explain this adjuster falling out. how did u put it back in? This may help me a bit.
#1
So I went ahead and bought these replica HID/LED headlights from ebay. They are also available to alibaba.oom
At first I was skeptical on ordering them because they were coming from china, and it did not seem like many of them were sold. I did some research on them, and they are actually made of good quality materials.
The clear headlight lens is made out of PC plastic, which is the kind of plastic that OEM uses, the projector is a Bosch 2nd generation projector, which by the way have excellent light output and a cutoff. The HID kit which comes with these headlights is a Phillips HID kit, which is pretty nice.
The fitment of these headlights is not 100%, but it is VERY close to being an exact fitment. The only spot which they do not fit with 100% is by the fender, and it is not noticeable at all. 99% fitment.
The only issue I had with these headlights is that one of them would not adjust, but that was my fault because I turned the adjustor too far, and it came out of the socket, which was easy to put back in. All you have to do to put it back in if it happens is take off the cap on the back of the headlight, and pull the plastic back of the projector onto a white ball looking leveler. Just connect those two back together and it will work again.
As for the error codes, on the GLI I get bulb out error for the left and front side light, other than that, I do not get any errors. But it might be different on the regular Jetta. You will need to use VAG-COM in order to enable HID headlights with Bi-xenon, and also to enable xenon with shutter in order for them to work properly.
The seller always kept good communication throughout the process, and would always tell me the status of the shipment. It did take a little while for them to get here but that is only because they were back-ordered, but once they shipped, I received them in only 4 days.
The LEDs are pretty bright, obviously not as bright as the OEM headlights, but they are bright enough to where you can see them during the day, and they are pretty bright at night. The projector in these headlights is awesome, and the light output is great with a very clean cut off. The LEDs function as the city lights, and they do stay on when the HIDs are on. The only difference between these headlights and the OEM ones is that there is no orange reflector in them, but it is instead smoked, and also the bottom part of the projector housing is flattened instead of round. The color temperature of the HIDs is 5000K which is extremely white, it looks like day light!
Overall, I would highly recommend these headlights if you are looking for an OEM look headlight without the OEM price. They are worth the price to pay, and they look great.
Here are a few pictures with just the LEDs on.
Here are some with the HIDs on
Some of the fitment
Some night shots.
#2
#3
Flippinnnn awesome!!! They look great!!!now I can't wait to get mineeee
great review
2012 Candy White GLI
Follow me onInstagram! @mandi_mkvi
#5
I added some night shots, so those are up.
As for the price, they very from $650-$800 depending on who you get them from.
Repair for the height adjustment added!
#6
#9
Yes, I'm just not sure how to remove them with vagcom, I have rosstech helping me out with the coding.
#10
Does it have leveling motors? and does it auto level on start up?
#11
I believe they do have leveling motors, but no, they do not auto level on start up. There might be a way to do it through VCDS, but I am not sure on how to yet. I will mess around with it some more a little later.
#12
#13
If you finding out about the leveling in vcds, I'd love to hear what you find.
#14
Would be nice if you posted actual cutoff line shots against a wall instead of only on the ground. The pics you have make it seem the beam angles from low to super high from right to left. Go to a wall and park 30ft to 50ft away and take shots. That's the only specified way to judge good cutoffs.![]()
#16
Which ones are threse exactly? Win Power Sagitar? Have a link?
#17
Yes, they are the ones form winpower. I got them here.....
http://www.ebay.com/itm/160878206622...84.m1423.l2649
#20
#22
Can't decide on this, or finding someone that can do a projector retrofit. The small fitment issue has me weary, but at the same time, a retrofit in OEM housings could leak/fog.
2008 BMW 335i 6MT coupe - Montego Blue Metallic | ///M-Sport package | 19" BBS RS-GT
2012 VW Jetta SE - Reflex Silver Metallic | bike rack, tint, powdered Detroits, '13 Hybrid/GLI rep headlights
#24
#28
Cutoff is quite nice and sharp but the right projector needs to be rotated slightly counter-clockwise.
2006 2.5L 5Spd, VF CAI, C2 93Oct Flash, OEM HID Retrofit, GTI Cluster Retrofit, GLI MFSW Retrofit, OEM LED Euro Tails, AMBER CLUB, RCD-510 Retrofit, Auto Headlights/Wipers (RLS Retrofit), OEM Projector Fogs Retrofit (CECM).
#29
Yeah... just as I feared. Both projectors need rotation inward. Something you cannot adjust from the outside. Only way is to unscrew the projectors and tilt them correctly then refasten them. I had to do that 3 times when I retrofitted my own projector kit from TRS. Good thing is you won't have to saw those apart like I had to with my stock lights lol
Guess I was right that it looked to beam at an angle against the ground *is a lighting whore* lol
#30
Yes, I do need to adjust the right one to be more straight, I will do that sometime soon, and will have different picture posted up!
#31
I think they look great with the platinum gray. I actually think they look better with this color than the others.
#32
I would be all over these, you could level out both the projectors out of that tilt without tearing it open.
#33
I wish someone sold these with no projectors built in. Just the housing's. That way you can simply use them to create your custom retrofit.
#35
I think I'm going to order these.....
1995 E34 525i-Favorite//2003 325Ci-Gone
2002 A6 2.7T-Money Pit//2006 Nissan Altima 3.5 SE-Trying to be the "economical college student"
2008 A4 2.0T-Good car//2012 GLI ATB-Current DD
