VWVortex.com - Help..... 1.8t running very rough at idle, replaced much to no avail......
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 30
    Thread: Help..... 1.8t running very rough at idle, replaced much to no avail......
    1. 09-28-2012 05:17 PM #1
      2002 Jetta 1.8t. 122k miles. Replaced timing belt, water pump, tensioner, idler pully (checked timing as well, is dead on)
      Replaced throttle body, no change.
      Replaced spark plugs, didn't find any vacuum leaks (going to pressure test today)
      Tried replacing coil packs... No change.
      Replaced Camshaft position sensor, no change.
      Car seems to run great over 2000RPM, but will not idle.
      Autoscan seems to lead me in 10 different directions. Replacing fuel filter today. Please help.
      Here is the first autoscan (throttle body was out of the car)
      Thursday,20,September,2012,18:14:02:55851
      VCDS Version: Release 11.11.4
      Data version: 20120807
      Chassis Type: 9M - VW Jetta IV
      Scan: 01 02 03 08 09 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57
      75 76
      VIN: 3VWSE69M42M080838 Mileage: 196730km/122242miles
      Address 01: Engine Labels: 06A-906-032-AWP.lbl
      Part No: 06A 906 032 LQ
      Component: 1.8L R4/5VT G 0007
      Coding: 07550
      Shop #: WSC 23328
      VCID: 78FF5D43580960D8195
      3VWSE69M42M080838 VWZ7Z0A4057787
      6 Faults Found:
      16684 - Random/Multiple Cylinder Misfire Detected
      P0300 - 35-00 -
      16685 - Cylinder 1
      P0301 - 35-00 - Misfire Detected
      16687 - Cylinder 3
      P0303 - 35-00 - Misfire Detected
      17951 - Angle Sensor 1 for Throttle Actuator (G187)
      P1543 - 35-00 - Signal too Small
      17580 - Angle Sensor 2 for Throttle Actuator (G188) Signal too Low
      P1172 - 35-00 -
      17987 - Throttle Actuator (J338)
      P1579 - 35-00 - Adaptation Not Started
      Readiness: 0110 1101
      Address 02: Auto Trans Labels: 09A-927-750.lbl
      Part No: 09A 927 750 T
      Component: AG5 Getriebe 09A 0162
      VCID: 3C7781532CB18CF83DD
      3 Faults Found:
      01166 - Engine Torque Signal
      16-00 - Signal Outside Specifications
      00526 - Brake Light Switch-F
      28-10 - Short to Plus - Intermittent
      01045 - Tiptronic Switch (F189)
      27-10 - Implausible Signal - Intermittent
      Address 03: ABS Brakes Labels: 1C0-907-37x-ASR.lbl
      Part No: 1C0 907 379 K
      Component: ASR FRONT MK60 0103
      Coding: 0018945
      Shop #: WSC 00066 000 00000
      VCID: 326BAF6BAEF54A88E71
      1 Fault Found:
      01314 - Engine Control Module
      013 - Check DTC Memory
      Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
      Part No: 6Q0 909 605 F
      Component: 04 AIRBAG VW6 0202 0004
      Coding: 12340
      Shop #: WSC 00066
      VCID: 3A7B874B2685B2C82F1
      1 Fault Found:
      00532 - Supply Voltage B+
      07-10 - Signal too Low - Intermittent
      Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
      Part No: 1J0 920 906 N
      Component: KOMBI+WEGFAHRSP VDO V59
      Coding: 07234
      Shop #: WSC 00000
      VCID: 3365AA6F01EF4380EC7
      No fault code found.
      Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
      Part No: 6N0 909 901
      Component: Gateway KCAN 0001
      Coding: 00006
      Shop #: WSC 00066
      VCID: F0EFE563B079B898515
      Address 46: Central Conv. Labels: 1C0-959-799.lbl
      Part No: 1C0 959 799 C
      Component: 1H Komfortger·t HLO 0003
      Coding: 00258
      Shop #: WSC 00066
      VCID: 377D9E7F1597AFA0D0F
      Subsystem 1 - Part No: 1C1959801A
      Component: 1H Tırsteuer.FS KLO 0002
      Subsystem 2 - Part No: 1C1959802A
      Component: 1H Tırsteuer.BF KLO 0002
      Subsystem 3 - Part No: 1C0959811A
      Component: 1H Tırsteuer.HL KLO 0002
      Subsystem 4 - Part No: 1C0959812A
      Component: 1H Tırsteuer.HR KLO 0002
      Address 56: Radio Labels: 3B7-035-1xx-56.lbl
      Part No: 3B7 035 180
      Component: Radio NP2 0005
      Coding: 00031
      Shop #: WSC 00066
      VCID: DDB1ACD757EB25F0EA3
      End ---------------------------------------------------------------------
    2. 09-28-2012 05:17 PM #2
      These are the codes I am currently getting from the ECM
      Control Module Part Number: 06A 906 032 LQ
      Component and/or Version: 1.8L R4/5VT G 0007
      Software Coding: 07550
      Work Shop Code: WSC 23328
      Additional Info: 3VWSE69M42M080838 VWZ7Z0A4057787
      13 Faults Found:
      17972 - Throttle Actuator (J338)
      P1564 - 35-10 - Under-Voltage during Basic Setting - Intermittent
      P1543 - 35-10 - Signal too Small - Intermittent
      P1172 - 35-10 - - Intermittent
      P0300 - 35-00 -
      16685 - Cylinder 1
      16687 - Cylinder 3
      16486 - Mass Air Flow Sensor (G70)
      P0102 - 35-10 - Signal too Low - Intermittent
      18032 - MIL Request Signal Active (Check TCM for errors too!)
      P1624 - 35-00 -
      16688 - Cylinder 4
      P0304 - 35-00 - Misfire Detected
      16686 - Cylinder 2
      P0302 - 35-00 - Misfire Detected
      17763 - Cylinder 1 Ignition Circuit
      P1355 - 35-10 - Open Circuit - Intermittent
      17766 - Cylinder 2 Ignition Circuit
      P1358 - 35-10 - Open Circuit - Intermittent
      17769 - Cylinder 3 Ignition Circuit
      P1361 - 35-10 - Open Circuit - Intermittent
    3. Member BassNotes's Avatar
      Mar 15th, 2005
      Costa Mesa, Calif., USA
      2002 VW GTI 1.8t
      09-28-2012 09:36 PM #3
      Clear the fault codes and run a throttle body adaptation.
      Bob Lee
      2002 GTI 1.8t 262,000+ miles
      VCDS 15.7.3 with KEY-USB interface
    4. Member Freddy24's Avatar
      Oct 16th, 2011
      Chicago, IL
      2001 GTI
      09-29-2012 02:48 AM #4
      Quote Originally Posted by BassNotes View Post
      01 GTI 10/14/11
      Gonzo Tuned
      Quote Originally Posted by boradie sucht View Post
      what good does searching do anymore? say in 2 years when new people come on and have questions and decide to search first. and then this thread pops up, when its all idiots like you telling him to search. whats the point of that, either contribute or STFU
    5. 09-29-2012 05:44 PM #5
      Ran a throttle body adaptation. No change.
      Car is trying to idle around 950rpm.
      Runs very rough. Feels like its only firing on 2 cylinders. Replaced fuel filter today. No change.
      Could it just be bad gas? There were a few gas stations around my area that recently went through some gas issues..... At this point I am just searching.
    6. Member Vegeta Gti's Avatar
      Feb 12th, 2003
      konoha village, hawaii
      1984 GLi 20v, '16 M3, '85 Golf, '03 BMP 20th AE
      09-29-2012 06:05 PM #6
      unplug your MAF and drive around, tested/checked your front O2? what are your plugs gaps? how is the front O2 wiring? what is wired into the car..aftermarket stereo,etc?
      :HOMEGROWN MOTORSPORTS:1:4.9 SuaSponte #13Dead Rabbits. Ungluck on IG. MKIforLife
      Quote Originally Posted by .Ant View Post
      What vegeta said.
    7. 09-29-2012 06:14 PM #7
      Tried driving with the MAF unplugged. No change.
      O2 sensor wiring is good. Will check the front O2 sensor now. Plugs are gapped at .032
      Car is totally stock. No aftermarket anything.
    8. Member Freddy24's Avatar
      Oct 16th, 2011
      Chicago, IL
      2001 GTI
      09-29-2012 08:44 PM #8
      Quote Originally Posted by J.schaef View Post
      Maf could be bad
      01 GTI 10/14/11
      Gonzo Tuned
    9. 09-30-2012 12:30 AM #9
      Cleaned MAF, no change. Will try a known good MAF.
    10. n00b
      Sep 23rd, 2012
      Murfreesboro, TN
      2002 Turbo S, 2003 NBC, 2010 Jetta TDI Cup
      09-30-2012 05:46 PM #10
      Well this probably does not help but it looks like you are having some very similar problems as I am, codes are very similar also. I have been working on this problem for 2 months or more now with no resolve.
      Look at my post; http://forums.vwvortex.com/showthrea...2#post79079252
      Maybe we can compare notes...
      K
    11. Member 1fast2liter's Avatar
      Apr 4th, 2005
      beaver dam WI
      2000 audi tt 180q
      09-30-2012 05:53 PM #11
      try cleaning the throttle body. also do you ave te updated coolant temp sensor?
      infinity front and sides,votex rear,st coilovers,eurodyne tapp 1000cc tuned,hks ssq bov, pte 5857 pagparts turbo kit with 38mm tial wastegate. spec stage 3, custom intake, bbm fuel rail, billy boat 3in exhaust,ecs bleeder block,mbc,fmic,bfi mounts,cm flywheel,front mount interccoler, aeb head cat 3652 cams, scat rods je pistons super tech valves and springs.
    12. 09-30-2012 06:34 PM #12
      Quote Originally Posted by 1fast2liter View Post
      Throttle body is new. Ran TBA with no change.
      Will check the coolant temp sensor tomorrow, see if it is the updated one. I am at a total loss. Inspected the vacuum system. Replaced the 2 way valve, and 2 check valves. Found 2 fairly large leaks.
      Fixed all vacuum issues I found, no change.
    13. Member 1fast2liter's Avatar
      Apr 4th, 2005
      beaver dam WI
      2000 audi tt 180q
      09-30-2012 06:42 PM #13
      is this all the time or just on start up r when ever car is left ti idle?
    14. 09-30-2012 06:45 PM #14
      It is all the time at idle.
    15. Member BRES's Avatar
      Jul 24th, 2009
      Mk4 GTI, C7 3.0T Quattro, 335i
      09-30-2012 08:14 PM #15
      I had bouncy idle problems and mk6 coils fixed that.
      Sent from iPhone 4S.
      2011 335i Alpine White Loaded (his)
      2013 A6 Glacier White Metallic 3.0T Quattro Prestige (her's)
      MK4 GTI 1.8T with goodies (garage queen)
    16. Member VWBugman00's Avatar
      Mar 16th, 2009
      Kennewick Wa
      00 Beetle
      10-01-2012 01:36 PM #16
      Quote Originally Posted by BRES View Post
      Mk5's will work too. And they're about $25 each at autozone with a year warranty.
      2000 Beetle, 1991 CR-X, 2005 Chevy Malibu 3.5 LS, 1988 F-150 (R.I.P)
    17. 10-01-2012 02:17 PM #17
      I tried 2 sets of new coils, both provided no change.
    18. Member Slimjimmn's Avatar
      Apr 8th, 2006
      Rochester, MN
      MK4 shaggin wagon
      10-01-2012 03:34 PM #18
      Is your coil pack harness cracked? Do a search
      Also have you done A COMPRESSION test?
      the car is on an inclined driveway and up on jack stands in the front only
      04 Jetta Wagon 2.slow------>Family man now
    19. Member groggory's Avatar
      Apr 21st, 2003
      Long Beach, CA
      2002 VW GTI 1.8 BT
      10-01-2012 03:43 PM #19
      Sounds like you need to check all your positive and ground terminals throughout the car.
      There is a grounding section of the FAQ that details all the points.
      Please check your grounds with a voltmeter and keep an accurate log of what you checked and what voltage you read. Post up your exact results.
      My Build
      Welcome to the world of racing! Budgets are ALWAYS exceeded, deadlines are never met, end-goals never reached, and wives always unhappy... it's all worth it though!
    20. Junior Member livef4st's Avatar
      Aug 15th, 2012
      DFW, TX
      2005 VW Jetta GLI
      10-01-2012 04:47 PM #20
      Glad to see a full scan.
      What does measure block 32 say?
      also, measuring blocks 15 and 16 at idle.
    21. 10-01-2012 04:51 PM #21
      Quote Originally Posted by Slimjimmn View Post
      I searched cracked coil pack harness, I will investigate that if nothing else solves the problem. It seems to have just suddenly started about 2 weeks ago, for no apparent reason.
      Yes, compression is high and even across all 4.
      Quote Originally Posted by groggory View Post
      Will check my grounds, log my results today and report back.
      Quote Originally Posted by livef4st View Post
      Will check these today as well.
      Thanks for your help and suggestions everyone.
    22. Senior Member VW1990CORRADO's Avatar
      Sep 30th, 2000
      Billerica,MA/autoengineering.com
      3 cars, 3 turbos, and a V8
      10-01-2012 11:15 PM #22
      same issue on a friends 04.5 gli
      -Rick
      NOW mine2002 Gti 337 PTE5857B,2008 RS4,2008 Ibis Audi A4 Ti hers2010 Tiguan SEL
      THEN 2001 S4 90 corrado,90 gti vr6, 95 golf sport+many,many more..
      www.autoengineering.com
    23. Member Slimjimmn's Avatar
      Apr 8th, 2006
      Rochester, MN
      MK4 shaggin wagon
      10-03-2012 11:59 PM #23
      I just replaced my worn out cracked coil harness and its like night/day difference.
    24. Member
      Jan 4th, 2007
      MA
      2004 Jetta GLS 1.8T
      10-09-2012 11:55 AM #24
      did you try cleaning the MAP sensor and the intercooler?
    25. Member JColleran1991's Avatar
      Apr 21st, 2012
      Cleveland, Ohio
      2003 Jetta Wagon TDI, 2004 Touareg V10 TDI, 2005.5 Jetta 2.5
      10-24-2012 04:30 PM #25
      Quote Originally Posted by Vegeta Gti View Post
      Sorry to threadjack, but why did you ask if the OP has an aftermarket stereo? I didn't realize that can make a difference in an idle. The idle on mine is a little rougher than I think it should be and I have an aftermarket stereo, amp, sub, bi-xenons, and an alarm with remote start. Could any of these factors be causing my rough idle?
