Results 1 to 9 of 9
Thread: g60 help please
  1. Junior Member kiddeigo's Avatar
    May 31st, 2006
    Portage, PA
    90 corrado g60
    09-29-2012 07:28 PM #1
    so i just started to mod my g60, i have 68mm pully, 3.5 bar fpr chip, isv, and rsr outlet. After i put all the stuff on i started getting wicked idle surge went over everything and haveno leaks, the car ran fine before now have the damn surge.
    Any help would be great
    also how much psi should a stock charger with 68mm pulley put out?
  2. Junior Member kiddeigo's Avatar
    May 31st, 2006
    Portage, PA
    90 corrado g60
    09-29-2012 07:28 PM #2
    also at like 4500 im getting at the most 10 psi of boost
  3. Junior Member kiddeigo's Avatar
    May 31st, 2006
    Portage, PA
    90 corrado g60
    09-29-2012 08:01 PM #3
    this idle surge just started randomly, also it only does it after hit the accelerator, when i first start it idles fine
  4. Member 8716vrocco's Avatar
    Feb 12th, 2001
    Chitown
    86 Scirocco 16v, 90 Celica GT, 05 Honda VTX1800F
    09-30-2012 12:44 PM #4
    I am in no way an expert on G60 stuff so hopefully someone will correct me if I am wrong. I believe a ISV reroute will help your situation.
    Project 16v Lysholm
    "I hope you go commando, otherwise your panties would always be in a bunch"
  5. Junior Member kiddeigo's Avatar
    May 31st, 2006
    Portage, PA
    90 corrado g60
    10-01-2012 05:38 PM #5
    i already did the re route. yeah i was just driving and it started, i adjusted the idle adjust screw and it stopped, then started again so i tightened it up again and now it wont stop
  6. Member mateok's Avatar
    Mar 14th, 2001
    Atlanta, GA
    90 G60(since new) 93 VR
    10-02-2012 09:33 AM #6
    It sounds like you're getting unmetered air in somewhere. I would pull a vacuum on it per Bentley.
  7. Member crazynorweegian's Avatar
    May 8th, 2006
    Portland, OR
    1990 1.9L G60-ST5 Black, 02 S60 2.4t
    10-03-2012 02:48 AM #7
    How do you know you don't have any leaks? Did you do the proper idle screw adjustment procedure? Ignition timing done correctly? ECU vacuum line plugged in and exactly 1 meter? I would grab a spare known-good ISV and try that (or test it by maintaining your own idle until it warms up with it unplugged). Blue temp sensor could cause weird problems like that (also plugging the wrong harness into the blue temp sensor). Check your idle switch adjustment on the throttle cable and the WOT switch functionality. That is everything easy I can think of.
    Stephen
    Portland, OR
    Black 1990 1.9L Stage 5 G60 - keeper
    Corrados decay in a way that can only be measured using quantum physics
    http://sites.google.com/site/corradoproject/
  8. Member mateok's Avatar
    Mar 14th, 2001
    Atlanta, GA
    10-03-2012 11:42 AM #8
    Is it still doing it? Did you find the problem? Or is it a hunk of twisted metal at the bottom of a cliff now?
  9. Member crazynorweegian's Avatar
    May 8th, 2006
    Portland, OR
    10-06-2012 03:17 AM #9
    Quote Originally Posted by mateok View Post
    My guess is: Yes. No. Maybe.
    Stephen
    Portland, OR
