Results 1 to 16 of 16
Thread: CC turn off while driving.
  1. 09-28-2012 10:52 AM #1
    Hi,
    I have a problem with my CC 2011 with 18,000 miles. (2.0 T DSG)
    It happens 3 times, while I´m driving like at 18 mph, it turns off sporadically.
    I already scan the car, and non error registered. Has anyone has the same problem??
    What could it be?
    I still have warranty, but I want first a diagnostic before I left the car at the dealer, because sincerely I don´t trust them at all.
    Thank you for your help.
  2. Junior Member
    Jul 3rd, 2012
    West of Boston
    2013 VW CC Sport, 6spd MT
    09-28-2012 12:45 PM #2
    Quote Originally Posted by chicositos View Post
    Hi,
    What could it be?
    Did you use a quality scan tool like VCDS (Ross-Tech) vs. a generic OBDII scanner?
    This'll be a tough one for the dealer to diagnose if nothing is flagged in the control modules and they have nothing to go on
  3. 09-28-2012 02:19 PM #3
    Yes I did use VCDS 10.8
    Regards
  4. Member dcbc's Avatar
    Sep 14th, 2011
    Texas
    2010 CC Sport 2.0T (6M)
    09-28-2012 07:57 PM #4
    I had something like this happen when I didn't get the hose clamp back on correctly after installing a CAI. The clamp behind the MAF was loose and the MAF was basically throwing its hands in the air. Car would go dead when I came off the gas.
    2010 CC Sport 6MT, Clear turns, Modshack Intake, Unitronic Stage 1+, RNS 510 Upgrade, 9W7(L) upgrade, 10 spkr Audio Upgrade with Amp and 10" sub.
  5. 09-28-2012 08:46 PM #5
    Thank you, but I don´t think is that, your check engine was lighting?
    It feels, like when you release the clutch.
    I feel it maybe be 3 things:
    Alternator
    Crankshaft sensor
    DSG mechatronics
    I hope is not the mechatronics, because it shifts perfectly, and I don´t have any error at the scan.
    HELPP!!!
  6. Member CC U L8TR's Avatar
    Aug 3rd, 2010
    2010 CC R-line
    09-28-2012 10:08 PM #6
    PM sent
  7. Member new2me's Avatar
    Feb 28th, 2012
    Morris, IL.
    09' VW CC 2.0T/80' XS1100 rolling project
    09-29-2012 09:29 AM #7
    There is a recall on the ignition module. Have the dealer check your VIN to see if it qualifies.
    Hex-Can+USB Vag-com
  8. Member dcbc's Avatar
    Sep 14th, 2011
    Texas
    09-29-2012 11:34 AM #8
    Alternator
    Crankshaft sensor
    DSG mechatronics
    HELPP!!!
    No check engine light in my situation. But it's an easy thing to check to make sure there's nothing interfering with the MAF. So I figured I'd mention it.
  9. n00b dasautocc's Avatar
    May 4th, 2011
    Miami, Fl
    2011 Candy White VW CC Sport AT
    09-29-2012 11:11 PM #9
    i had the same thing happen to my CC. I have a 2011 2.0 DSG. It happens to me when im in heavy stop and go traffic. As im slowing down to a stop the engine stalls and the parking brake engages. i have to shift to P, restart the engine and release the parking brake. All in the middle of traffic.
    I took it to the dealer and they said they reflashed the tranny. Drove it out of the dealer and it happened again.
    I took it back to the dealer but they couldnt replicate the problem so they didnt know what to fix. but they happened to find something wrong with the fuel pump so they replaced that.
    i havent driven in stop and go traffic since then so i dont know if its fixed. it only occurs in heavy traffic with the a/c on.
    hope this helps
  10. n00b dasautocc's Avatar
    May 4th, 2011
    Miami, Fl
    09-29-2012 11:12 PM #10
    by the way the dealer said there were no hard codes and i never got a CEL.
  11. Junior Member
    Sep 10th, 2012
    '10 VW CC 2.0T
    09-30-2012 05:14 PM #11
    I would say it is the alternator, or a huge vacuum leak. How does it die? Does it just cut out, or does it putter into a stall?
  12. n00b dasautocc's Avatar
    May 4th, 2011
    Miami, Fl
    09-30-2012 05:59 PM #12
    motor stalls completly like a manual transmission car when you dont push the clutch to stop.
  13. Junior Member
    Sep 10th, 2012
    '10 VW CC 2.0T
    09-30-2012 09:24 PM #13
    I have had some horrendous vacuum leaks that have caused this to happen - boost gauge will show this, but this is doubtful. I am not familiar much with the DSG, but mine has already done some strange things.
    I would test this by driving in tiptronic mode, or whatever the VW term, if that is incorrect.
    Edit:
    I have read that the mechatronic unit can cause false neutrals and jerking shifting. I am up against the dealer on the jerking and lurching. Hoping to get that replaced.
  14. 10-01-2012 04:19 PM #14
    Thanks for your replys,
    I think is not going to be easy to find the problem, at least is happens like once in a week, but on friday I have my appointment at the dealer to check out what it is, I hope they can fix it.
    I let you know the advance.
    Regards
  15. n00b dasautocc's Avatar
    May 4th, 2011
    Miami, Fl
    10-04-2012 02:42 PM #15
    happened again yesterday in traffic i guess its back to the dealer for the third time...
  16. 10-09-2012 11:24 PM #16
    Well, here are the updates.
    I took my car to the dealer, and guess what, they didn´t find anything!!
    In the last days, I made the basic setting to the DSG, and after that it seems to works perfectly.
    Any advance I let you know.
    Rgds
