VWVortex.com - Question about camshaft..
    Results 1 to 9 of 9
    Thread: Question about camshaft..
    1. n00b
      Sep 27th, 2012
      Corozal, Puerto Rico
      1987 Fox waGON
      09-27-2012 07:49 PM #1
      Whell as the title said i have q question as what camshaft shoud i use. Im rebuilding a 1.8 8v from a cabrio mk2 to transfer to my fox wagon.. it has a solid lifter head . Im convertig the engine to a doble carburator sistem (delorto 40 side draft) its goin to be a daly driver. So mi question is does the stock camshaft works with that setup of carburators or do i have to install a new one ? If yes, what camshaft is the best ( numbers ) for a daly driven car, i dont whant to race in the wagon but i would like that it runs nicely and has a nice idle,nothing to agresive...
      any healp will be deeply apreciated
      Apr 16th, 2006
      Brokelyn, NY
      90 fox, 85 gli
      09-27-2012 11:44 PM #2
      Yes, you can use the stock cam with carbs.
      If you wanted to upgrade on the cheap, you can try to find a cam off an RD motor (86-87 1.8l 8v gti/gli).
      Otherwise, there's the 268* cam that should give you the power it should have had all along.
      If you don't mind upgrading the valvetrain, the 276* is highly recommended, especially with carbs if you don't mind setting the idle a little higher and having a slight lump. The power is great from what I hear.
      As far as cabriolets go, there wasn't one based on the A2 platform.
      What year is the cabrio? I'm assuming later on with digifant / hydraulic lifter head?
      For the Fox, a nice upgrade would be sourcing a dual outlet manifold and corresponding downpipe (custom if need be). It's really necessary to open up the higher revs.
      I really suck at smog.
    3. n00b
      Sep 27th, 2012
      1987 Fox waGON
      10-01-2012 06:57 PM #3
      i have an 86 gti engine in my shop so maybe it has the camshaft that you say..i goin to take it out an comparing the two.. as for the exaust im making a custom headder from scratch.. thankz for the healp brow..
    4. Member
      Mar 31st, 2008
      PNW - Oregon
      10-02-2012 03:12 PM #4
      Quote Originally Posted by R.A.G. View Post
      86 GTI would most likely have an A grind..
      not a 268*
      any stock US SPEC VW cam is NOT performance oriented..
      Apr 16th, 2006
      Brokelyn, NY
      90 fox, 85 gli
      10-02-2012 03:13 PM #5
      edit: http://www.techtonicstuning.com/cams.html
      G
      whoa didn't realize PF and RV use the same cam.
      It's true it's still quite mild, but compared to the other OEM offerings in America, it's the "best" bet if the budget is $0-20.
      edit2: oh ****, I just remembered you have a solid lifter head. do not use the hydro cam.
    6. Member
      Mar 31st, 2008
      PNW - Oregon
      10-06-2012 03:08 PM #6
      Quote Originally Posted by ziddey View Post
      G
      yup, solid lifter heads need solid lifter valves..
      if you put a hydro cam in a solid head, it will make the worst clatter you have ever heard in your entire life..
    7. Member .:RDUBBIN's Avatar
      Jun 27th, 2008
      Seattle, WA
      11-04-2012 10:44 AM #7
      Quote Originally Posted by Glegor View Post
      What about the other way around? Solid lifter cam in a hydro head?
      Current: '82 Caddy, '15 Golf,
      Previous: '12 GTI, '10 CC, '04 R32, '57 Oval, '05 GLi, '01 A4, '97 Jetta, '64 Bettle, '00 Jetta, '01 Beetle, '84 GTI, '12 Touareg, '00 TDI, '80 Caddy, '14 Passat, '14 Beetle
    8. Member LT1M21Stingray's Avatar
      Sep 13th, 2006
      Foothills of the Adirondacks.
      SR71 C30 t53a/b
      11-06-2012 08:54 AM #8
      From my experience, the 276 cam will only work great if you have lots of mods, like increased displacement, head work, etc. Otherwise you will loose too much bottom end/torque, and it will not wake up the motor in the top end.
      Always be conservative when choosing your cam.
      Quote Originally Posted by Tavarish
      The car's best safety feature includes ejecting you in the moment of impact and wishing you the best of luck.
    9. Member LT1M21Stingray's Avatar
      Sep 13th, 2006
      SR71 C30 t53a/b
      11-06-2012 08:59 AM #9
      Quote Originally Posted by .:RDUBBIN View Post
      Solid cams and hydro cams don't have the same base circle. Just don't mix them, it will not work.
