. Drvr (J136) Labels: None
      Part No SW: 561 959 760 A HW: 561 959 760 A
      Component: MEM-FS H04 0181
      Revision: AA000000 Serial number: 00000029257885
      Coding: 00581B0000000000000001010101202020202121202020
      VCID: 21672ABC384D40100EB
      Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
      Part No SW: 3C8 035 684 E HW: 3C8 035 684 E
      Component: RNS-MID H65 3696
      Revision: AB001001 Serial number: VWZ6Z7M7131133
      Coding: 0405000201000086000C
      ASAM Dataset: ------------------------- ------
      VCID: 2D7FC68C74959470BA3
      Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
      Part No SW: 5N0 959 701 G HW: 3C0 959 793 C
      Component: TUER-SG FT 002 0503
      Revision: 12110009 Serial number: 0004866262
      Coding: 0015BE
      ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
      ROD: EV_TSGFPQ35BRFVW46X.rod
      VCID: 3957E2DCB8DD38D026B
      Slave Driver:
      Subsystem 1 - Part No SW: 5N0 959 703 G HW: 3C0 959 794 D
      Component: J388__TSG-HL 008 1504
      Serial number: 00000006817445
      Coding: 000490
      Address 44: Steering Assist Labels: 5N1-909-144.clb
      Part No SW: 5N1 909 144 M HW: 5N1 909 148 G
      Component: J500__APA-BS KL.287 1002
      Revision: 1AH03836 Serial number: 00121090323901
      Coding: 0000258
      VCID: 3C59FBC87FEF0DF83DD
      Address 47: Sound System (R12) Labels: 5K0-035-456.clb
      Part No SW: 5K0 035 456 B HW: 5K0 035 456 B
      Component: KonzernAmp 8K 0368
      Revision: -------- Serial number: EAA085A0025712
      ASAM Dataset: EV_AudioVerst8KanalBNO1 A01003
      ROD: EV_AudioVerst8KanalBNO1.rod
      VCID: 2977329C487D885056B
      Address 4C: Tire Pressure II
      Cannot be reached
      Address 4F: Centr. Electr. II (J520) Labels: 1K0-907-532.clb
      Part No SW: 7N0 907 532 HW: 1K0 907 951
      Component: EZE_2 H40 1623
      Coding: 05030100
      VCID: EFC39C843E19266048F
      Subsystem 1 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
      Component: J245EE20SKB13 H03 0220
      Subsystem 2 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
      Component: J394EE20SKB13 H03 0220
      Address 52: Door Elect, Pass.
      Cannot be reached
      Address 53: Parking Brake
      Cannot be reached
      Address 55: Xenon Range
      Cannot be reached
      Address 56: Radio (J0506) Labels: 1T0-035-680.clb
      Address 6C: Back-up Cam.
      Cannot be reached
      Address 77: Telephone Labels: None
      ASAM Dataset: EV_UHVNA A01719
      ROD: EV_UHVNA_VW36.rod
      VCID: 558F4E6CB485FCB0223
      End ---------------------------------------------------------------------
    2. Forum Sponsor Dana @ Ross-Tech's Avatar
      Sep 15th, 2009
      Apollo, PA
      02 Gti, 12 Tiggy SEL
      09-27-2012 05:36 PM #2
      Hello,
      I just picked up a 2012 Tiggy SEL myself and while experimenting with the comfort operation and rain closing I decided to enable comfort roof opening - which is not supported on normal sunroof VW models - and the vehicle was extremely confused!
      This has since sorted itself but comfort opening was closing the roof, closing was making it tip up and the fancy blinds were also confused. If you have had that car locked, which puts the CAN Gateway and all installed modules to sleep, try the normal and comfort functions again and see if this sorted itself. If not, I would gladly post my scan and the 4F-Centr. Electr. II coding would be safe to reference - but the 09 / BCM would NOT be cool to copy from another car.
      VCDS has a coding and adaptation log found by default in the following location: C:\Ross-Tech\VCDS\Debug
      Either paste the factory coding values back into the 09 and 4F modules or post the contents from those logs here for review.
      Dana Marie
      P.S. No Scan = No Soup
      Nov 2nd, 2006
      South FL
      09-27-2012 06:29 PM #3
      Thanks for the info re: the logs.
      On mine, the fob is operating everything as expected (though the rain didn't close the roof as expected), but the overhead switch was only making the roof move sporadically (the screen was acting normally).
    4. Forum Sponsor Dana @ Ross-Tech's Avatar
      Sep 15th, 2009
      Apollo, PA
      09-27-2012 07:00 PM #4
      Okay, I didn't have this issue but I didn't tweak my 4F-Centr. Electr. II coding either. This may be the roof being out of sync rather than coding related, and to be honest I'll need to search for the tech tip from the introduction of the JSW back in 2009 which explains that relearn via inside switch, but post the coding log please.
      Edit. FWIW this is my 4F:
      Component: EZE_2 H40 1620
      Revision: H40 Serial number: 150611F2003544
      Coding: 050B0500
      Shop #: WSC 01324 020 00200
      VCID: EFE653E53E96746048F
      Component: J245EE20SKB13 H02 0220
      Component: J394EE20SKB13 H02 0220
      Dana Marie
      Nov 2nd, 2006
      South FL
      09-28-2012 08:33 AM #5
      Address 09:5K0 937 086 N recoded (Long Coding) from 6F180A1B88232EC4008800C134000D4448550006576D8DF0E4 840000A040 to 6B180A3FE8232EC4008800C134000D4448550006576D8DF0E4 840000A040 (01357/011/00200) Tuesday,25,September,2012,15:13:26:33962
      Address 09:5K0 937 086 N recoded (Long Coding) from 6B180A3FE8232EC4008800C134000D4448550006576D8DF0E4 840000A040 to 6B180A3FC8232EC4008800C134000D4448550006576D8DF0E4 840000A040 (01357/011/00200) Thursday,27,September,2012,15:08:43:33962
      Address 4F:7N0 907 532 recoded (Long Coding) from 050B0500 to 05030100 (01357/011/00200) Thursday,27,September,2012,15:10:30:33962
      Address 09:5K0 937 086 N recoded (Long Coding) from 6B180A3FC8232EC4008800C134000D4448550006576D8DF0E4 840000A040 to 6B180ABFC8232EC4008800C134000D4448550006576D8DF0E4 840000A040 (01357/011/00200) Thursday,27,September,2012,15:18:12:33962
      There were more, but they were from my old one... The first one from the 25th was me originally trying to set it up, the rest on the 27th was me trying to make the rain close happen, the screen not open with fob, and then trying to troubleshoot the switch.
    6. Member Yeti35's Avatar
      May 17th, 2006
      SL, UT
      2010 V6 TDI Touareg
      09-28-2012 10:29 AM #6
      Quote Originally Posted by gilesrulz View Post
      Don't you need a rain sensor to make this work in the first place? I don't think you can activate it if the sensor is not there to begin with. I know with the Touaregs you couldn't get it to work with the rain sensor they had since it was not ever intended to work that way. It could be the same senario with your Tiguan.
      Nov 2nd, 2006
      South FL
      09-28-2012 10:33 AM #7
      This car has a rain sensor (in the SEL), and this functionality does work for this vehicle as far as I know. It worked on my 09, and I have seen no indication that it doesn't continue to work on the 12, in the forums etc.
      Nov 2nd, 2006
      South FL
      09-28-2012 04:27 PM #8
      I think this is sorted. When I went out to my car this afternoon, the roof was working normally, so maybe it was just confused like you said. I ended up recoding to baseline, and then starting again anyway, just to make sure, but I think I am straight.
      thanks!
      Nov 2nd, 2006
      South FL
      09-29-2012 02:45 PM #9
      Looks like I spoke too soon. I got in the car today, and it tilted up no problem. Drove two minutes down the road, and now it won't do anything. Any thoughts on how to relearn the switch?
      Thanks very much.
    10. Forum Sponsor Dana @ Ross-Tech's Avatar
      Sep 15th, 2009
      Apollo, PA
      10-25-2012 10:09 AM #10
      Hi,
      I missed the recent replies here but noticed this older thread yesterday:
      http://forums.vwvortex.com/showthrea...t-but-no-Slide
      ... which reminded me to play with that some more. I have not had any functionality issues since the initial one - but I wasn't able to locate the reset procedure either. Pulling down on the switch for an extended amount of time doesn't do anything and it may be worthwhile to check the owner's manual, but I haven't yet.
      I was able to locate two basic settings last night in the 4F-Centr. Electr. II module, one for the roof and the other for the blinds. Be careful so you don't get pinched but my testing went as follows:
      Code:
                      Address 4F: Centr. Electr. II  (7N0 907 532 )
      20:25:34 Group 001: Sun Roof
        0.0 %  Sun Roof Position
        Tilt position  Sun Roof Position
        Normed  Sun Roof Normalization
        Learned  Sun Roof Learn. Sequence
      20:25:38 Group 002: Sun Roof
        Inactive  Sun Roof Reversing
        Inactive  Sun Roof Thermal Protection
      20:25:45 Group 003: Sun Roof - Switch for Push-Out Position
        Not Oper.  Sun Roof Switch "OPEN"
        Not Oper.  Sun Roof Switch "CLOSE"
        Normal  Sun Roof Switch ERROR
        Closed  Sun Roof Switch PRESELECT
      20:25:58 Group 008: Roof Blinds
        51.0 %  Roof Blinds Position
        Slid position  Roof Blinds Position
        Normed  Roof Blinds Normalization
        Learned  Roof Blinds Learn. Sequence
      20:26:01 Group 009: Roof Blinds
        Inactive  Roof Blinds Reversing
        Inactive  Roof Blinds Thermal Protection
      20:26:05 Group 010: Roof Blinds
        Not Oper.  Roof Blinds Switch "OPEN"
        Not Oper.  Roof Blinds Switch "CLOSE"
        Normal  Roof Blinds Switch ERROR
      20:26:07 Group 011
        Not Oper.
        Not Oper.
        Normal
      20:26:31 Group 001: Sun Roof
                      Address 4F: Centr. Electr. II       Labels: 1K0-907-532.CLB
      Control Module Part Number: 7N0 907 532     HW: 1K0 907 951
        Component and/or Version: EZE_2         H40 1620
                 Software Coding: 05030100
                  Work Shop Code: WSC 01324 020 00200
                            VCID: EFE653E53E9674490E
      1 Fault Found:
      01512 - Control Module for Sliding Roof
                  005 - No or Incorrect Basic Setting / Adaptation - Intermittent
                   Freeze Frame:
                          Fault Status: 00100101
                          Fault Priority: 2
                          Fault Frequency: 2
                          Reset counter: 102
                          Mileage: 17174 km
                          Time Indication: 0
                          Date: 2015.14.04
                          Time: 20:25:39
      Address 4F: DTCs cleared
      Fault Codes have been Erased
      20:27:28 Group 003: Sun Roof - Switch for Push-Out Position
        51.0 %  Sun Roof Switch "OPEN"
        Slid position  Sun Roof Switch "CLOSE"
        Normed  Sun Roof Switch ERROR
        Learned  Sun Roof Switch PRESELECT
      20:27:47 Group 003: Sun Roof - Switch for Push-Out Position
        0.0 %  Sun Roof Switch "OPEN"
      1 Fault Found:
      02907 - Control Module for Roof Shade (J394)
                   Freeze Frame:
                          Fault Priority: 2
                          Fault Frequency: 1
                          Reset counter: 102
                          Mileage: 17174 km
                          Time Indication: 0
                          Date: 2015.14.04
                          Time: 20:26:37
      Although I'd like to tinker some more try 4F: Centr. Electr. II > Basic Settings > Group 001 > Go > On/Off/Next (it took more than on click to get it ON) > watch out because the roof begins to move.
      Dana Marie
    11. Member
      Nov 30th, 2011
      2012 Passat V6 SEL Prem/Nav; 2012 Tiguan SEL Prem/Nav
      10-25-2012 07:35 PM #11
      Search my topics/posts too... I initially had some issues w 2012 SEL limited (no RVC) pano. Tilt vs slide, key fob vs Kesey comfort up/diwn and rain close. Got them all sorted... Don't remember off the top my head how...This was 9mths-1yr ago. Try both here an Tig forums... Maybe even Passat forums (I've got both some I typed both car into only one forum).
      Nov 30th, 2011
      10-25-2012 07:36 PM #12
      And relearning was involved, via procedure in manual twist and hold button certain way....but I also did via VCDS basic settings just to tech myself more of VCDS.
    13. Member
      Nov 2nd, 2006
      South FL
      10-26-2012 08:47 AM #13
      I ended up having a bad switch. I haven't gotten back to the vcds changes though.
