Results 1 to 5 of 5
Thread: Belt shredding after AEB swap with ABA acc's
  1. Member johnsomj's Avatar
    Feb 2nd, 2008
    PNW, 206
    '92 GTi 1.8T
    09-28-2012 11:34 AM #1
    I did this swap, AEB into my MKII GTI, it hums, it's fast, it's light and still corners really well super happy with it!!! Great decision. I run ABA hardware on the engine, and put a spacer inbetween the pully that doesn't quite allign properly... here's where it gets tricky. I have this all done, but now i'm shredding belts after driving for a few days, and i think it's because the tensioner isn't alligned properly. I can't remember off the top of my head the size of the belts I'm using, but i know that i had to switch to a longer length by a mm just to get the belt on after i shredded the first one. I think that belt was too tight and ruined the alignment of my tensioner, but now i have a whole new problem and turning to the advice of those who've come before me. Anyone run into this problem before or have any advice???
  2. Member sdezego's Avatar
    Apr 23rd, 2004
    Hurricane Central FL
    '90 Corrado | '62 Harley Panhead
    09-28-2012 03:48 PM #2
    What Crank Pulley are you running? Sounds like something is not right there.
    ABA pulley must be properly shaved and centered 5.8mm for use on a 16v/20v
    S
    Build: Project sc2020
    My G60 now on MS3 | 4Cyl Torque Plate Rental | 02M Mounts
  3. Member johnsomj's Avatar
    Feb 2nd, 2008
    PNW, 206
    '92 GTi 1.8T
    10-03-2012 03:30 PM #3
    That's good info, i'll try to do a little more research.
  4. Member johnsomj's Avatar
    Feb 2nd, 2008
    PNW, 206
    '92 GTi 1.8T
    10-18-2012 01:38 PM #4
    i'm an idiot. It's not the toothed belt that's shredding, it's the serp belt driving the acc's.
  5. Member BARELY LEGAL's Avatar
    Jul 2nd, 2009
    Cincinnati, OH
    '81 Jetta Coupe | '04 .:R32 | '91 318i
    10-19-2012 05:23 PM #5
    You can use a modified Bahn Brenner crank pulley typically meant for 16v swaps. That's what I used on my AEB swap running ABA bracket, tensioner, and alternator.
    The nice thing about the BBM pulley is that they machine it to fit a locating ring in the center. This keeps the pulley true to the crank and free of vibration.
    Cin City
