Results 1 to 5 of 5
Thread: Interior Trim glue: Recommendations?
  1. Member mike in SC's Avatar
    Apr 29th, 2004
    The South
    2005 Honda Civic Si 1988 VW Fox Wagon
    09-28-2012 08:47 PM #1
    There are several places in my wagon where some of the trim plastic unglued. See pictures for problem areas.
    What kind of glue would you recommend to reattach the pieces? Any suggestions?
    Thanks
    "It's dark and you want to go home?"
  2. Member doppelfaust's Avatar
    Aug 15th, 2007
    Tacoma, WA
    1988 Fox GL Wagon
    09-28-2012 11:28 PM #2
    I usually use Weldwood spray adhesive, it's good stuff.
    Aug 17th, 2011
    Brooklyn, NY
    '88 Fox GL Wagon, '04 Jetta GLS Wagon TDi, '89 Fox Coupe (sold)
    09-29-2012 12:02 AM #3
    I have that same issue as your 2nd photo. It's almost as if the material shrunk - it's not very pliable - and I tried using a similar adhesive - but it just tore even more. I plan on deciding on a nice fabric replacement.
    How a VW Fox Wagon sucked me back in...a build thread
  4. Member QuantumSyncro's Avatar
    Apr 28th, 2000
    Des Moines, IA
    97 Jetta TDI, 89 Fox diesel, 92 300SD turbo, 82 GS1100E
    09-29-2012 12:05 AM #4
    ditto on the spray, keep a can of it around just in case.
    The quality of the vinyl fabric used in the Fox isn't that good, and the sun tends to shrink and then it's even harder to get it to stay down, even with adhesive.
    Gir - "won't the sploding hurt?" Zim - "Silence!"
  5. Member mike in SC's Avatar
    Apr 29th, 2004
    The South
    09-29-2012 11:32 AM #5
    It is mostly due to heat and shrinkage, but on the b pillars I replaced the trim b/c of shrinkage. I'll use a spray for what I can.
    redone-Any ideas for what fabric you'll use?
    Thanks everyone.
    I care about the interior a little more b/c the paint is terrible; it's a 20 foot car for sure. I want the interior to be as nice as a 24 year old car can be.
